    Web interface access issue
    Duet Web Control
    • Stockerbotundefined
      Stockerbot
      This just came up as I was trying to add my configuration file to the Duet for my printer. Prior to that, I was connected and didn't have any issues.
      I confirmed the wifi card is on and connected to an IP address. When I enter the IP address in my browser I receive this error:
      Your Duet rejected the HTTP request: page not found
      Check that the SD card is mounted and has the correct files in its /www folder
      I have checked the folder and it looks like the files are accurate in there. I'm not sure what else might be causing the issue. Anyone run into this before? From what I can tell I'm not missing any files on the card so I'm at a total loss.
      Thanks in advance!!
      • Vetiundefined
        Veti
        what url are you accessing?
        what firmware are you running?
        what dwc where you running?
        just for test, take out the sd card remove all files from the www folder and extract the content of the corresponding dwc there.
        also run a file system check
