    G1 H3 and M500 P31 to save multiple endstop on combined Z axis
    Firmware wishlist
    532
    • KipKundefined
      KipK
      Hi there
      3.1.1 firmware here
      So I have a printer working well with 3 point auto bed level.
      I use a BL touch for probing and 3 optical endstops on Z max.
      Homing sequence go to Z max on each endstop. Then when print start It does the 3 point bed leveling, and then probe the center.
      I'm very glad of this setup works really well.
      However, I wonder how I can setup a resume after power failure as I do with my one z axis setup.
      I've tried
      G1 Z400 F300 H3
      M500 P31
      But it only save the Z max as a global axis not one value for each motor
      Ideally it should save z max for each separated Z,
      Then on resume print no need to reprobe ( what is impossible in this case ) , it should restart with the correct previous bias recorded.
      Is there another way of achieve this yet?
        You would need to split the Z axis into separate axis and save their positions independently I think.
        If you tram the bed surface using the probe first, you should be able to adjust the Z max endstop positions such that they could be used to relevel on a power loss resume.
        • KipKundefined
          KipK
          Thanks. I was not sure if I can still split Z axis on 3.x as with firmware 2.x
          That should clearly work if so.
          Well, Reprap 3 made this cleaner by not splitting, perhaps someday it could be interesting to add a way to save and restore leveling.
          Adding a new flag to M500 P31 for saving multiple endstop position for one axis.
            Yes RRF3 made it simpler to use multiple endstops on a single axis, but I don't think that extends to measuring of each endstop position. Perhaps
            I'll edit your title and move this to the firmware wishlist for evaluation.
            KipKundefined 1 Reply Last reply Reply Quote 0
            • KipKundefined
              KipK @Phaedrux
              Fell free to move the thread 👍
              I wonder what other interest than failure resume there is to use multiple Z max endstops instead of direct probing zMin?
                Using Zmax endstops has the disadvantage that it doesn't actually measure the current position of the bed surface, so it's a less attractive option outside of power loss recovery where a print is still on the bed.
                • KipKundefined
                  KipK
                  Here is the different procedure I imagine, can you confirm the logic is good ?
                  Configure resume level macro ( macro started manually, not done at each print )
                  • homeZ min with probe
                  • level Z min
                  • probe Z min
                  • separate Z axis
                  • home Z max H3 per Z axis with endstops
                  • save M500 P31
                  start print:
                  • home Z min with probe
                  • level Z min
                  • probe z min
                  • print start
                  resume print after failure:
                  • separate Z axis
                  • home zmax H1 per Z axis with endstops
                  • up bed 5mm
                  • blind level:
                    . calculate motor 2 and 3 bias ( 1 is reference ) and move accordingly
                    G1 Z2 ( mz1max - mz2max );
                    G1 Z3 ( mz1max - mz3max );
                  • go to previous saved position
                  • resume print
                    That sounds logical.
                    • KipKundefined
                      KipK
                      I'm on my way to try that.
                      If it was considered to improve for Reprap 3, method could be contained like this:
                      • Record zmax:
                        G1 H3 Z400 ; as we have 3 independant motor will get zmax of each leadscrew.
                        M500 P31; save those values
                      • Resume print:
                        G28 Z (home using zmax )
                        G91; relative moves
                        G1 Z-15; up bed 15mm
                        Gxx xxx ; restore saved Z bias
                      • KipKundefined
                        KipK
                        So how I'm doing this correcctly using conditionnal gcode ?
                        G1 U(move.axes[2].max-move.axes[3].max) ; restore U bias
                        G1 V(move.axes[2].max - move.axes[4].max) ; restore V bias
                        reports me errors
                        edit: sorry, found the information , brace were missing.
                        G1 U{move.axes[2].max-move.axes[3].max}
                        G1 V{move.axes[2].max - move.axes[4].max}
                        • KipKundefined
                          KipK
                          Seems tehre's something wrong on my logic.
                          Here is wht I've made:
                          Config.g:
                          M584 X1 Y0 Z6:8:7 U8 V7 P3 E4; three Z motors connected to driver outputs 6, 8, 7
                          M350 X16 Y16 Z16 U16 V16 E16 I1                                     ; configure microstepping with interpolation
                          M92 X200.00 Y200.00 Z400.00 U400 V400 E402.00                         ; set steps per mm
                          M574 Z2 S1 P"duex.e2stop";	set endstops for Z
                          M574 U2 S1 P"duex.e6stop";	set endstops for U
                          M574 V2 S1 P"duex.e5stop";	set endstops for V
                          ; Leadscrews
                          M671 X-214:214:214 Y0:-121:118 S10 						    ; leadscrews at middle left, front right, and rear right
                          HomeZ.g:
                          if (!move.axes[0].homed)
                            M98 P"homex.g" ; need to home X Y first
                          if sensors.endstops[2].triggered
                          	G91;
                          	G1 Z-15 F1000 H2 ; move bed up a bit
                          	M400			 ; wait for move to finish
                          M220 S100		; set back speed to 100%
                          G90
                          G1 X0 Y0 F10000; move head to the center
                          G30; probe Z = 0
                          G32; level bed
                          G1 X0 Y0 F10000;
                          G30; probe Z again
                          Macro to calibrate each Zmax:
                          M208 S1 Z-3;	Allow z to be negative
                          G90;
                          G1 X0 Y0  F10000; 		go to the center
                          G1 Z30 F1000;
                          G30		;		 probe bed and set z=0
                          G32		; 		start 3 point bed leveling
                          G1 X0 Y0 F10000;
                          G30     ;	Probe for Z=0
                          G91		; relative mode
                          G1 Z10 F800				; raise nozzle
                          M584 Z6 U8 V7 P5 ; split z axis
                          ;G92 U10 V10; set U V axis to 10 as Z
                          G1 H3 Z370 U370 V370 F1000; move Z, U, V down until endstops trigger and get new z limits
                          M500 P31		; save new z height
                          M584 Z6:8:7 P3 ; unsplit z axis
                          G90
                          Z max values are correctly saved for each z axis:
                          M208 S0 Z341.22 U314.82 V316.30
                          Then after a powerfailure I have a homeZmax.g macro :
                          if sensors.endstops[2].triggered || sensors.endstops[3].triggered || sensors.endstops[4].triggered
                          	G91;
                          	G1 Z-20 F1000 H2 ; move bed up a bit
                          G91
                          G1 H1 Z370 U370 V370 F1000		; move Z, U, V down until endstops trigger
                          G1 Z-10 U-10 V-10 F800      		; get back 10mm
                          G1 H1 Z15 U15 V15 F300  			; go to zmax slowly
                          G1 Z-30 U-30 V-30 F1000;		 			up bed 30mm
                          ; Blind leveling
                          G1 U{move.axes[2].max - move.axes[3].max} V{move.axes[2].max - move.axes[4].max}; restore U V bias
                          G90
                          Problem here is bed is completly tiled.
                          I don't get now where I've failed 🙂
                          • KipKundefined
                            KipK
                            Found it.
                            Seems I have to set also U and V to 0 reference after a Z probe.
                            Now it works.
                            macro calibrate Z max for each axis:
                            G90;
                            G1 Z30 F1000;
                            G1 X0 Y0 F10000;
                            G30     ;	Probe for Z=0
                            G91		; relative mode
                            G90
                            Have to say, object models and conditionnal gcode is a killer feature. 🙂
