    New firmware 1.19 beta 2
    Firmware installation
    18
    70
    10.0k
    • cbusilloundefined
      cbusillo
      Beta 5 does the same thing for me. While flashing the firmware becomes unresponsive. After power down and up, it is running the old firmware.
      I'm excited for this firmware to become stable. I want to buy a couple more 😃
        @cbusillo:
        You mean it's still reporting in DWC that beta 4 is running? You may need to update file iap4e.bin to latest version first - just up!oad it through the Settings/General page as you do the firmware.
        • cbusilloundefined
          cbusillo
          Where do I find the most up to date iap4e.bin? The one in my sys directory currently is 60.0 KiB 4/7/2017, 1:24:13 PM.
          I noticed I am on the CK fork. Could that be my problem? I believe at the time you had not released the most up to date Duet Ethernet firmware. I was trying to get bed mesh to work so I was trying anything I could think of.
          Thank you for the quick responses as always.
          • cbusilloundefined
            cbusillo
            I used SAM-BA to flash beta 5. That appears to have worked. As I was pressing the erase button I realized the reset button MAY have been pressed by a wire.
            • minimundefined
              minim
              @dc42:
              I have withdrawn beta 4 and released beta 5, which fixes the known issue that was causing software resets. Those of you who were affected by this, please accept my apologies for the inconvenience caused. The WiFi module code has not changed, so you can install beta 5 over beta 4 using the standard firmware upgrade procedure.
              The Duet06/085 build is still at beta 4 because it was not affected by this issue.
              Nothing to apologise for! I'm using the beta releases to try to help test and locate the bugs. If I needed is to be stable all the time I'd be on the stable release 🙂 Glad to see that you got it sorted.
              You are doing great work btw!
              • kelchmundefined
                kelchm
                @dc42:
                @kelchm, you don't need USB or PanelDue to complete the upgrade. See https://duet3d.com/wiki/DuetWiFiFirmware_1.19_alpha#Getting_ready_to_upgrade. But I recommend you wait until I have released beta 5.
                Just reviewing the steps again it seems step 2 under 'Doing the upgrade' requires a PanelDue or USB:
                "When the Duet has restarted after the firmware upgrade, execute the SetNetwork macro on PanelDue or via USB (if using USB then the command is M98 P/macros/SetNetwork)."
                  I see. You could temporarily put that M98 command at the end of config.g.
                  EDIT: I just realised that won't work, because the network won't be enabled at that point.
                  In a later beta I will add the facility to set up the connection by temporarily running the Duet as an access point, as before.
                  • BlackTomundefined
                    BlackTom
                    I'll give another try to 1.19 soon.. with the 1yr old twins, time is missing 😉
                    • tomasfundefined
                      tomasf
                      I just updated my test machine to beta 5. Still the same problem where it won't connect to my network. After [c]M552 S1[/c], nothing happens for a while, until it finally says "Wifi module is idle".
                        In theory that means that you didn't send it a M587 command with the correct SSID and password, or that it can't see the wifi network. You can send M587 with no parameters to check that it has remembered the SSID correctly.
                        • tomasfundefined
                          tomasf
                          Hmm. I added another network (M587 reports both), and it did successfully join that one. Unfortunately, that's not the network I ideally want to use. Countless other devices in my home connect to my regular network without any problems. Strange.
                            I've just noticed a bug. If the password contains a semicolon then the M587 command will not be parsed correctly. So passwords containing semicolons won't work. I'll fix this in the next beta.
                            There may be other characters that won't work in wifi passwords - unfortunately the SDK for the WiFi module is not open source, so I can't check. But they should be the same characters that didn't work before, or a subset of them.
                            • Adamfilipundefined
                              Adamfilip
                              Just updated to 1.19 Beta 5, working well overall. noticed two small issues
                              1. when using Gcode console, if i try to add a new wifi network using
                                M587 S"Wifi Name" P"MyPassword" it will convert it all to Capitals. even if i need it to be Case sensitive.
                              2. during a print, I paused it, and then went to control on Panel Due and wanted to extrude extra filament as i was changing rolls.. i set to to extrude 50mm at 5mms/sec and it ignores the speed setting and tried to extrude all within 1 second.. which was way too fast and caused the extruder to skip, dont recall if this was an issue on previous firmware
                              • Jackalundefined
                                Jackal
                                @Adamfilip:
                                For number 1 you can turn off "Always Convert G-Codes to Upper-Case" in "Settings > User Interface", probably DWC need a check to see if it is a M587 gcode or simply leave the case of quoted parameters.
                                  Adamfilip
                                  Hoping a Tab can be added to webcontrol to add/remove wifi networks. Enable ADhoc
                                    I've just released 1.19beta6. Those of you already running a 1.19beta version can just install it over the network. See https://github.com/dc42/RepRapFirmware/blob/dev/WHATS_NEW.md for the change list.
                                    • gate546undefined
                                      gate546
                                      @dc42:
                                      I've just released this at https://github.com/dc42/RepRapFirmware/tree/dev/Release (look in the Edge folder for your board). See https://github.com/dc42/RepRapFirmware/blob/dev/WHATS_NEW.md for the full change information and important upgrade notes.
                                      what means this :"DuetWiFiServer-1.19beta1.bin Restored DuetWiFiServer-1.19beta1.bin"
                                      Thank you
                                      Dommy
                                        I accidentally removed that file from the Duet-WiF/Edge folder when I committed release 1.19beta6 of RepRapFirmware. So I put it back again.
                                        • Kulitorumundefined
                                          Kulitorum
                                          1.19 beta 6 does not connect
                                          I tried 1.19 beta6 but is unable to get the printer to connect to my wifi.
                                          After updating, and running the SetNetwork macro, I connect through USB and M552 returns "Wifi module is idle"
                                          Sending "M552 S1" and I get "Wifi module is changing state" for 1-2 minutes, then "Wifi module is idle" again.
                                          Ideas?
                                            Kulitorum
                                            Meh, M552 S2 responds:
                                            11:24:24.849 : WiFi reported error: invalid access point configuration
