    No Axis Movement
    Firmware installation
    1.6k
    • 1d1undefined
      1d1
      OK, back again... thanking you again. I downloaded in the order given and all uploads were successful. This is where we are now:
      G28
      Error: Failed to enable endstops
      So we're back to no movement but much closer, I think, as we know that all motors, drivers and endstops function. I still have the z endstop connected at the z position though the z motor is connected at P4.
      droftartsundefined Vetiundefined 2 Replies Last reply Reply Quote 0
        droftarts administrators @1d1
        @1d1 Check your firmware version with M115, and post response, and please also post your current config.g.
        For forum ease-of-use, copy the text from DWC and paste it in your reply post. For extra points, format it as 'code', by highlighting the copied text and clicking </> in the formatting bar. Should looks something like:
        My config.g here!
        If you do this with all pasted text (eg M122 responses) it makes it MUCH easier to troubleshoot, and will probably make it easier for other forum members to help.
        • 1d1undefined
          1d1
          M115
          FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet WiFi 1.02 or later ```
          FIRMWARE_DATE: 2020-05-19b2
          Q5Delta
          Send code...
          Status
          Idle
          Mode: FFF
          Tool Position
          X
          0.0
          Y
          0.0
          Z
          201.00
          Extruder Drives
          Drive 0
          0.0
          Speeds
          Requested Speed
          0 mm/s
          Top Speed
          0 mm/s
          Sensors
          Vin
          24.2 V
          MCU Temperature
          32.1 C
           Tools
           Extra
           Control All
          Tool	Heater	Current	Active	Standby
          Tool 0
          T0 - Load Filament	n/a	n/a
          0
          0
          Temperature Chart
          No Data
          System Directory
          0:/sys/config.g
          ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Sep 16 2020 09:55:19 GMT-0400 (Eastern Daylight Time)
          G90                                            ; send absolute coordinates...
          M83                                            ; ...but relative extruder moves
          M550 P"Q5"                                     ; set printer name
          M665 R104.3 L215 B52 H210                      ; Set delta radius, diagonal rod length, printable radius and homed height
          M666 X0 Y0 Z0                                  ; put your endstop adjustments here, or let auto calibration find them
          M552 S1                                        ; enable network
          M586 P0 S1                                     ; enable HTTP
          M586 P1 S0                                     ; disable FTP
          M586 P2 S0                                     ; disable Telnet
          M569 P0 S1                                     ; physical drive 0 goes forwards
          M569 P1 S0                                     ; physical drive 1 goes backwards
          M569 P2 S1                                     ; physical drive 2 goes forwards
          M569 P3 S1                                     ; physical drive 3 goes forwards
          M584 X0 Y1 Z2 E3                               ; set drive mapping
          M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
          M92 X80.00 Y80.00 Z80.00 E663.00               ; set steps per mm
          M566 X1200.00 Y1200.00 Z1200.00 E1200.00       ; set maximum instantaneous speed changes (mm/min)
          M203 X18000.00 Y18000.00 Z18000.00 E1200.00    ; set maximum speeds (mm/min)
          M201 X1000.00 Y1000.00 Z1000.00 E1000.00       ; set accelerations (mm/s^2)
          M906 X800 Y800 Z800 E600 I30                   ; set motor currents (mA) and motor idle factor in per cent
          M84 S30                                        ; Set idle timeout
          M208 Z0 S1                                     ; set minimum Z
          M574 X2 S1 P"xstop"                            ; configure active-high endstop for high end on X via pin xstop
          M574 Y2 S1 P"ystop"                            ; configure active-high endstop for high end on Y via pin ystop
          M574 Z2 S1 P"zstop"                            ; configure active-high endstop for high end on Z via pin zstop
          M558 P4 C"^zprobe.in" H5 F120 T6000            ; set Z probe type to switch and the dive height + speeds
          G31 P500 X0 Y0 Z2.5                            ; set Z probe trigger value, offset and trigger height
          M557 R52 S20                                   ; define mesh grid
          M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
          M307 H0 B1 S1.00                               ; enable bang-bang mode for the bed heater and set PWM limit
          M140 H0                                        ; map heated bed to heater 0
          M143 H0 S100                                   ; set temperature limit for heater 0 to 100C
          M308 S1 P"e0temp" Y"thermistor" T100000 B4138  ; configure sensor 1 as thermistor on pin e0temp
          M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
          M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
          M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
          M106 P0 S1 H T45                               ; set fan 0 value. Thermostatic control is turned on
          M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
          M106 P1 S1 H1 T45                              ; set fan 1 value. Thermostatic control is turned on
          M950 F2 C"fan2" Q500                           ; create fan 2 on pin fan2 and set its frequency
          M106 P2 S1 H1 T45                              ; set fan 2 value. Thermostatic control is turned on
          M563 P0 D0 H1 F0                               ; define tool 0
          G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
          G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
          Remove a space
          Z0 ;
          • 1d1undefined
            1d1
            Well, that didn't quite work right. I'll try again just get it the way it should be. Learning a lot here....
