    Duet2 wifi Not connecting
    Duet Web Control
    3.7k
    • Tisum1979undefined
      Tisum1979
      Should I use all upper or lower case letters for my password
        Upper and lower case in the SSID isn't a bit deal, but if you are using upper and lower case in the password you should read the notes here: https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M587_Add_WiFi_host_network_to_remembered_list_or_list_remembered_networks
        Many programs used to send GCodes convert all characters to uppercase. In firmware 1.19.2 and later, within any quoted string you can use a single-quote character to indicate that the following character should be changed to lowercase. For example, M587 S"ABC" P"P'A'S'SW'O'R'D" would specify that the password is "PassWord". Use two single quote characters to represent one actual single quote character in the password or in the SSID. For example, if your SSID is "Pete's network" then enter "Pete''s network".
        The use of special characters in the SSID cannot be guaranteed to work. In general it's best to avoid most special characters. Spaces, periods, dashes, underscores, and other punctuation is likely ok, but special characters on the number keys likely are not safe. (@#$%^&*). If you are having troubles adding your SSID, try a simplified version with only letters and numbers.
        This is why I suggest using a macro to enter the SSID and password, so that it doesn't matter.
          Tisum1979
          I did what you said above and entered in my SSID and password which was all lower case with number and it loaded OK. I sent M552 S1 and then M122 while the command was trying to connect and this is what I got-- WiFi -<LF>
          Network state is changing mode<LF>
          WiFi module is trying to connect<LF>
          Failed messages: pending 0, notready 0, noresp 0<LF>
          WiFi firmware version 1.23<LF>
          WiFi MAC address 98:f4:ab:cf:be:21<LF>
          WiFi Vcc 3.33, reset reason Turned on by main processor<LF>
          WiFi flash size 4194304, free heap 28264<LF>
          Socket states: 0 0 0 0 0 0 0 0<LF>
          ok<LF>
          WiFi reported error: Failed while trying to connect to MySpectrumWiFiF8-2G<LF>
          WiFi module is idle<LF>
            Ok, so it seems like it's trying to connect, but can't. To eliminate the problem being with the wifi module, let's try setting it up in access point mode. This will verify that the wifi module is working, and confirm that you can connect to it. That would mean that the problem is with your wifi network, whatever that may be.
            https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M589_Configure_access_point_parameters
            Take a look at that link. Basically you will be telling to Duet to create its own access point, and then you will connect your device (your PC) to that access point.
            Then you should be able to access the web interface from your browser by going to the IP address you set when you configure it.
              Tisum1979
              Ok this is a stupid question. I have typed in M589 and the SSID and Password, in the example it shows a verticle line does that need to be in there before I type in the IP address
                That vertical line is actually the capital letter i
                  Tisum1979
                  Ok and is there a space between the IP address and the C1? what is C1
                    Yes there is a spaxe between the address and the C1. You can leave the C1 off entirely. It sets the wifi channel (1-13) default is 1 and should be fine for our test.
                      Tisum1979
                      ok so do I just type the 552 S1 now
                      ok so this is my resaults- M589 S"MySpectrumWiFiF8-2G" P"abigail2011" I192.168.1.1 C1<LF>
                      ok<LF>
                      M552 S1<LF>
                      ok<LF>
                        Tisum1979
                        I don't understand why it's not connecting
                          Ok, let me try explaining again.
                          What we want to do is use the M589 command to create a NEW wifi network that is coming from the Duet itself. You'll then connect to THAT network from your computer.
                          So try this, send M589 S"DuetWifi" P"abigail2011" I192.168.1.1
                          Then send M552 S2
                          Now on your computer you will have to look for the wifi network called DuetWifi and connect to that using the password you just set.
                          Then in your browser go to 192.168.1.1 which should open to the Duet web interface if everything is working.
                            Tisum1979
                            It didn't work. Would it be possible for it not to work if my windows 10 is out of date
                              What does it say when you send the commands?
                              Do you see a wifi network on your computer called DuetWifi after sending that command?
                                Tisum1979
                                M589 S"DuetWiFi" P"abigail2011" I192.168.1.1<LF>
                                ok<LF>
                                  Tisum1979
                                  M552 S2<LF>
                                  ok<LF>
                                  WiFi module is providing access point DuetWiFi, IP address 192.168.1.1<LF>
                                    Ok, that looks like it's working.
                                    Now on your computer you need to connect to the SSID called "DuetWifi" instead of MySpectrumWiFiF8-2G.
                                      Tisum1979
                                      ok the blue light came on but it was asking for a network security key.
                                        @Tisum1979 said in Duet2 wifi Not connecting:
                                        abigail2011
                                        That's the password you set in the M589 command.
                                          Tisum1979
                                          would the connection to the board not work if there
                                            Tisum1979
                                            so if I am connected to the duet wifi I don't have internet. It disconnects me from spectrum
