    3.2-RC2 DSF error in if statement
    Beta Firmware
    453
    • chrishammundefined
      chrishamm administrators
      I'm sorry but I'm having trouble reproducing this problem. I created a new sensor pin on my setup and call abort only if a given condition is met (a GPIO value like in your macro). This check cancels the running macro files only if the condition is true. Can you please provide a generic macro file to reproduce this problem? Also, can you confirm that the axes are always homed before G53 G0 is called? If any axes are unhomed at that point, G0/G1 will abort the running files too.
      Duet software engineer
      TypQxQundefined 1 Reply Last reply Reply Quote 0
      • TypQxQundefined
        TypQxQ @chrishamm
        @chrishamm I am also having a hard time with this but I have a feeling it is from the execution order of nested and macros on multiple levels. Having problems elsewhere too. I am trying to make a generic macro.
          chrishamm administrators @TypQxQ
          @TypQxQ I haven't observed a similar problem on other machines either so I wonder if it's a problem with your particular macro. Perhaps you check the sensor when movement hasn't finished? Try running M400 before you check the sensor state.
          • TypQxQundefined
            TypQxQ @chrishamm
            TstNest-1.g TstNest-0.g @chrishamm said in 3.2-RC2 DSF error in if statement:
            I do use M400 in the code above.
            I have commented out all moves and it almost always crashes, but not always. The attached code crashes most of the time.
            Sometimes it crashes more often if run in quick succession but not if called quickly from another macro multiple times.
            If I remove the commented lines or I comment out the M98 lines it will also run fine. Could it be something inside the macro parsing code?
            [debug] Completed ;G53 G0 X580 F6000       			; Wipe Backwards, and move away from other tools, incase next move is Y only.
            [debug] Completed ;G0 X500 F30000       				; Wipe Backwards, and move away from other tools, incase next move is Y only. (To tool coordinates)
            [info] Aborted macro file 0:/macros/TstNest-0.g
            [debug] Cancelled ; Check so the tool is mounted steady.
               System.Threading.Tasks.TaskCanceledException: A task was canceled.
               at DuetControlServer.Commands.Code.Process() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/Commands/Generic/Code.cs:line 432
               at DuetControlServer.Commands.Code.ExecuteInternally() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/Commands/Generic/Code.cs:line 350
            [debug] Cancelled M582 T4
               at DuetControlServer.Commands.Code.Process() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/Commands/Generic/Code.cs:line 456
            [debug] Completed M400 ; Wait for current moves to finish
            I attach the code as files downloaded from the DWC so nothing is lost in case some obscure sign I can't find messes things up.
            TstNest-0.g
            TstNest-1.g
            trigger4.g
              @TypQxQ said in 3.2-RC2 DSF error in if statement:
              [debug] HTTP: Sent G53 G0 X500 Y515 F20000 ; Rapid to the approach position with tool-0. (park_x, park_y - offset). Y next to make a square move. , remaining space 1488, needed 48
              Right at the beginning of the first macro you shared in your main post I cannot see an M400 before the if-clause but it may be unrelated. It's hard to believe that codes could be still executed in the wrong order but DSF might swallow an error message from G0 (that's the last code sent to RRF before the files are aborted). Can you try to connect a USB serial console to the Duet and check for potential error messages that do not show up via DWC/DSF?
              • TypQxQundefined
                TypQxQ
                The code I shared always runs until the second if-clause. It is there the code sometimes stops.
