DUET2 Ethernet | Y-Axis movement --> Timeout Webserver
@Egris said in DUET2 Ethernet | Y-Axis movement --> Timeout Webserver:
V3.
did you update to 3.1.1?
did you update the wifi firmware as well? -
HI, yeah updated to 3.1.1.
Duet 2 Ethernet needs wifi firmware? -
no my bad
by crashing you mean you can not connect to the webserver anymore?
do you have a paneldue?
yes, cant connect back. I have no Panel due. For the ongoing print there is no drawback.
what browser are you using?
is usb connected?
tryed Edge and Firefox, no diffrence. USB is not connected at the moment
Can you please post your config.g and homing files as well as the output of M122 and M98 P"config.g".
How are you commanding the long Y axis move? How long?
What do you mean by the webserver failing or crashing? what exactly is happening?
Here is the config File.
When I do a Y-Axis Move "100mm" via Move-Botton on Web-Control the Webserver timed out and i cant reconnect. Only after a powercycle i can connect back.
When i move the X-Axis via the Buttons there is no problem..Started a print, Can post the other informations tomorrow.
Best regards
And homing works normally?
In addition to the other info requested, what version of DWC is installed?
If you send G91 G1 Y100 from the console does it have the same effect?
First of all thank you for all of your help.
Finally I found my problem what is causing the webserver to stop working when y-axis is moved by firmware or manually pushed.. :D.The wires of the Y-Axis Stepper where to close to my Ethernet-Cable.
Worked perfectly for 2 years until now..electro magnetic disorder
