    3.2.0-beta3 requires a DWC Emergency stop to be able to print
    Beta Firmware
    • Stephen6309undefined
      Stephen6309
      3.2.0-beta3 requires a DWC emergency stop to be able to print. Fired up the printer today, start print, H0 to 65C, H1 to 220C, the H1 heatup fails and goes to 2000C and the parts cooling fan goes to 100%. The Toolboard 1LC doesn't get configured properly on when the printer is turn on. Only happpens when first turned on.
      Beta3 is on the Duet 3 and 1LC.
      PI4 is powered by an Meanwell 5vdc power supply, Duet 3 not receiving or sending 5vdc to Pi4.
      Pressing the reset button on the Duet 3 doesn't reset the Toolboard 1LC, but the emergency stop in DWC does.
      Didn't do a M122 B121 after first power up.
      Reset button on Duet 3:
      m122 b121
      Diagnostics for board 121:
      Duet TOOL1LC firmware version 3.2-beta3.2 (2020-11-13)
      Bootloader ID: SAMC21 bootloader version 2.1 (2020-11-03b2)
      Never used RAM 4704, free system stack 96 words
      HEAT 43 CanAsync 88 CanRecv 82 TMC 65 MAIN 349 AIN 70
      Last reset 00:00:01 ago, cause: software
      Last software reset at 2020-11-27 09:13, reason: HardFault, available RAM 4180, slot 2
      Software reset code 0x0060 ICSR 0x00000003 SP 0x200011c8 Task
      Stack: 20001018 20001304 00000011 00000000 20000928 000172cd 00018250 01000000 00037b9c 00037c96 20001218 200032d0 00000020 00017a61 20004608 00000000 20001300 00008895 00037b9c 20004618 00037c96 43431440 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5
      Driver 0: position 0, 80.0 steps/mm, standstill, SG min/max 2/2, read errors 0, write errors 1, ifcount 61, reads 533, writes 9, timeouts 0, DMA errors 0, failedOp 0xff
      Moves scheduled 0, completed 0, in progress 0, hiccups 0
      No step interrupt scheduled
      VIN: 24.3V
      MCU temperature: min 999.0C, current 0.0C, max -273.2C
      Ticks since heat task active 115, ADC conversions started 1108, completed 1107, timed out 0
      Last sensors broadcast 0x00000000 found 0 119 ticks ago, loop time 0
      Free CAN buffers: 36, messages lost 19, duplicates 0, oos 0, busOff 0
      H1 goes to 2000c. Can't turn off H1. Endtops not found. File ID error. Errors not saved in console.
      m122 b121 after error:
      HEAT 43 CanAsync 88 CanRecv 82 TMC 65 MAIN 257 AIN 70
      Last reset 00:00:18 ago, cause: software
      Driver 0: position 0, 80.0 steps/mm, standstill, SG min/max 2/2, read errors 0, write errors 0, ifcount 61, reads 8836, writes 0, timeouts 0, DMA errors 0, failedOp 0xff
      VIN: 24.3V
      MCU temperature: min 38.5C, current 38.6C, max 38.8C
      Ticks since heat task active 38, ADC conversions started 18782, completed 18780, timed out 0
      Last sensors broadcast 0x00000000 found 0 41 ticks ago, loop time 0
      Free CAN buffers: 36, messages lost 168, duplicates 0, oos 0, busOff
      m122 b121 after emergency stop, and now printing:
      Never used RAM 4168, free system stack 96 words
      HEAT 43 CanAsync 88 CanRecv 82 TMC 53 MAIN 333 AIN 64
      Last reset 00:00:53 ago, cause: software
      Driver 0: position 0, 418.0 steps/mm, standstill, SG min/max 2/2, read errors 0, write errors 1, ifcount 74, reads 26497, writes 12, timeouts 0, DMA errors 0, failedOp 0xff
      VIN: 24.0V
      MCU temperature: min 37.6C, current 37.7C, max 38.2C
      Ticks since heat task active 51, ADC conversions started 52866, completed 52865, timed out 0
      Last sensors broadcast 0x00000002 found 1 55 ticks ago, loop time 0
      Free CAN buffers: 36, messages lost 473, duplicates 0, oos 0, busOff 0
        1. Please upgrade to beta4. Your M122 report shows beta3.2, but beta4 is now current.
        2. If the startup problem (tool board not getting initialised) persists when using beta4, please try adding a G4 S1 command in config.g before the first command that refers to the tool board, to give the tool board more time to start up after receiving power.
        3. If you get another uncommanded reset of the tool board when running beta4, please post the M122 report again.
        Stephen6309undefined 2 Replies Last reply Reply Quote 0
          Stephen6309 @dc42
          @dc42 Finally installed beta4, didn't see that the 1LC had to be updated first. Did an emergency stop, H1 would fail while heating up to 220C. Added the G4 S1 before the extruder stepper define. Did the edit reset and it still took an emergency stop for H1 to heatup to 200C. Will update if it still happens on the next cold startup.
            Stephen6309 @dc42
            @dc42 Fired up today, it's failing to get H1 to 220C, then 2000C and parts cooling fan goes to 100%.
            Replaced thermister, no change.
            Running parts cooling fan off of 24vdc. + of Power In connector, ground to out2. Also, the parts cooling fan would start running again after boot was finished.
            So I changed the parts cooling fan back to 12v off out2. H1 now heats up fine on initial boot.
            Looks like a 24v connection doesn't work. Since you can run lower voltage fans with separate power supply with a common ground. I figured it would work for a 24v fan on the Toolboard 1LC. Somehow the ground of out2 connection doesn't like to ground 24v.
            Stephen6309undefined 1 Reply Last reply Reply Quote 0
              Stephen6309 @Stephen6309
              After a shutdown, reinstalling the extruder assembly back on the printer. Fired it up and it still can get to 220C, no errors.