                I've activated serial debug:
                Debugging enabled for modules: Platform(0) GCodes(3) Move(4) PrintMonitor(9) PortControl(11) DuetExpansion(12) LinuxInterface(16)
                Debugging disabled for modules: Network(1) Webserver(2) Heat(5) DDA(6) Roland(7) Scanner(8) Storage(10) FilamentSensors(13) WiFi(14) Display(15) CAN(17)
                Successfull run of macro:
                Requesting non-blocking macro file 'daemon.g' (fromCode: false)
                Macro completed on channel 9
                HTTP: M98 P"0:/macros/TstNest-0.g"
                Requesting macro file '0:/macros/TstNest-0.g' (fromCode: true)
                HTTP: M950 J3 C"0.io3.in"
                HTTP: M581 P3 T4 S1
                HTTP: G91
                HTTP: G90
                HTTP: M558 P8 C"1.io2.in" F250 H5 T24000 A2 S0.020000
                HTTP: G31 Z-1
                HTTP: M400
                HTTP: M98 P"/macros/TstNest-1.g"
                Requesting macro file '/macros/TstNest-1.g' (fromCode: true)
                HTTP: M950 J14 C"nil"
                Macro completed on channel 0
                HTTP: M400
                HTTP: M582 T4
                Requesting macro file 'trigger4.g' (fromCode: false)
                Trigger: M118 S"Carriage coupling failed!"
                Macro completed on channel 5
                HTTP: M118 S"Value checked and outside if"
                HTTP: M208 X500
                And a unsuccessfull one right after (no moves or other changes inbetween):
                HTTP: M581 P3 T4 S1
                HTTP: G91
                HTTP: G90
                HTTP: G31 Z-1
                HTTP: M400
                HTTP: M400
                HTTP: M582 T4
                Because the scripts checks for a open endstop and has no moves you can try it on any board.
                And my Status:
                RepRapFirmware for Duet 3 MB6HC version 3.2-RC2 running on Duet 3 MB6HC v0.6 or 1.0 (SBC mode)
                Board ID: 08DJM-956L2-G43S4-6JKDD-3SJ6L-TB62G
                Used output buffers: 1 of 40 (17 max)
                Static ram: 149788
                Dynamic ram: 65076 of which 124 recycled
                Never used RAM 143844, free system stack 126 words
                Tasks: Linux(blocked,79) HEAT(blocked,277) CanReceiv(blocked,801) CanSender(blocked,346) CanClock(blocked,352) TMC(blocked,19) MAIN(running,720) IDLE(ready,19)
                Owned mutexes: HTTP(MAIN)
                Last reset 09:18:44 ago, cause: software
                Last software reset at 2020-12-30 22:04, reason: User, none spinning, available RAM 144312, slot 0
                Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task Linu Freestk 0 n/a
                Error status: 0x00
                Aux0 errors 0,0,0
                Aux1 errors 0,0,0
                MCU temperature: min 44.3, current 44.5, max 46.0
                Supply voltage: min 31.9, current 31.9, max 32.0, under voltage events: 0, over voltage events: 0, power good: yes
                12V rail voltage: min 12.0, current 12.0, max 12.1, under voltage events: 0
                Driver 0: position 176657, standstill, reads 55500, writes 0 timeouts 0, SG min/max not available
                Driver 1: position 12028, standstill, reads 55500, writes 0 timeouts 0, SG min/max not available
                Driver 2: position 12800, standstill, reads 55499, writes 0 timeouts 0, SG min/max not available
                Driver 3: position 0, standstill, reads 55499, writes 0 timeouts 0, SG min/max not available
                Driver 4: position 0, standstill, reads 55500, writes 0 timeouts 0, SG min/max not available
                Driver 5: position 0, standstill, reads 55500, writes 0 timeouts 0, SG min/max not available
                Date/time: 2020-12-31 07:22:56
                Slowest loop: 92.19ms; fastest: 0.08ms
                === Storage ===
                Free file entries: 10
                DMs created 125, maxWait 0ms, bed compensation in use: mesh, comp offset 0.000
                === MainDDARing ===
                Scheduled moves 103, completed moves 103, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                === AuxDDARing ===
                Segments left: 0
                Movement lock held by null
                Telnet is idle in state(s) 0
                File is idle in state(s) 0
                USB is idle in state(s) 0
                Aux is idle in state(s) 0
                Queue is idle in state(s) 0
                LCD is idle in state(s) 0
                SBC is idle in state(s) 0
                Daemon is idle in state(s) 0
                Aux2 is idle in state(s) 0
                Code queue is empty.
