    Improving Build Instructions
    Firmware developers
    773
    • Garth_42undefined
      Garth_42
      Under the cmake section, I don't have a toolchain file. Not sure if this is an issue or not either.
        It looks like you have somehow lost the tool prefix, because it should be looking for arm-none-eabi-g++ not simply g++.
        • Garth_42undefined
          Garth_42
          Hi @dc42 I appreciate your help. It is looking like there is something larger that is the matter with my configuration. I don't even have Tool Settings.
          • Garth_42undefined
            Garth_42
            Okay, so I was looking over the build instructions again and I realized that for some of the repos I installed the master version instead of the specified version. I am now using the specified version of each repo and I am seeing the arm-none-eabi for all the repos except the CANlib and FreeRTOS.
            Even with that, I am still getting the path error.
            • Garth_42undefined
              Garth_42
              Also, with the repos where I am able to find the Tool Settings, it is looking like it is trying to compile and gets build errors. So to my understanding it is interesting that it is saying that it can't find it in path still.
              Garth_42undefined 1 Reply Last reply Reply Quote 0
              • Garth_42undefined
                Garth_42 @Garth_42
                Hi everyone, I am not experienced in building large C++ projects and I don't want to be a burden on the forum, does anyone have a good resource on general build advice/troubleshooting that I can look at?
                • Garth_42undefined
                  Garth_42
                  Hello everyone,
                  I finally was able to compile the firmware! I am noting down what I did here that made it work hopefully to help others with the first build.
                  Make sure that:
                  You are checking out the correct "tags" of a repo in github. A certain version of the firmware requires certain tags of a repo to be installed. See this for V 3.02: https://github.com/Duet3D/RepRapFirmware/blob/v3.02-dev/BuildInstructions.md ... there is a table listing the tag (not branch) to pull from.
                  Also, the order of "make" in path matters. I had Chocolatey installed also and its make was further u on the list in my Path environment variable which overrode the version of make that is being used for this project.
                  This forum post has a lot of helpful information and got me the rest of the way.: https://forum.duet3d.com/topic/19980/little-help-to-build-rrf3/3
                  Good luck!
                  seraserundefined 1 Reply Last reply Reply Quote 0
                  • Garth_42undefined
                    Garth_42
                    Also, an easy way to add a project to Eclipse is File -->Open Projects From File System and then select the Firmware directory with all of the downloaded projects into it.
                    Also, make sure to read the entire page of instructions, not skipping over anything. For the Duet 3 you don't need to compile the DuetWifiSocketServer project, but you do still need it added into Eclipse.
                    • seraserundefined
                      seraser @Garth_42
                      @Garth_42 Im glad if my topic help you because @oliof is great and wonderfull.
                      I think I have my solution near...will see
                      Can you share your downloaded CoreNG, FreeRTOS, RRFLibraries, duetwifisocket and Reprapfirmware?
                      Yo check if my problem is my environnment or files
                      Thank you
                      • seraserundefined
                        seraser
                        Nevermind finally compiled latest version fine.
                        • Garth_42undefined
                          Garth_42 @seraser
                          @seraser glad you finally compiled it! Sorry I didn’t respond in time.
