    error upgrading
    Firmware installation
    1.5k
    • PeterAundefined
      PeterA
      Thanks I will do that tonight and let you know. As for the config.g I couldn't agree more, I have run a new setup and after its all upgraded I will be able to try it out. Again thank you.
      • PeterAundefined
        PeterA
        OK, long story short, I tried to go to the 2.05 first but had the same error. Then I copied the missing file "Duet2CombinedIAP.bin" from the v 3.00 and put it into the /sys file on the SD card. Hey hit the money, all the upgrades went as they should.
        • PeterAundefined
          PeterA
          Thanks for your help. I have an issue now with my piezo drilling into the bed when trying to home. Could you please point me in the right direction.
          Here's my config.g
          ; generated by RepRapFirmware Configuration Tool v3.2.2 on Thu Jan 21 2021 05:12:35 GMT+0200 (South Africa Standard Time)
          ; ##### General preferences #####
          M550 P"Tevo BlackWidow" ; set printer name
          ; Using a PanelDue with Duet 3 and Duet 2 and RRF3 will require the following line "M575: Set serial comms parameters" being present in config.g.
          M575 P1 S1 B57600
          ; ##### Network #####
          M552 S1 ; enable network
          M587 S"Tech5_753CE0_EXT" P"landeach108" ; Configure access point. You can delete this line once connected
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          ; ##### Drives #####
          M569 P2 S0 ; physical drive 2 goes backwards
          M92 X80.00 Y80.00 Z1600.00 E426.90 ; set steps per mm
          M566 X800.00 Y800.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X3000.00 Y3000.00 Z500.00 E1200.00 ; set maximum speeds (mm/min)
          M201 X500.00 Y500.00 Z250.00 E250.00 ; set accelerations (mm/s^2)
          M906 X1050 Y1050 Z900 E700 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S60 ; Set idle timeout
          ; ##### Axis Limits #####
          M208 X365 Y245 Z260 S0 ; set axis maxima
          ; ##### Endstops ######
          M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin !xstop
          M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin !ystop
          M574 Z1 S1 P"!zstop" ; configure active-high endstop for low end on Z via pin !Zstop
          ; ##### Endstops old 2.05 Firmware working Settings #####
          ;M574 X1 S0 ; Set active low end stops
          ;M574 Y1 S0 ; Set active low end stops
          ;M574 Z2 S2 ; configure Z-probe endstop for high end on Z
          ; ##### Z-Probe Precision Piezo #####
          M558 P5 C"^zprobe.in" H5 F450 T5000 ; set Z probe type to switch and the dive height + speeds
          M557 X10:328 Y10:210 S20 ; define mesh grid
          ; ##### Z-Probe old 2.05 Firmware working Settings #####
          ; M558 P8 R1 I1 H5 F450 T5000 ; Set Z probe type to inverted, unfiltered piezo and the dive height + speeds
          ; G31 P500 X0 Y0 Z0 ; Set Z probe trigger value, offset and trigger height
          ; M557 X10:328 Y10:210 P5 ; Define mesh grid
          ; ##### Heaters #####
          M307 H0 A94.6 C545.4 D2.4 S1.00 V24.1 B0 ;PID tuning for Bed
          ; M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit
          M307 H1 A309.5 C152.4 D4.9 S1 S1 V24.1 ;PID tuning for Nozzel
          ; M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
          M143 H1 S310 ; set temperature limit for heater 1 to 310C
          ; ##### Fans #####
          M106 P0 C"Hot End" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off
          M106 P1 C"Parts Fan" S1 H1 T45 ; set fan 1 name and value. Thermostatic control is turned on
          ; ##### Tools #####
          M563 P0 S"Mosquito" D0 H1 F0 ; define tool 0
          ; ##### Miscellaneous #####
          ; ######### Automatic power saving ##########
          ; ########## Epilogue ##########
          M501 ; Run config-override.g
          T0 ; select first tool
          • Vetiundefined
            Veti
            did you change the config by hand or generated a new one?
            • Vetiundefined
              Veti
              post your homing file
              • PeterAundefined
                PeterA
                Hi, I generated a new one then Formatted it a bit as you can see. Its like the Duet is not registering that the Z piezo has triggered even though it has. I would think that I've got something wrong with identifying it or something in the config.g???
                Any way here's my homeall.g
                I was getting errors so i had to replace all the S(x) switches with an H(x).