                === CAN ===
                Messages queued 5914, send timeouts 0, received 17726, lost 0, longest wait 1ms for reply type 6036, free buffers 48
                === SBC interface ===
                State: 4, failed transfers: 0
                Last transfer: 1ms ago
                RX/TX seq numbers: 18008/18008
                SPI underruns 0, overruns 0
                Number of disconnects: 1, IAP RAM available 0x2c85c
                Buffer RX/TX: 0/0-0
                === Duet Control Server ===
                Duet Control Server v3.2.0-rc2
                Code buffer space: 4096
                Full transfers per second: 35.66
                Maximum length of RX/TX data transfers: 3464/292
                  Interesting, thanks again for the logs. Can you check if return terminates the current macro file as expected?
                  • TypQxQundefined
                    TypQxQ @chrishamm
                    @chrishamm I couldn't find a reference to the return command but I put it last in the if construct:
                    if sensors.gpIn[3].value!=0
                      echo "value not 0"
                      return
                    else
                      echo "else here"
                    In the first one it has no effect on the code but on the other one I get
                    Error: Failed to evaluate "": expected an expression of TstNest-0.g
                    But not always. When it does throw the exception it looks like this:
                    [debug] IPC#29: Got new UNIX connection, checking permissions...
                    [debug] IPC#29: Granting full DSF permissions to external plugin
                    [debug] IPC#29: Command processor added
                    [debug] IPC#29: Received command SimpleCode
                    [debug] Waiting for execution of M98 P"0:/macros/TstNest-0.g"
                    [debug] Processing M98 P"0:/macros/TstNest-0.g"
                    [debug] Waiting for finish of M98 P"0:/macros/TstNest-0.g"
                    [debug] HTTP: Sent M98 P"0:/macros/TstNest-0.g", remaining space 1480, needed 56
                    [info] Starting macro file 0:/macros/TstNest-0.g on channel HTTP
                    [debug] Waiting for execution of M950 J3 C"0.io3.in" ; Use the input pin on io3 on the main board as carriage coupling check. (macro code)
                    [debug] Waiting for execution of M581 P3 T4 S1 ; Use triggers as info.(Run Trigger4.g) (macro code)
                    [debug] Waiting for execution of ; Mounting (macro code)
                    [debug] Waiting for execution of ; runs after firmware thinks Tool49 is selected (macro code)
                    [debug] Waiting for execution of ; Note: tool offsets are applied at this point! (macro code)
                    [debug] Waiting for execution of ; Note that commands prefixed with G53 will NOT apply the tool offset. (macro code)
                    [debug] Waiting for execution of ; Check so no tool is mounted before trying to mount one. (macro code)
                    [debug] HTTP: ==> Starting code M98 P"0:/macros/TstNest-0.g"
                    [debug] Processing M950 J3 C"0.io3.in" ; Use the input pin on io3 on the main board as carriage coupling check.
                    [debug] Waiting for finish of M950 J3 C"0.io3.in" ; Use the input pin on io3 on the main board as carriage coupling check.
                    [debug] Processing M581 P3 T4 S1 ; Use triggers as info.(Run Trigger4.g)
                    [debug] Waiting for finish of M581 P3 T4 S1 ; Use triggers as info.(Run Trigger4.g)
                    [debug] Processing ; Mounting
                    [debug] Waiting for finish of ; Mounting
                    [debug] Processing ; runs after firmware thinks Tool49 is selected
                    [debug] Waiting for finish of ; runs after firmware thinks Tool49 is selected
                    [debug] Processing ; Note: tool offsets are applied at this point!
                    [debug] Waiting for finish of ; Note: tool offsets are applied at this point!
                    [debug] Processing ; Note that commands prefixed with G53 will NOT apply the tool offset.
                    [debug] Waiting for finish of ; Note that commands prefixed with G53 will NOT apply the tool offset.
