    G30 S-2 does not work in RRF3.2
    Beta Firmware
    1
    1
    201
    • Marco Bonaundefined
      Marco Bona
      Hi, as the title says after updating the G30 S-2 command to RRF3.2 it seems to me that it does not update the position.
      List what I tried to do:
      -I made first print and had to raise the Z by 0.4 with babystepping
      -I have corrected G31 Z value in config.g
      -I started printing again but had to correct Z of 0.4 again with babystepping.
      I believe that the G30 S-2 command at start of printing does not correct Z offset value.
      I also point out some warnings that appear when config.g is loaded:
      6/1/2021, 12:00:43	Warning: M307: Heater 3 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
      6/1/2021, 12:00:43	Warning: M307: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 686C
      6/1/2021, 12:00:43	Warning: M307: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 198C
      @dc42, I haven't tried to change the tool with this version yet, has the problem I exposed yesterday (https://forum.duet3d.com/topic/20721/tool-change-problem-think), been solved?
      If you can help attach the report
      m122
      RepRapFirmware for Duet 3 MB6HC version 3.2 running on Duet 3 MB6HC v0.6 or 1.0 (SBC mode)
      Board ID: 08DJM-956L2-G43S4-6JKF0-3S86T-9A5YD
      Used output buffers: 1 of 40 (28 max)
      Static ram: 149788
      Dynamic ram: 64176 of which 120 recycled
      Never used RAM 144748, free system stack 182 words
      Tasks: Linux(ready,77) HEAT(blocked,296) CanReceiv(blocked,813) CanSender(blocked,371) CanClock(blocked,352) TMC(blocked,50) MAIN(running,1145) IDLE(ready,19)
      Owned mutexes: HTTP(MAIN)
      Last reset 00:16:55 ago, cause: software
      Last software reset at 2021-01-06 12:00, reason: User, FilamentSensors spinning, available RAM 144056, slot 1
      Software reset code 0x000d HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task Linu Freestk 0 n/a
      Error status: 0x00
      Aux0 errors 0,0,0
      Aux1 errors 0,0,0
      MCU temperature: min 23.9, current 24.0, max 24.6
      Supply voltage: min 24.1, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0
      Driver 0: position 0, standstill, reads 32180, writes 19 timeouts 0, SG min/max 0/0
      Driver 1: position 0, standstill, reads 32180, writes 19 timeouts 0, SG min/max 0/0
      Driver 2: position 0, standstill, reads 32183, writes 17 timeouts 0, SG min/max 0/0
      Driver 3: position 0, standstill, reads 32182, writes 18 timeouts 0, SG min/max 0/0
      Driver 4: position 0, standstill, reads 32183, writes 17 timeouts 0, SG min/max 0/0
      Driver 5: position 0, standstill, reads 32183, writes 17 timeouts 0, SG min/max 0/0
      Date/time: 2021-01-06 12:17:33
      Slowest loop: 1.72ms; fastest: 0.05ms
      === Storage ===
      Free file entries: 10
      DMs created 125, maxWait 0ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      === AuxDDARing ===
      Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = 3 -1 -1 -1
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === CAN ===
      Messages queued 4071, send timeouts 0, received 12178, lost 0, longest wait 1ms for reply type 6042, free buffers 48
      === SBC interface ===
      State: 4, failed transfers: 0
      Last transfer: 1ms ago
      RX/TX seq numbers: 37808/37808
      SPI underruns 0, overruns 0
      Number of disconnects: 0, IAP RAM available 0x2c8a8
      Buffer RX/TX: 0/0-0
      === Duet Control Server ===
      Duet Control Server v3.2.0
      Code buffer space: 4096
      Full transfers per second: 37.28
      Maximum length of RX/TX data transfers: 5456/980