                ; homeall.g
                ; called to home all axes
                ; generated by RepRapFirmware Configuration Tool on Mon Dec 24 2018 18:36:17 GMT+0200 (South Africa Standard Time)
                G91 ; relative positioning
                G1 Z5 F1000 H2 ; lift Z relative to current position
                ;G1 Z5 F1000 S2 ; lift Z relative to current position
                G1 H1 X-365 Y-245 F2000 ; move quickly to X and Y axis endstops and stop there (first pass)
                ;G1 S1 X-365 Y-245 F2000 ; move quickly to X and Y axis endstops and stop there (first pass)
                G1 X5 Y5 F400 ; go back a few mm
                G1 H1 X-6 Y-6 F500 ; move slowly to X and Y axis endstops once more (second pass)
                ;G1 S1 X-6 Y-6 F500 ; move slowly to X and Y axis endstops once more (second pass)
                G1 Z3 F500 H2 ;LIFT Z FROM CURRENT HIEGHT
                ;G1 Z3 F500 S2 ;LIFT Z FROM CURRENT HIEGHT
                G1 H1 Z-275 F600 ;MOVE DOWN TILL ENDSTOP TRIGGERED
                ;G1 S1 Z-275 F600 ;MOVE DOWN TILL ENDSTOP TRIGGERED
                G1 Z2 F300 H2 ; LIFT Z FOR SECOND PROBE
                ;G1 Z2 F300 S2 ; LIFT Z FOR SECOND PROBE
                G1 H1 Z-4 F600 ;MOVE DOWN TILL ENDSTOP TRIGGERED
                ;G1 S1 Z-4 F600 ;MOVE DOWN TILL ENDSTOP TRIGGERED
                G90 ; absolute positioning
                G92 Z-0.04 ; set Z to axis minimum (you may want to adjust this)
                • Vetiundefined
                  Veti
                  @PeterA said in error upgrading:
                  you generated a config for a z endstop not a z probe.
                  there is no G30 in you homing script.
                  PeterAundefined 1 Reply Last reply Reply Quote 0
                  • PeterAundefined
                    PeterA @Veti
                    @Veti
                    OK so do i change that to
                    M574 Z1 S1 P"!zprob" ; configure active-high endstop for low end on Z via pin !
                    Not sure if that is even a command??
                    • Vetiundefined
                      Veti @PeterA
                      but the homing script is more important.
                      generate a new one in the configurator,
                      load the json and change the z endstop to probe
                      • PeterAundefined
                        PeterA
                        OK thanks Ill go give it a try
                        • fcwiltundefined
                          fcwilt @Veti
                          @Veti said in error upgrading:
                          His config.g file says it's for v3.
                          From the v3 documentation:
                          The S2 option of M574 is intended for use only when axes other than Z are using the Z probe for homing. ... When using the Z probe to home Z, M574 Z0 should be used.
                          • Vetiundefined
                            Veti
                            it works either way.
                            M574 Z1 S2
                            is what the configurator creates for z probe on version 3.
                            but as i said more important is the homing script.
                            • PeterAundefined
                              PeterA
                              OK so done all that. Now when homing all z Just lifts up then says its homed. I can see the piezo is not triggering. Below are the changes I made in bold.
                              config.g
                              M574 Z0 S2 ; configure Z-probe endstop for low end on Z
                              ;M574 Z1 S1 P"!zstop" ; configure active-high endstop for low end on Z via pin !Zstop
                              and the new homeall.g
                              ; homeall.g
                              ; generated by RepRapFirmware Configuration Tool v3.2.2 on Thu Jan 21 2021 05:12:36 GMT+0200 (South Africa Standard Time)
                              G1 H1 X-370 Y-250 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                              G1 H2 X5 Y5 F6000 ; go back a few mm
                              G1 H1 X-370 Y-250 F1800 ; move slowly to X and Y axis endstops once more (second pass)
                              G1 X10 Y10 F6000 ; go to first bed probe point and home Z
                              ;G91 ; relative positioning
                              ;G90 ; absolute positioning
                              • PeterAundefined
                                PeterA
                                So I'm not sure???😖
                                • PeterAundefined
                                  PeterA
                                  When using the configurator the z option for piezo remains greyed out. So i used the old settings???
                                  • Vetiundefined
                                    Veti
                                    post the output of M119
                                    • fcwiltundefined
                                      fcwilt @Veti
                                      M574 Z1 S2
                                      Son of a gun. That's confusing.
                                      Turns out, at least on 3.2 that M574 Z0 or M574 Z1 S2 or M574 Z2 S2 works.
                                      It even worked with no M574 referencing Z at all.
                                        Phaedrux Moderator @fcwilt
                                        @fcwilt said in error upgrading:
                                        Which makes complete sense since G30 only cares about M558 and G31. M574 is for endstops.
                                          Phaedrux Moderator @PeterA
                                          In your 2.05 config for the piezo you have it inverted and P8 probe type. To do the same in 3.2 you'd add a ! to the pin name. Try this.
                                          M558 P8 C"^!zprobe.in" H5 F450 T5000 R1
                                          That would match your previous settings.
                                          You should also check your config.g syntax by sending M98 P"config.g" This will report any errors that may get lost during startup.
                                          • PeterAundefined
                                            PeterA
                                            Sorry guys had an internet issue. Bust testing now