                    [debug] Processing ; Check so no tool is mounted before trying to mount one.
                    [debug] Waiting for finish of ; Check so no tool is mounted before trying to mount one.
                    [debug] HTTP: Sent M950 J3 C"0.io3.in" ; Use the input pin on io3 on the main board as carriage coupling check., remaining space 1488, needed 48
                    [debug] HTTP: Sent M581 P3 T4 S1 ; Use triggers as info.(Run Trigger4.g), remaining space 1440, needed 48
                    [debug] Completed M950 J3 C"0.io3.in" ; Use the input pin on io3 on the main board as carriage coupling check.
                    [debug] Completed ; Mounting
                    [debug] Completed M581 P3 T4 S1 ; Use triggers as info.(Run Trigger4.g)
                    [debug] Completed ; runs after firmware thinks Tool49 is selected
                    [debug] Completed ; Note that commands prefixed with G53 will NOT apply the tool offset.
                    [debug] Completed ; Note: tool offsets are applied at this point!
                    [debug] Completed ; Check so no tool is mounted before trying to mount one.
                    [debug] Evaluating If block
                    [debug] Evaluating 3 on channel HTTP
                    [debug] Evaluating sensors.gpIn[3].value!=1 on channel HTTP
                    [debug] Evaluation result: (sensors.gpIn[3].value!=1) = False
                    [debug] End of If block
                    [debug] Waiting for execution of G91 ; relative positioning (macro code)
                    [debug] Waiting for execution of ;G1 H2 Z+5 F6000				; Lift z so we don't crash (macro code)
                    [debug] Processing G91 ; relative positioning
                    [debug] Waiting for execution of G90 ; Return to absolute (macro code)
                    [debug] Waiting for finish of G91 ; relative positioning
                    [debug] Waiting for execution of ; Set Z Probe settings (macro code)
                    [debug] Processing ;G1 H2 Z+5 F6000				; Lift z so we don't crash
                    [debug] Waiting for finish of ;G1 H2 Z+5 F6000				; Lift z so we don't crash
                    [debug] Waiting for execution of M558 P8 C"1.io2.in" F250 H5 T24000 A2 S0.02 ; Set the pin of Z probe (macro code)
                    [debug] Processing G90 ; Return to absolute
                    [debug] Waiting for execution of G31 Z-1 ; Set probe height as -1 so 0 is 1mm below the probe (macro code)
                    [debug] Waiting for finish of G90 ; Return to absolute
                    [debug] Waiting for execution of M400 ; Wait for current moves to finish (macro code)
                    [debug] Processing ; Set Z Probe settings
                    [debug] Waiting for execution of ;M208 X600							; Set axis software limits and min/max switch-triggering positions. Extended with tools (macro code)
                    [debug] Waiting for finish of ; Set Z Probe settings
                    [debug] Waiting for execution of M98 P"/macros/TstNest-1.g" ; Don't use the X max as EmergencyStop. (macro code)
                    [debug] Processing M558 P8 C"1.io2.in" F250 H5 T24000 A2 S0.02 ; Set the pin of Z probe
                    [debug] Waiting for execution of ;G53 G0 X500	Y515 F20000       		; Rapid to the approach position with tool-0. (park_x, park_y - offset).  Y next to make a square move.  (macro code)
                    [debug] Waiting for finish of M558 P8 C"1.io2.in" F250 H5 T24000 A2 S0.02 ; Set the pin of Z probe
                    [debug] Waiting for execution of ;G53 G0 X590 F30000       			; Fast Move to the pickup position with tool. (macro code)
                    [debug] Processing G31 Z-1 ; Set probe height as -1 so 0 is 1mm below the probe
                    [debug] Waiting for execution of ;G53 G0 X598 F3000        			; Slow Move to the pickup position with tool-0. (macro code)
                    [debug] Waiting for finish of G31 Z-1 ; Set probe height as -1 so 0 is 1mm below the probe
                    [debug] Waiting for execution of ;Lock the tool (macro code)
                    [debug] Processing M400 ; Wait for current moves to finish
                    [debug] Waiting for execution of ;M98 P"/sys/custom/tool_lock.g" 		; Lock the tool (macro code)
                    [debug] Waiting for finish of M400 ; Wait for current moves to finish
                    [debug] Waiting for execution of ; Move nozzle to purge area (macro code)
                    [debug] Processing ;M208 X600							; Set axis software limits and min/max switch-triggering positions. Extended with tools
                    [debug] Waiting for execution of ;G53 G0 X580 F6000       			; Wipe Backwards, and move away from other tools, incase next move is Y only.  (macro code)
                    [debug] Waiting for finish of ;M208 X600							; Set axis software limits and min/max switch-triggering positions. Extended with tools
                    [debug] HTTP: Sent G91 ; relative positioning, remaining space 1512, needed 24
                    [debug] HTTP: Sent G90 ; Return to absolute, remaining space 1488, needed 24
                    [debug] Processing M98 P"/macros/TstNest-1.g" ; Don't use the X max as EmergencyStop.
