    Timelapses, are they possible?
    Third-party software
    2.6k
    • resamundefined
      resam
      You should not need the python3 ... prefix.
      What does systemctl status duet_timelapse.service say?
        A Former User @resam
        @resam said in Timelapses, are they possible?:
        it looks ok
        • resamundefined
          resam
          Nope - "auto-restart" means it crashed somewhere...
          What does journalctl -t duet_timelapse.service say?
            • resamundefined
              resam
              Whats your current ExecStart line? I think you might have messed around with it a bit too much 😃
                uh surely, how can I see the ExecStart?
                  A Former User @A Former User
                  @the_dragonlord said in Timelapses, are they possible?:
                  Thanks for everything....it didn't create the video at all
                  • resamundefined
                    resam
                    I've pushed another update - turns out I had the ffmpeg option disabled instead of enabled.
                    With the latest update you need to pass in this extra command line argument: --run-ffmpeg
                    A Former User? 2 Replies Last reply Reply Quote 0
                      execellent!! Have yoy solved the auto start issue too?
                        --run-ffmpeg
                        IT WWWWWWOOOOORRRRKKKKKKSSSSSSSSSSSSSSSS!!!!!!! Great jon my friend, great job!!! Thanks a lot for everything!!!
                        ok, it works with the example print but not with mine....I've inserted the GCODE in the layer change but it doesn't take the pictures...tha GCODE works because when the layer changes I see the nozzle stopping for a while....I'm using Ideamaker as slicer....any idea?
                        EDIT:
                        It started to wokr after about 6-7 layers....they are not so small layers, it take about 30-40 secs each to complete
