UPS 24v on SKR PRO RRF 3
STM
883
    sankafola
    Hello all i wonder if i can get some help here , i have the following :
    Anycubic Predator
    SKR PRO ver 1.2
    Smart Effector ver 2
    Magballs
    RRF 3
    Board: STM32F4 SBC (STMSBC)
    DSF Version: 3.2.0-beta1+1
    Firmware: RepRapFirmware for STM32F4 based Boards 3.2-beta1_2 (2020-09-15b1)
    Am trying to add Resume by using the Bigtree UPS 24v , which have 2 wires to the PS 24v and another plug for a 3 pin connector , anyone can help how to configure it in the RRF config files and where to connect it to which connector on the SKR PRO
    thanks in advance
      A Former User
      AFAIk RRF3 doesn't yet have support for a power loss input, but you have to set it up as a trigger on a available pin and have the trigger macro in turn execute your pause.g (or replicate its function in the trigger macro)
      See https://duet3d.dozuki.com/Wiki/Gcode#Section_M581_Configure_external_trigger
        Stephen6309
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M911_Configure_auto_save_on_loss_of_power
          sankafola
          @bearer so i put the 3 pin one one empty one ok then i put the M581 in the config.g as
          M581 P"e0stop+e1stop" T2 C1
          Trigger 2 is a pause
          now my questions how to save the last position of the hotend and how to resume ? and how to make the 3 pin monitor the power ?
          ? 1 Reply Last reply 10 Oct 2020, 16:43 Reply Quote 0
            A Former User @sankafola
            @sankafola said in UPS 24v on SKR PRO RRF 3:
            i thought pause handles the saving, according to https://duet3d.dozuki.com/Wiki/Gcode#Section_M916_Resume_print_after_power_failure
            presumably one of the three pins go high or low when the power input fails, but i'm not familiar with the module
            undefined 2 Replies Last reply 10 Oct 2020, 17:06 Reply Quote 0
              sankafola
              so i need also to use M911 in the config.g but let me ask you this if the pause saves the last position of the print i need to make a marco to get this info and resume how ??
                sankafola @A Former User
                @bearer here is the one am talking about https://www.biqu.equipment/collections/expansion-board/products/btt-ups-24v-v1-0-resume-printing-while-power-off-module
                  @bearer so if i do this M581 P"!e2stop" T2 C0 means when the inverted pin goes from 5 v to 0 do a pause is that right ?
                  but if the power is cut and these capacitor keep it alive for 1 more min and it paused how it will resume what do i need to do to get it to resume ?
                  ? 1 Reply Last reply 30 Oct 2020, 14:30 Reply Quote 0
                    @sankafola I'm interested too because I have a 12VDC power supply and to be able to use the resume after power outage I thought to buy this:
                    https://www.aliexpress.com/item/32967985788.html?spm=a2g0o.productlist.0.0.2d9255cbWfDPoe&algo_pvid=cdd5d04b-1af9-4065-9037-be32ec8befcc&algo_expid=cdd5d04b-1af9-4065-9037-be32ec8befcc-8&btsid=0b0a555b16040680685654891ea7fc&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
                    So it would be possible to connect the otuput port of this "UPS" to a free pin of the DUET 2 Wifi and trigger a pause?
