    looking for latest firmware . been out of loop a while .
    Firmware installation
    • gurusonwheelsundefined
      gurusonwheels
      looking for the latest firmware for my machine . been out of the loop a few years .
      Stephen6309undefined 1 Reply Last reply Reply Quote 0
      • dhusoloundefined
        dhusolo
        https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview
          Here's a post I wrote for someone upgrading from 1.20 as well. It may serve you well.
          https://forum.duet3d.com/topic/19305/duet-2-wifi-with-gigabot-thermocouple-issue/4?_=1607311861434
          • Stephen6309undefined
            Stephen6309 @gurusonwheels
            @gurusonwheels Firmware 2.05.1 is the latest for the 1.xx firmware. Also, read all the what's new readme files for all versions since 1.2 for any changes you need.
            See page two of https://github.com/Duet3D/RepRapFirmware/releases?after=3.01-RC11 to get 2.05.1
            To use 3.xx you have to change the config.g. It changed how the pins are defined.
            To help making the config.g file see: https://configtool.reprapfirmware.org/Start
            • Vetiundefined
              Veti
              post your original config.g here.
              then start entering the details in the configurator and generate a new config.
              then post that here so we can check for you
