Duet 2 Wifi and Airwolf 3D HD - Fan not coming on.
Board: Duet 2 WiFi (2WiFi) Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.2 (2021-01-05) Duet WiFi Server Version: 1.25 Hi,
I have the fan plugged into FAN1 pin as the documentation I read said that it was the safest as FAN1 comes on by default on power up.Here is what I have for my fans
M950 F0 C"fan1" Q500 ; create fan 0 on pin fan1 and set its frequency M106 P0 T45 H1 S1 ; set fan 0 value. Thermostatic control is turned on The fan does turn on when I'm not using sliced gcode... I turned my hotend to 60 and it turned on around the 45 mark.
When I use Cura to slice my gcode, it is set to not use the fan for the first 3 layers and then turn on at 100%.
It isn't turning my fan on... Can anyone assist?
Check your cura settings for what fan it's trying to target.
Can you share a sliced gcode file from cura?
Also, post your full config.g