            Q5Delta
            Send code...
            Status
            Idle
            Mode: FFF
            Tool Position
            X
            0.0
            Y
            0.0
            Z
            201.00
            Extruder Drives
            Drive 0
            0.0
            Speeds
            Requested Speed
            0 mm/s
            Top Speed
            0 mm/s
            Sensors
            Vin
            24.2 V
            MCU Temperature
            32.1 C
             Tools
             Extra
             Control All
            Tool 0
            0
            0
            Temperature Chart
            No Data
            System Directory
            0:/sys/config.g
            Remove a space
            Z0 ;
            M115
            FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-05-19b2
            • Vetiundefined
              Veti @1d1
              @1d1 said in No Axis Movement:
              this is not reflected in your config
              • 1d1undefined
                1d1
                Done. Homing moves X and Y - no Z. Here is M122:
                Q5
                Send code...
                Status
                Idle
                Mode: FFF
                Tool Position
                X
                0.0
                Y
                0.0
                Z
                210.00
                Extruder Drives
                Drive 0
                0.0
                Speeds
                Requested Speed
                0 mm/s
                Top Speed
                0 mm/s
                Sensors
                Vin
                24.2 V
                MCU Temperature
                32.8 C
                 Tools
                 Extra
                 Control All
                Tool 0
                T0 - Load Filament	Heater 1
                off	20.7 C
                0
                0
                Bed	Heater 0
                off	20.9 C
                0
                0
                Temperature Chart
                M122
                9/16/2020, 11:12:11 AM	M122
                RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
                Board ID: 08DGM-956GU-DJMSN-6JTDA-3S46Q-TUQHH
                Used output buffers: 3 of 24 (11 max)
                Static ram: 27980
                Dynamic ram: 92916 of which 56 recycled
                Exception stack ram used: 264
                Never used ram: 9856
                Tasks: NETWORK(ready,292) HEAT(blocked,1224) MAIN(running,1824) IDLE(ready,80)
                Owned mutexes: WiFi(NETWORK)
                Last reset 00:01:41 ago, cause: software
                Last software reset at 2020-09-16 11:10, reason: User, spinning module GCodes, available RAM 9624 bytes (slot 2)
                Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
                Error status: 0
                MCU temperature: min 31.2, current 32.7, max 33.0
                Supply voltage: min 24.1, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
                Date/time: 2020-09-16 11:12:09
                Cache data hit count 168900657
                Slowest loop: 2.20ms; fastest: 0.13ms
                === Storage ===
                Free file entries: 10
                SD card longest read time 1.3ms, write time 0.0ms, max retries 0
                Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
                === MainDDARing ===
                === AuxDDARing ===
                Segments left: 0
                Movement lock held by null
                HTTP is idle in state(s) 0
                Telnet is idle in state(s) 0
                File is idle in state(s) 0
                USB is idle in state(s) 0
                Aux is idle in state(s) 0
                Trigger is idle in state(s) 0
                Queue is idle in state(s) 0
                Daemon is idle in state(s) 0
                Code queue is empty.
                === Network ===
                Slowest loop: 15.75ms; fastest: 0.00ms
                Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
                HTTP sessions: 1 of 8
                - WiFi -
                Network state is active
                WiFi firmware version 1.23
                WiFi MAC address 5c:cf:7f:76:71:a9
                WiFi Vcc 3.29, reset reason Unknown
                WiFi flash size 4194304, free heap 24616
                WiFi IP address 192.168.1.54
                WiFi signal strength -48dBm, reconnections 0, sleep mode modem
                9/16/2020, 11:11:59 AM	M115
                9/16/2020, 11:10:38 AM	Connection established
                9/16/2020, 11:10:36 AM	Connection interrupted, attempting to reconnect...
                9/16/2020, 11:10:28 AM	G28
                Error: G0/G1: insufficient axes homed
                9/16/2020, 11:10:28 AM	Emergency stop, attemping to reconnect...
                9/16/2020, 11:10:11 AM	Connection established
                9/16/2020, 11:08:50 AM	Connection interrupted, attempting to reconnect...
