    Questions on updating to latest 3.2 build
    Firmware installation
    332
    • dhusoloundefined
      dhusolo
      I recently updated from 3.2-b4. I used a new SD card instead of updating the old one due to various issues I've had the last few months. However for whatever reason DWC still shows as 3.2-b4. I have ran sudo apt-get update and sudo apt-get upgrade but it still shows as 3.2-b4
      Duet3
        Since you were previously running a beta of 3.2, you must have been using the unstable package server. Did you follow the instructions for updating from the release notes?
        Users running an unstable firmware version (for example, any 3.2beta or 3.2RC version) on Duet + SBC, run sudo apt-get update followed by sudo apt-get upgrade duetsoftwareframework=3.2.0 duetcontrolserver=3.2.0 duetwebserver=3.2.0 duettools=3.2.0 duetruntime=3.2.0 duetsd=1.1.0 duetwebcontrol=3.2.0 reprapfirmware=3.2.0-1
        https://github.com/Duet3D/RepRapFirmware/releases/tag/3.2
        • dhusoloundefined
          dhusolo
          I thought about that and before upgrading I was using the unstable package server. But considering I used a different SD and wrote a new Duetpi image to the card I thought that would be irrelevant.
            The Duet3 still has the old firmware flashed.
            Try sending M997 to trigger a firmware update.
            • dhusoloundefined
              dhusolo
              I ran M997 and it gives me the error
              1/16/2021, 8:44:02 AM Warning: Incompatible firmware, please upgrade as soon as possible
              1/16/2021, 8:44:01 AM Failed to upload dwc-settings.json
              Could not complete action because the connection has been terminated```
              m122
              RepRapFirmware for Duet 3 MB6HC version 3.2-beta4 running on Duet 3 MB6HC v1.01 or later (SBC mode)
              Board ID: 08DJM-956L2-G43S8-6J9D0-3S46T-9U2LF
              Used output buffers: 1 of 40 (10 max)
              Static ram: 123212
              Dynamic ram: 138176 of which 44 recycled
              Never used RAM 130760, free system stack 188 words
              Tasks: Linux(ready,75) HEAT(blocked,298) CanReceiv(blocked,947) CanSender(blocked,371) CanClock(blocked,352) TMC(blocked,52) MAIN(running,1179) IDLE(ready,19)
              Owned mutexes: HTTP(MAIN)
              Last reset 00:00:39 ago, cause: software
              Last software reset at 2021-01-15 22:58, reason: User, none spinning, available RAM 132440, slot 2
              Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0xffffffff Task Linu
              Error status: 0x00
              MCU temperature: min 24.2, current 25.6, max 25.8
              Supply voltage: min 24.6, current 24.6, max 24.7, under voltage events: 0, over voltage events: 0, power good: yes
              12V rail voltage: min 12.1, current 12.1, max 12.1, under voltage events: 0
              Driver 0: position 0, standstill, reads 62325, writes 14 timeouts 0, SG min/max 0/0
              Driver 1: position 0, standstill, reads 62326, writes 14 timeouts 0, SG min/max 0/0
              Driver 2: position 0, standstill, reads 62326, writes 14 timeouts 0, SG min/max 0/0
              Driver 3: position 0, standstill, reads 62327, writes 14 timeouts 0, SG min/max 0/0
              Driver 4: position 0, standstill, reads 62328, writes 14 timeouts 0, SG min/max 0/0
              Driver 5: position 0, standstill, reads 62329, writes 14 timeouts 0, SG min/max 0/0
              Date/time: 2021-01-16 08:44:37
              Slowest loop: 2.52ms; fastest: 0.14ms
              === Storage ===
              Free file entries: 10
              === MainDDARing ===
              Scheduled moves 0, completed moves 0, StepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
              === AuxDDARing ===
              Segments left: 0
              Movement lock held by null
              Telnet is idle in state(s) 0
              File is idle in state(s) 0
              USB is idle in state(s) 0
              Aux is idle in state(s) 0
              Queue is idle in state(s) 0
              LCD is idle in state(s) 0
              SBC is idle in state(s) 0
              Daemon is idle in state(s) 0
              Aux2 is idle in state(s) 0
              Code queue is empty.
              === Filament sensors ===
              Extruder 0 sensor: ok
              === CAN ===
              Messages queued 142, send timeouts 337, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 47
              === SBC interface ===
              State: 0, failed transfers: 1
              Last transfer: 20ms ago
              RX/TX seq numbers: 1258/1259
              SPI underruns 1, overruns 1
              Number of disconnects: 0, IAP RAM available 0x20a28
              Buffer RX/TX: 0/0-0
              === Duet Control Server ===
              Duet Control Server v3.2.0
              Code buffer space: 4096
              Full transfers per second: 34.26
              Maximum length of RX/TX data transfers: 3056/848
                At this point your best options may be to upgrade RRF using Bossa, or upgrade in standalone mode.
                • dhusoloundefined
                  dhusolo
                  Using Bossa to update the firmware worked. However I did notice every time I update the firmware my DWC settings get reverted. Ex all my pre defined temps get reset. Is there something I can do to prevent that?
                    Phaedrux Moderator @dhusolo
                    @dhusolo said in Questions on updating to latest 3.2 build:
                    I wonder if that has anything to do with the settings not sticking?
                    In the DWC general settings are you set to save to local storage?
