    Persistent variable stored on the SD Card
    Firmware wishlist
    anet et5
    410
    • audryhomeundefined
      audryhome
      Hi there,
      I need to purge/clean my nozzle without using skirts, because I print small parts.
      The only way to solve this is to print a straight line around my bed, this ensure the head will be ready when skipping to print sequence after this preamble.
      I would like to use the perimeter of my bed, say a 5/10 mm strip to purge my nozzle, then I could clean my bed once every 10/20 parts, which is the maximum I print in one session.
      For this, I would need a variable that would be incremented each print (either unique or sequential) and that would be stored after each cleaning sequence, until a limit is reach and DUET says to me "this is enough, please clean your bed". Yes I am lazy....
      I didn't find any command that store anything on the SD card, except G29 and M500, but that doesn't help so much.
      Ideally, a variable feature, implemented in firmware, and an option to store the object model would be a solution, but it is not implemented yet....
      Any other idea?
      Many thanks
        You can use M560 to write a macro file to the SD card.
          audryhome
          Many thanks,
          Any idea when user variables will be available?
          • fcwiltundefined
            fcwilt @audryhome
            @audryhome said in Persistent variable stored on the SD Card:
            I don't understand what small parts has to do with it.
            Are you printing many at one time?
            audryhomeundefined 1 Reply Last reply Reply Quote 0
              dc42 administrators @audryhome
              Many thanks,
              They are planned for firmware 3.4. Firmware 3.3 is planned to be a short cycle; most of the new features planned for it have already been implemented.
                audryhome
                Thanks again, I will wait until it's available. I have multiple reasons to implement macros with session dependent parameters.
                Oozing with bed real estate management, and also random z probe point to eliminate the influence of the small spot deposited by my nozzle each time I home Z axis. Since it is orion driven, mark allways the same spot on the bed, and this add a tiny plastic spot, which is not melted anymore on the bed, and that introduce cumulative error on the measurement.
                  Random Z probe point for homing Z is already possible.
                    audryhome @fcwilt
                    @fcwilt Yes, I print tiny parts ( custom gears and connectors), and I need minimal entry points on my objects to allow best external mechanical interface possible.
                    Therefore I need to purge my nozzle between each part to ensure identical start conditions.
                    And since I need many parts, I stuff my printing bed with as much as possible parts.