                HTTP request timed out
                9/16/2020, 11:08:37 AM	Upload of config.g successful after 1s
                9/16/2020, 10:48:26 AM	M115
                9/16/2020, 10:06:42 AM	G28
                9/16/2020, 10:00:42 AM	G28
                9/16/2020, 10:00:05 AM	Connection established
                9/16/2020, 10:00:04 AM	Connection interrupted, attempting to reconnect...
                9/16/2020, 9:59:44 AM	Upload of config.g successful after 1s
                9/16/2020, 9:59:12 AM	G28
                9/16/2020, 9:59:02 AM	Connection established
                9/16/2020, 9:59:02 AM	Connection interrupted, attempting to reconnect...
                9/16/2020, 9:58:49 AM	Upload of config.g successful after 1s
                9/16/2020, 9:57:32 AM	G28
                9/16/2020, 9:56:58 AM	Connection established
                9/16/2020, 9:56:58 AM	Connection interrupted, attempting to reconnect...
                9/16/2020, 9:56:18 AM	Upload of config.g successful after 1s
                9/16/2020, 9:38:32 AM	Connected to 192.168.1.54
                code_text
                  @1d1 Does your config.g have M584 X0 Y1 Z4 E3 in it now? And you'll need to reset after changing this.
                  Is your homedelta.g unchanged from the one you posted earlier in the thread?
                  Please send M98 P"config.g" and post the response (this checks for errors in config.g).
                  • 1d1undefined
                    1d1
                    @droftarts said in [No Axis Movement](/post/179087):
                    > M584 X0 Y1 Z4 E3
                    Yes it is
                    ; homedelta.g
                    ; called to home all towers on a delta printer
                    ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Sep 16 2020 09:55:20 GMT-0400 (Eastern Daylight Time)
                    G91                        ; relative positioning
                    G1 H1 X215 Y215 Z215 F1800 ; move all towers to the high end stopping at the endstops (first pass)
                    G1 H2 X-5 Y-5 Z-5 F1800    ; go down a few mm
                    G1 H1 X10 Y10 Z10 F360     ; move all towers up once more (second pass)
                    G1 Z-5 F6000               ; move down a few mm so that the nozzle can be centred
                    G90                        ; absolute positioning
                    G1 X0 Y0 F6000             ; move X+Y to the centre
                    	M98 P"config.g"
                    HTTP is enabled on port 80
                    FTP is disabled
                    TELNET is disabled
                    Error: Invalid Z probe type 4
                    Error: Invalid Z probe index
                    Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
                      @1d1 Change
                      to
                      M558 P5 C"^zprobe.in" H5 F120 T6000            ; set Z probe type to switch and the dive height + speeds
                      (Probe type 4 is not supported in RRF3, use either 5 or 8.)
                      Still not sure why it's not activating the endstops. What EXACTLY happens when you press HOME ALL? If the X and Y motors are moving (the Z may not be, but I think that's possibly a wiring issue), how far do they move? They should move 215mm up towards the endstops. If they don't move that far (which may be why the endstops are not being triggered and you get the error message) it's possible that your steps per mm on XY and Z are incorrect.
                      • 1d1undefined
                        1d1
                        Well, until I can get some homing done, I haven't even configured or connected my z probe. Or done a PID tune for the hot end either.
                        What happens right now is that X and Y push the extruder up and out between the X and Y towers. Z doesn't move at all. I hit emergency stop. If the Z went up, it would center the movement. I'll check the Z connections.
                        Z motor works fine when driven from another driver (X) so the wiring is good. Right now, I think that the endstops not working despite clear triggering when manually pushed. They just don't stop the motors, and end up banging away at the endstop switches. I need to look at the board while this is happening to see if they are actually being hit.
                        Everything worked perfectly on the MKS Base board that the printer shipped with. However, I wanted the Duet as I use a direct drive extruder and Duets on my other two printers.
                        I go do some more checks and see if I get any farther.
                        • Vetiundefined
                          Veti @1d1
                          i am confused
                          i dont think there is anything in the config.g you posted that would create this output.
                          did you post the correct output?
                          • 1d1undefined
                            1d1
                            I found it.. finally.... and terribly embarrassing: X and W were reversed at the drivers. It is now homing perfectly. Now I'm going to work on the Z probe setup and will introduce a new topic if I can't get it right. For now, and to all of you who helped, Major Thanks!!! I was lost and have now been found...
                            • 1d1undefined
                              1d1
                              Oh - and PID tune too. It will be fine ... or else.