                    [debug] HTTP: Sent M558 P8 C"1.io2.in" F250 H5 T24000 A2 S0.02 ; Set the pin of Z probe, remaining space 1400, needed 88
                    [debug] HTTP: Sent G31 Z-1 ; Set probe height as -1 so 0 is 1mm below the probe, remaining space 1368, needed 32
                    [debug] HTTP: Sent M400 ; Wait for current moves to finish, remaining space 1344, needed 24
                    [debug] Waiting for finish of M98 P"/macros/TstNest-1.g" ; Don't use the X max as EmergencyStop.
                    [debug] Processing ;G53 G0 X500	Y515 F20000       		; Rapid to the approach position with tool-0. (park_x, park_y - offset).  Y next to make a square move.
                    [debug] Waiting for finish of ;G53 G0 X500	Y515 F20000       		; Rapid to the approach position with tool-0. (park_x, park_y - offset).  Y next to make a square move.
                    [debug] Processing ;G53 G0 X590 F30000       			; Fast Move to the pickup position with tool.
                    [debug] Waiting for finish of ;G53 G0 X590 F30000       			; Fast Move to the pickup position with tool.
                    [debug] HTTP: Sent M98 P"/macros/TstNest-1.g" ; Don't use the X max as EmergencyStop., remaining space 1292, needed 52
                    [debug] Processing ;G53 G0 X598 F3000        			; Slow Move to the pickup position with tool-0.
                    [debug] Waiting for finish of ;G53 G0 X598 F3000        			; Slow Move to the pickup position with tool-0.
                    [debug] Processing ;Lock the tool
                    [debug] Waiting for finish of ;Lock the tool
                    [debug] Processing ;M98 P"/sys/custom/tool_lock.g" 		; Lock the tool
                    [debug] Waiting for finish of ;M98 P"/sys/custom/tool_lock.g" 		; Lock the tool
                    [debug] Processing ; Move nozzle to purge area
                    [debug] Waiting for finish of ; Move nozzle to purge area
                    [debug] Processing ;G53 G0 X580 F6000       			; Wipe Backwards, and move away from other tools, incase next move is Y only.
                    [debug] Waiting for finish of ;G53 G0 X580 F6000       			; Wipe Backwards, and move away from other tools, incase next move is Y only.
