    Webcontrol update isn't working.
    CNC
    • Gerrardundefined
      Gerrard
      I followed the instructions here for updating webcontrol - both methods:
      https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Updating_DuetWebControl_files
      using the workbee files from here (just the WorkBeeControl-Duet2.zip file):
      https://learn.ooznest.co.uk/Wiki/WorkBee_Firmware_Releases
      I thought this would work - but I still have the vanilla duet web control... Any suggestions?
      • district9prawnundefined
        district9prawn
        Can you just manually copy and paste the www folder from the web control version you need?
        I've got a workbee and ran into some trouble with the web control after updating using the Ooznest firmware. I ended up just updating to the latest duet firmware, web server and web control and have been sweet ever since.
          Are the Workbee files based on DWC2 or DWC3? If they are based on DWC2 but you have at some point installed DWC3, then you should be able to load the Workbee version by appending /reprap.htm to the IP address in your browser address bar.
