    Duet 3 Spindle Control
    CNC
    • Gerrardundefined
      Gerrard
      Hi All,
      I'm trying to configure my Duet 3 to set my spindle speeds. I'm using a PWM to 0-10VDC board from the out9 pin on the Duet.
      I'm having trouble setting the PWM frequency for the spindle speed. I currently have a multimeter hooked up to the output pins of the PWM converter board, and below is a series of code that I've tried setting different frequencies, but getting more or less the same result in all cases.
      I expect to set the spindle speed to 6000rpm to get 2.5VDC on the pins.
      The board has a pair of jumpers to select between (what appears to be) 0-10V and 0-7.5V logic, I'm confident that I've got this selected right.
      Here's a link to the board i'm using: https://www.auscomtech.com.au/product/pwm-to-voltage-converter-module-0-100-to-0-10v-digital-to-analog-signal/
      M453 C"out9" F50
      M3 S6000
      Read: 4.94V
      M453 C"out9" F100
      M3 S6000
      Read: 4.93V
      M453 C"out9" F1000
      M3 S6000
      read: 4.87V
      M453 C"out9" F3000
      m3 s6000
      Read: 4.74V
      M453 C"out9" F10000
      M3 S6000
      Read: 4.62V
      M453 C"out9" F500000000
      m3 s6000
      Read: 6.00V
      M453 C"out9" F5
      m3 s6000
      Read: 5.96V
      M453 C"out9" ;No frequency
      M3 S8000
      Read: 7.43V
      M3 S10000
      Read: 8.26V
      M3 S12000
      Read: 8.24v
      Any suggestions?
      • Gerrardundefined
        Gerrard
        To simplify the question. Is there any reason why changing the PWM frequency of the M453 command would have no effect on the output voltage - which is supposed to be proportionate to the PWM frequency (with its limits)?
          A Former User @Gerrard
          @Gerrard said in Duet 3 Spindle Control:
          well, to be blunt - the voltage isn't proportional to the PWM frequency but rather the duty cycle.
          • littlehobbyshopundefined
            littlehobbyshop
            I think you need to set your R value in M453 to your spindle max. Expected frequency for your controller is 1-3KHz so F needs to be between 1000-3000.
            PWM control is on the duty cycle of the wave not the frequency, frequency stays constant once you've set it.
            M453 is set once then speed changes done with M3.
            M453 C"out9" R12000 F2000
            M3 S12000 ;Should get 10V
            M3 S6000 ;Should get 5V
            BLV MGN Cube w/Hemera, K8200, Sunlu S8
            • Gerrardundefined
              Gerrard
              right... There's a gap in my understanding there. Thanks for clearing that up. I'll give that a shot this weekend.
              • Gerrardundefined
                Gerrard
                Thanks, that worked.