                    [debug] Completed G91 ; relative positioning
                    [debug] Completed ;G1 H2 Z+5 F6000				; Lift z so we don't crash
                    [debug] Completed G90 ; Return to absolute
                    [debug] Completed ; Set Z Probe settings
                    [debug] Waiting for execution of ;G0 X500 F30000       				; Wipe Backwards, and move away from other tools, incase next move is Y only. (To tool coordinates) (macro code)
                    [debug] Waiting for execution of M582 T4 (macro code)
                    [debug] Processing ;G0 X500 F30000       				; Wipe Backwards, and move away from other tools, incase next move is Y only. (To tool coordinates)
                    [debug] Waiting for execution of ; Check so the tool is mounted steady. (macro code)
                    [debug] Waiting for finish of ;G0 X500 F30000       				; Wipe Backwards, and move away from other tools, incase next move is Y only. (To tool coordinates)
                    [debug] Completed M558 P8 C"1.io2.in" F250 H5 T24000 A2 S0.02 ; Set the pin of Z probe
                    [debug] Waiting for execution of echo sensors.gpIn[3].value (macro code)
                    [debug] Completed G31 Z-1 ; Set probe height as -1 so 0 is 1mm below the probe
                    [debug] Processing M582 T4
                    [debug] Waiting for finish of M582 T4
                    [debug] Completed ;M208 X600							; Set axis software limits and min/max switch-triggering positions. Extended with tools
                    [debug] Processing ; Check so the tool is mounted steady.
                    [debug] Waiting for finish of ; Check so the tool is mounted steady.
                    [debug] Processing echo sensors.gpIn[3].value
                    [info] Starting macro file /macros/TstNest-1.g on channel HTTP
                    [debug] HTTP: ==> Starting code M98 P"/macros/TstNest-1.g" ; Don't use the X max as EmergencyStop.
                    [debug] Waiting for execution of M950 J14 C"nil" ; Don't use the input pin on io4 on the exp1 board as X max. (macro code)
                    [debug] Processing M950 J14 C"nil" ; Don't use the input pin on io4 on the exp1 board as X max.
                    [debug] Requesting update of key inputs, seq 311 -> 312
                    [debug] Waiting for finish of M950 J14 C"nil" ; Don't use the input pin on io4 on the exp1 board as X max.
                    [debug] HTTP: Sent M950 J14 C"nil" ; Don't use the input pin on io4 on the exp1 board as X max., remaining space 1492, needed 44
                    [debug] Completed M950 J14 C"nil" ; Don't use the input pin on io4 on the exp1 board as X max.
                    [debug] Finished codes from macro file /macros/TstNest-1.g
                    [info] Finished macro file /macros/TstNest-1.g
                    [debug] Updated key inputs
                    [debug] Requesting update of key sensors, seq 250 -> 252
                    [debug] HTTP: ==> Unfinished starting code: M98 P"/macros/TstNest-1.g" ; Don't use the X max as EmergencyStop.
                    [debug] HTTP: Disposing macro file /macros/TstNest-1.g
                    [debug] HTTP: Sent M400 ; Wait for current moves to finish, remaining space 1516, needed 20
                    [debug] Updated key sensors
                    [debug] Completed M98 P"/macros/TstNest-1.g" ; Don't use the X max as EmergencyStop.
                    [debug] HTTP: Sent M582 T4, remaining space 1488, needed 28
                    [debug] Completed ;G53 G0 X500	Y515 F20000       		; Rapid to the approach position with tool-0. (park_x, park_y - offset).  Y next to make a square move.
                    [debug] Completed ;G53 G0 X590 F30000       			; Fast Move to the pickup position with tool.
                    [debug] Completed ;G53 G0 X598 F3000        			; Slow Move to the pickup position with tool-0.
                    [debug] Completed ;Lock the tool
                    [debug] Completed ;M98 P"/sys/custom/tool_lock.g" 		; Lock the tool
                    [debug] Completed ; Move nozzle to purge area
                    [debug] Completed M582 T4
                    [debug] Completed ; Check so the tool is mounted steady.
                    [info] Starting macro file trigger4.g on channel Trigger
                    [debug] Waiting for execution of M118 S"Carriage coupling failed!" (macro code)
                    [debug] Processing M118 S"Carriage coupling failed!"
                    [debug] Waiting for execution of ;M118 S"Carriage coupling failed!!!!" L1 (macro code)
                    [debug] Waiting for finish of M118 S"Carriage coupling failed!"
