Using FAN Pin as a GPIO in Duet 3
Using Duet Controllers
    Saurabh
    Hi Sir @dc42 , I've Duet 3 6HC V1.0 I want to use FAN out pins(out4, out5, ou6) as a GPIO out pin. Tried configuring the pins using
    ; configuration
    M950 P0 C"out4"
    M950 P1 C"out5"
    M950 P2 C"out6"
    ; console
    M42 P0 S1 ; turn on pin out4
    M42 P1 S1 ; turn on pin out5
    M42 P2 S1 ; turn on pin out6
    But there is no output.
    Tried Inverting pin. Nothing works.
    How can I use this pins as a digital output pins?
    Thank you.
      Can you post your full config.g?
      Can you send M122 and M98 P"config.g" and post the response?
      What are you trying to control?
        Saurabh
        Solved the issue, GPIO pin is working when a device is connected to that. Earlier I was checking output on out4 using a multimeter and it was showing almost 0V. Any idea how to detect this pwm signal on out4 using a multimeter or scope?
        undefined 1 Reply Last reply 10 Feb 2021, 09:01 Reply Quote 0
          dc42 administrators @Saurabh
          @Saurabh said in Using FAN Pin as a GPIO in Duet 3:
          Connect a pullup resistor between the OUT- pin and the adjacent positive supply pin.
          3 out of 4
