    Multiple Errors Duet3
    Firmware installation
    3.6k
    • dkundefined
      dk @dk
      @dk
      I try third Toolboard and BL-touch - same result. No self test at power up. M401 and M402 works, but after first M402 BLTouch start flashes red once per second
        A Former User
        I think the moral of the story (and the numerous other threads that litter this forum) is that the Bl-touch is a terrible piece of hardware....
        dkundefined 1 Reply Last reply Reply Quote 0
          dc42 administrators @dk
          @dk said in Multiple Errors Duet3:
          @dk
          1. What VIN voltage to the tool board are you using?
          2. Can you send one tool board and bltouch to me here in UK? I think we've gone as far as we can trying to diagnose this remotely.
          • dkundefined
            dk @dc42
            I use 24 Volt through Tool Distribution Board, the same voltage as for Duet3.
            Can you please send to me foto of your Toolboard with BL-touch connected and config settings? I want to double-check if I miss something
            Can you give me your address (or email it to komkovdy at gmail) so I can check shipping cost and delivery time.
              Here's how it is connected:
              Even with CAN disconnected from the tool board, it does the self test at power on. So no configuration is needed for it to do the self test.
                PS - my BLTouch is version 3.0. Maybe something changed with 3.1?
                  I have just ordered a BLTouch version 3.1 which should arrive within a few days. I suggest I do tests using that before you send anything to me. I can't think of anything else different between your setup and mine.
                  • dkundefined
                    dk @A Former User
                    @CaLviNx
                    What would be a better alternative to BL-touch?
                      A Former User @dk
                      @dk
                      In my opinion the IR sensor that was invented by David Crocker a.k.a DC42
                      The only "restriction" is that you need to choose the print surface that it can see carefully. But due to its small size and no moving parts I feel it is the perfect solution, and for me it is, it's all I use (apart from a smart effector on my delta)
                        The IR sensor works well on most uniform opaque surfaces. I advise against using it with transparent bed surfaces such as glass (except perhaps black glass) or PEI.
                          A Former User @dc42
                          it works on black textured glass the same as the creality & anycubic types, also I have it working on scuffed/sanded PEI.
                          • dkundefined
                            dk
                            @dc42 said in Multiple Errors Duet3:
                            IR sensor
                            I would love to try using IR sensor but I have already designed and print effector for BL-touch and already bought 3 of them.
                            Wait for BL-touch 3.1 arrive to you and I hope you can find a reason why all 3 sensors don't work with the ToolBoard correctly
                            • dkundefined
                              dk @dc42
                              as a result of frequent connections and disconnections, I have already broken 2 CAN connectors for the Toolboard . Tell me please what kind of connector it is, jst zh 4 pin 1.5 mm connector or some other?
                              And do you have a suggestion where I can buy it? I didn't find any similar connectors at filastruder and printedsolid
                              Thank you
                                Yes it's JST ZH 4-pin, widely available on eBay as well as from the usual electronic component distributors.
                                My BLTouch 3.1 has arrived, so I hope to test to with a tool board later today.
                                  @dk, this thread is getting too long and has an inappropriate title, so I am starting a new one for this specific problem (Duet 3 tool board and BLTouch).