                    [debug] Trigger: Sent M118 S"Carriage coupling failed!", remaining space 1476, needed 60
                    [debug] Processing ;M118 S"Carriage coupling failed!!!!" L1
                    [debug] Waiting for finish of ;M118 S"Carriage coupling failed!!!!" L1
                    [debug] Evaluating sensors.gpIn[3].value on channel HTTP
                    [info] Carriage coupling failed!
                    [debug] Completed ;M118 S"Carriage coupling failed!!!!" L1
                    [debug] Completed M118 S"Carriage coupling failed!"
                    [debug] Finished codes from macro file trigger4.g
                    [info] Finished macro file trigger4.g
                    [debug] Waiting for finish of echo sensors.gpIn[3].value
                    [debug] Completed echo sensors.gpIn[3].value
                    [debug] Trigger: Disposing macro file trigger4.g
                    [debug] Evaluating sensors.gpIn[3].value!=0 on channel HTTP
                    [debug] Evaluation result: (sensors.gpIn[3].value!=0) = True
                    [debug] Waiting for execution of echo "value not 0" (macro code)
                    [debug] Doing Return
                    [debug] Processing echo "value not 0"
                    [debug] Waiting for execution of return  (macro code)
                    [debug] Evaluating "value not 0" on channel HTTP
                    [debug] Waiting for finish of echo "value not 0"
                    [debug] Completed echo "value not 0"
                    [debug] Processing return
                    [debug] Evaluating  on channel HTTP
                    [debug] Requesting update of key inputs, seq 312 -> 313
                    [error] Code return  has thrown an exception
                       DuetAPI.Commands.CodeParserException: Failed to evaluate "": expected an expression
                     ---> DuetAPI.Commands.CodeParserException: expected an expression
                       at DuetControlServer.Model.Expressions.EvaluateSubExpression(Code code, String expression, Boolean onlyLinuxFields, Boolean encodeResult) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/Model/Expressions.cs:line 574
                       at DuetControlServer.Model.Expressions.EvaluateExpression(Code code, String expression, Boolean onlyLinuxFields, Boolean encodeResult) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/Model/Expressions.cs:line 426
                       at DuetControlServer.Model.Expressions.Evaluate(Code code, Boolean evaluateAll) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/Model/Expressions.cs:line 288
                       --- End of inner exception stack trace ---
                       at DuetControlServer.Model.Expressions.Evaluate(Code code, Boolean evaluateAll) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/Model/Expressions.cs:line 293
                       at DuetControlServer.Commands.Code.ProcessInternally() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/Commands/Generic/Code.cs:line 539
                       at DuetControlServer.Commands.Code.Process() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/Commands/Generic/Code.cs:line 429
                    [error] Failed to evaluate "": expected an expression of TstNest-0.g
                    [debug] DuetAPI.Commands.CodeParserException: Failed to evaluate "": expected an expression
                       at DuetControlServer.Commands.Code.ExecuteInternally() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/Commands/Generic/Code.cs:line 403
                       at DuetControlServer.Commands.Code.<Execute>b__27_0(Task`1 task) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/Commands/Generic/Code.cs:line 289
                       at DuetControlServer.FileExecution.Macro.Run() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/FileExecution/Macro.cs:line 336
                    [debug] Finished codes from macro file 0:/macros/TstNest-0.g
                    [debug] HTTP: ==> Unfinished starting code: M98 P"0:/macros/TstNest-0.g"
                    [debug] HTTP: Disposing macro file 0:/macros/TstNest-0.g
                    [debug] Completed M98 P"0:/macros/TstNest-0.g" => 1
                    value not 0
                    [debug] IPC#29: Connection closed
                    [debug] IPC#30: Got new UNIX connection, checking permissions...
                    [debug] IPC#30: Granting full DSF permissions to external plugin
                    [debug] IPC#30: Command processor added
                    [debug] IPC#30: Received command ResolvePath
                    [debug] IPC#30: Connection closed
                    Hope this helps and Happy New Year 🍾
                      @TypQxQ Thanks and happy new year! I've got a fix ready for those issues.
