    pydsfapi [v3.2.0] - Official Python Client Library for DSF
    DSF Development
    3.2k
    • achrnundefined
      achrn @wilriker
      @wilriker Has the type of the MachineModel type that subscribe_conenction.get_machine_model() returns changed?
      My scripts that previously did that then e.g. for h in machine_model['heat']['heaters'] are suddenly reporting TypeError: 'MachineModel' object is not subscriptable.
      (This might have been a change in 3.1.2 - I had thought I installed 3.1.2, but when I installed 3.1.3 it suggested it was replacing 3.1.1).
      wilrikerundefined 2 Replies Last reply Reply Quote 0
      • wilrikerundefined
        wilriker @achrn
        @achrn I have noticed something similar but TBH I have no idea what is going on here. Nothing has changed in regards to this but still it is no longer working. I have to investigate that.
        Which python version are you using?
        Manuel
        My Tool Collection
        achrnundefined 1 Reply Last reply Reply Quote 0
        • achrnundefined
          achrn @wilriker
          @wilriker Wow that was quick!
          It occurred to me I could check for myself when the change happens - it does change between 3.1.1 and 3.1.2 and if I roll back to 3.1.1 my scripts start working again - MachineModel is subscriptable in 3.1.1, but not in 3.1.2 and 3.1.3.
          Having looked at the diff on GitHub 3.1.1 - 3.1.2 I can't see why the changes would change what gets returned (apart from let it be longer). As far as I can see teh changed def receive_json(self): was returning a str and is still returning a str.
          My Python is 3.7.3
          • wilrikerundefined
            wilriker @achrn
            @achrn Just as an idea, have you removed all .pyc files as well as __pycache__ directories? Just to make sure nothing is stuck in half-way pre-compiled voodoo black-magic bogus.
            Manuel
            My Tool Collection
            • achrnundefined
              achrn @wilriker
              @wilriker I ahdan't, but I was doing pip3 uninstall pydsfapi before each new install.
              I've tried again - unistall, hunt for any pydsfapi traces and obliterate them (including fo ~/.local/lib/python3.7 where I found a few). I'm not sure I want to remove all __pycache__ and *.pyc - plus it would take a while to hunt them all down. There are no *dsf*.pyc or pydsfapi* (except the .gz I'm installing from) files anywhere on the machine before I do a pip3 install
              After that, still the same behaviour - MachineModel object is not subscriptable.
              I have a relatively simple workaround, because if I don't transfer a full model, my first 'patch' gets a whole model. So I can easily change my scripts to start with an empty dict, and use get_machine_model_patch() to obtain a 'patch' containing the whole model (as a nice predictable string). Then I apply that patch to the empty dict, and that gives me a dict of the machine model, and the script proceeds from that point fine.
              • wilrikerundefined
                wilriker @achrn
                @achrn I have a vague theory of what might be the cause for this. But I can probably only test next week.
                Manuel
                My Tool Collection
                • achrnundefined
                  achrn @wilriker
                  @wilriker No problem - as I say, I've got an easy workaround, so there's not a rush on my account. Thanks.
                  • wilrikerundefined
                    wilriker @achrn
                    @achrn said in pydsfapi [v3.1.3] - Official Python Client Library for DSF:
                    I see the same problem with 3.1.1. It works for me (both versions) if I use
                    for h in machine_model.heat['heaters']
                    i.e. trying to access heat as a member rather than a dict key.
                    Manuel
                    My Tool Collection
                    • achrnundefined
                      achrn @wilriker
                      @wilriker said in pydsfapi [v3.1.3] - Official Python Client Library for DSF:
                      Yes, that works for me too in 3.1.3.
                      However, it breaks my patch-applying routine, so I think it's more work for me than my other workaround (at least, for my existing scripts).
                      • wilrikerundefined
                        wilriker @achrn
                        @achrn I don't know why this works for you in 3.1.1 (as it does not for me) but I found a simple way of getting it to work. I would though hold that off for version 3.2.0 because you said you have a working alternative solution.
                        Manuel
                        My Tool Collection
                        • achrnundefined
                          achrn @wilriker
                          Yes, no problem for me - I have what I wanted working now, so don't rush on my account.
                          • wilrikerundefined
                            wilriker
                            Release v.3.2.0
                            I am pleased to announce the release of version 3.2.0 of pydsfapi that syncs all the changes introduced with DSF 3.2.x.
                            This release also contains some major contributions and cleanups from @resam, thanks for that!
                            The package can be downloaded as usual from GitHub Releases page but will probably be available to be installed via pip in the future.
                            Manuel
                            My Tool Collection
