    WiFi connection issues
    Duet Web Control
    • Fredric92undefined
      Fredric92
      Duet 2
      Hello, everyone
      My question is, I've got some WiFi connection problems. Well, that's that. The connection lasts for only 20 minutes, after which you need to reconnect in a new way. This has never happened before. Although we recently installed remote employee monitoring, we are sure it isn't the problem because we've tried to uninstall the program or disable it - nothing changed. There are no problems with WiFi itself, no problems with connecting via a USB cable either. How do I reset my WiFi settings? Or what would you advise me to do in this situation?
      p.s. sorry for my English
        Please provide the results of M122 so we can see the firmware version, wifi version, and signal strength. Also post your config.g
        You can try clearing the saved SSID list with M588 S"*" and then re-adding your network again with M587. https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M587_Add_WiFi_host_network_to_remembered_list_or_list_remembered_networks
        One way to test if the wifi module is the problem or if it's your wifi router you can set the duet to access point mode where it creates a network and you join it. If that connection is stable, then it's likely something going on with your router, either interference, or an incompatibility.
        https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M589_Configure_access_point_parameters
          @Gerfa Start a new thread for your issue and include details on your setup.