                      • TypQxQundefined
                        TypQxQ
                        I updated to the stable 3.2 release of today but unfortunately it still doesn't work.
                        [debug] IPC#50: Got new UNIX connection, checking permissions...
                        [debug] IPC#50: Granting full DSF permissions to external plugin
                        [debug] IPC#50: Command processor added
                        [debug] IPC#50: Received command SimpleCode
                        [debug] Requesting update of key inputs, seq 40 -> 41
                        [debug] Requesting update of key sensors, seq 37 -> 39
                        [debug] HTTP: Sent M400 ; Wait for current moves to finish, remaining space 1512, needed 24
                        [debug] HTTP: Sent M582 T4, remaining space 1480, needed 32
                        [debug] IPC#50: Connection closed
                        [debug] Requesting update of key inputs, seq 41 -> 42
                          @TypQxQ Please revert to the original macros that you shared in your first post and make sure that M122 outputs version 3.2 for both the firmware and DCS. The general order looks OK to me but I cannot see any good reason why the codes after M98 P"/macros/TstNest-1.g" are cancelled.
                          • TypQxQundefined
                            TypQxQ
                            I have reverted to the files I attached in my post from "31 Dec 2020, 00:24".
                            I had double checked the version. I couldn't attach debug info because the post exceeded the allowed length.
                            RepRapFirmware for Duet 3 MB6HC version 3.2 running on Duet 3 MB6HC v0.6 or 1.0 (SBC mode)
                            Used output buffers: 1 of 40 (15 max)
                            Static ram: 149788
                            Dynamic ram: 64700 of which 112 recycled
                            Never used RAM 144232, free system stack 154 words
                            Tasks: Linux(ready,71) HEAT(blocked,295) CanReceiv(blocked,801) CanSender(blocked,352) CanClock(blocked,352) TMC(blocked,53) MAIN(running,1120) IDLE(ready,19)
                            Last reset 01:36:39 ago, cause: software
                            Last software reset at 2021-01-05 21:57, reason: User, none spinning, available RAM 144336, slot 1
                            Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task Linu Freestk 0 n/a
                            Error status: 0x00
                            Aux0 errors 0,0,0
                            Aux1 errors 0,0,0
                            MCU temperature: min 39.4, current 39.8, max 40.4
                            Driver 0: position 0, standstill, reads 13972, writes 0 timeouts 0, SG min/max not available
                            Driver 1: position 0, standstill, reads 13972, writes 0 timeouts 0, SG min/max not available
                            Driver 2: position 0, standstill, reads 13972, writes 0 timeouts 0, SG min/max not available
                            Driver 3: position 0, standstill, reads 13972, writes 0 timeouts 0, SG min/max not available
                            Driver 4: position 0, standstill, reads 13972, writes 0 timeouts 0, SG min/max not available
                            Driver 5: position 0, standstill, reads 13972, writes 0 timeouts 0, SG min/max not available
                            Date/time: 2021-01-05 23:34:00
                            Slowest loop: 93.48ms; fastest: 0.06ms
                            === Storage ===
                            DMs created 125, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                            === MainDDARing ===
                            Scheduled moves 3, completed moves 3, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                            === AuxDDARing ===
                            Segments left: 0
                            === CAN ===
                            Messages queued 18738, send timeouts 0, received 56197, lost 0, longest wait 1ms for reply type 6036, free buffers 48
                            RX/TX seq numbers: 59729/59729
                            Number of disconnects: 2, IAP RAM available 0x2c8a8
                            Buffer RX/TX: 0/0-0
                            Full transfers per second: 35.62
                            Maximum length of RX/TX data transfers: 3364/292
                            pi@qTC:~ $ sudo /opt/dsf/bin/DuetControlServer -l debug
                            Written by Christian Hammacher for Duet3D
                            Licensed under the terms of the GNU Public License Version 3
                            If you run this code you can run the code above yourself and see.
