    New experimental firmware 1.19beta7
    Firmware installation
    3.4k
    • MrBlomundefined
      MrBlom
      The G10 z offset seam to be working fine
      have done a cuple of prints and it uses the offset
      new for me is some random disconnects and js erros like this
      A JavaScript error has occurred so the web interface has closed the connection to your board. It is recommended to reload the web interface now. If this happens again, please contact the author and share this error message:
      Message: Uncaught SyntaxError: Unexpected token A in JSON at position 113
      URL: http://192.168.1.130/
      Line: 3:1
      Error object: {}"
      any how thanks for the update and keed up the good work !
      • Forgvn77undefined
        Forgvn77
        I also have had problems with WiFi not reconnecting after a modification to config.g or even when power cycling the DuetWiFi. Many times the PanelDue will report "Connected" and then a minute or two later, "Wifi module is idle". Additional attempts to get it to connect eventually work.
        Velleman K8200, Geeetech G2S Pro (x2), Geeetech Rostock 301 retrofitted with Duet
        Make A Difference!
        • MrBlomundefined
          MrBlom
          i get this
          http://192.168.1.130/rr_download?name=0:/sys/oem.json 404 (not found)
          can i verify that oem.json exist from the web gui?
            @MrBlom:
            i get this
            I presume you are using either Wireshark or a debugging console to see that message. That file should not be present on normal installations, it is an optional component used by one of our OEMs to modify the interface presented by DWC.
            • MrBlomundefined
              MrBlom
              Hello
              i look at the requests sent / resived in google chrome dev tools
              just trying to figur out whats happening when the diconnect appers
              ok then i will not try to finde the oem file 🙂
              a sugestion is to shorten the variabel names in the response coming back to the ui
              it looks like 50% or more is just variable names
              shorten them and it will send less data
              Thanks for a fast reply
              • Neotkoundefined
                Neotko
                Just wanted to share a weird thing happened to me.
                I installed this beta, and after not being able to connect it to my wifi network I did downgrade it to the latest 1.18
                Weird thing is that now the network wifi always works, not even one ajax error for a week and a half. I thought was my imagination so I been testing and testing and is rock steady stable now. The only difference between before and now is that I changed thr name of the printer to all caps, so I highly doubt that made the difference.
                So in my experience updating to 1.19 and downgrading made all my ajax connect issues go away. Weird. Could just be the all caps name? Or maybe is there's something on the 1.19 wifi upgrade that doesn't go away by downgrading to 1.18?
                Anyhow I couldn't be happier with how much stable the printer connection is now.
                  Did you follow the instructions at https://duet3d.com/wiki/DuetWiFiFirmware_1.19beta to get connected when you installed the beta?
                  Were you definitely running DuetWiFiServer 1.03ch before you changed to the beta? If not then you may have ended up with a later version of DuetWiFiServer than you started with.
                  • Neotkoundefined
                    Neotko
                    This is what I have now
                    • MrBlomundefined
                      MrBlom
                      Hade to go back to
                      Firmware Version: 1.19beta6 (2017-06-10)
                      WiFi Server Version: 1.19-beta1
                      Web Interface Version: 1.16
                      the discconects was to mush even whit low pool settings
                        Please explain what you mean by "low pool settings".
                        • MrBlomundefined
                          MrBlom
                          Sorry for the bad English.
                          There is some settings for the times to retry,reconnet, pull not pool
                          It shuld say "slower update intervall"
