M500 Always Fails
@bearer Thank you!
That would've been nice to know right off the bat. Especially since none of the guides take it into account. Seems like I could've saved a whole lot of head-banging if that had been cleared up immediately.
Also, that's a super bizarre omission that makes no sense at all. I hope it gets rectified soon. Having only M500 and M501 not work in SBC mode is seriously odd
It boils down to differences in the virtual sd card used on the pi which isn't fully compatible with the code that uses the real sd card when in stand alone mode.
I think it was scheduled for 3.2 but haven't kept up with stuff lately (also, its possible the Wiki is out of date, but it doesn't work odds are its still at thing)
Edit: Calling it an omission isn't quite fair, is clearly been on display in the bottom of a locked filing cabinet stuck in a disused lavatory with a sign on the door saying ‘Beware of the Leopard.”
Do you need any of the features the Pi offers? Might be better to switch to stand alone mode where M500 is supported while they implement the filesystem support for the SBC mode? The Pi/SBC doesn't really offer much at the present?
@bearer The main thing it gives me right now is the ability to have the Pi 4 outside of the electronics enclosure, which gives me functional wifi without requiring any additional adapters (the base of my delta printer is all aluminum). I also have it hooked up to a Pi touchscreen, which gives me a much more complete interface at the printer itself, rather than the limited interface of a PanelDue. Plus I have a Bluetooth keyboard and touchpad paired, which has been convenient. And having the Pi 4 right there makes it super simple to have a camera hooked up for monitoring progress and/or capturing time lapses. Honestly, I'm loving the SBC thing compared to my other Duet-powered setups. If it's only the lack of M500, I'll deal with that until it's fixed. I just wish I hadn't wasted a week on trying to resolve this.
I haven't seen any mention of M500 or M501 in the recent 3.2 beta fixes and changes, so it doesn't look like it'll be making it into this release.
If you replace the ribbon cable with ethernet and stick an sd-card in the duet, you can use the pi to bridge ethernet to wifi and keep using the screen to access DWC running on the duet's ethernet interface. Should -give you the same-ish functionality + M500 while the devs fix the file system stuff that is missing
(edit: suppose you don't have to remove the ribbon cable actually, it can supply power or just sit there unused as long as the Duet has a sd-card with a config file it will ignore the SBC interface afaik)
I don't want to spend more money on an ethernet bridge. Pi4s and touchscreens I have littered about the workshop practically for free
All I need to do is put my heater autotune parameters and delta auto-configure results manually in config.g. I run auto-config before every print anyways. I can't think of anything else I use M500 for. It's only tedious initially because of the initial configuration which requires adjusting those settings multiple times until I zero in on the right ones.
It's also super comforting to know that I'M NOT DOING ANYTHING WRONG and there's nothing wrong with my setup that'll bite me later. That was my main concern.
@GoremanX said in M500 Always Fails:
you can use the pi for that
@bearer Thank you!
Sorry about that. I should have clued into checking the unsupported list first. I hope the road to feature complete isn't much longer.
@GoremanX Thanks for the report, I could confirm this is a bug in DSF. It will be fixed in the next software version.
The reason it is happening is because you have configured heaters with gaps (i.e. for example heater 0, 1, 3, 5). You can work-around this problem by configuring the heaters sequentially.
@chrishamm Thank you for that clarification. I configured the heaters in the order that seemed logical to me to keep them organized compared with sensors and tools. I tried re-organizing the config file so that sensors and heaters are in numerical order (1,2,3), but it didn't seem to have fixed the issue.
I skipped heater 0 since I'm using an AC bed heater and the SSR doesn't need vast quantities of current so it's being powered by heater 2 instead, which simplifies wiring. But I did have a sensor 0 configured as a general purpose sensor that was purely informational. So I went ahead and created a heater 0 (that won't do anything) and assigned it to sensor 0, and now M500 works as expected.
Heater 0 doesn't need to be Out0. I have AC bed heater on an SSR on Out1, but it's heater 0 (and I don't have any problem with M500).
M308 S0 P"spi.cs1" Y"rtd-max31865" ; configure sensor 0 as PT100 via CS pin spi.cs1 M950 H0 C"out1" Q5 T0 ; create bed heater output on out1 and map it to sensor 0 M307 H0 A500 C1500 D12 S1 V0 B0 ; configure bed heater (since mains heater supply voltage is not relevant) M140 H0 ; map heated bed to heater 0 M143 H0 S150 ; set temperature limit for heater 0 to 150C -
@achrn That's all well and good, but it seems unnecessarily confusing. What I did isn't technically wrong, it just happened to run afoul of a bug. I like being able to reference heater, output and sensor by the same number to avoid any potential mistakes in the future when I haven't looked at the file in months and suddenly need to make changes, especially when using these boards on many different types of printers that have completely different physical configurations
