rotary delta + mesh compensation | Strange Z-Lift
@PCR I haven't tested this yet, i will give it a try
@Egris 2 years ago i used firmware 2.x. There i managed to probe the bed with g29 in a rectangular grid
@PCR With M557 R140 S15 got the same result for the Z-Lift as
M557 X-140:140 Y-140:140 S20..
Effector moves after first probe trigger to abaot X0 Y140.
Thanks for your help -
@Egris, can you post a video showing the effect of doing a single G30 move using firmware 3.2 or 3.3beta?
@dc42 After the G30 i did via Webcontrol button Y+5 5mm in Y-Direction. The Effector is moving in Y and Z direction. Could this matter?
Testing it with 3.3 beta gives the same Result
It looks like the move to raise the probe after it triggers may be using one motor only. Is the Z motor on the left as seen in that video?
Please post your config.g file so that I can try to replicate it.
@dc42 thank you very much for looking into my problem!
Here is my config.g Fileand i did a drawing of the actual wiring layout
; Rotary Delta Config
M669 K10 U190.0 L393.5 R45 A-90.0:46.50 H419.5 X60, Y60, Z60 B212.132
M666 X0.0 Y0.0 Z-0.28I rotated the all 3 arm angles by 60° to line up the X/Y Axis
@dc42 at the moment i cant confirm weather the mesh compensation is working or not. For me it was not possible to finish the grid probing. At the outskirts of the bed the Z-Lift is doing really fast moves to the other side of the bed. What i can confirm is that printing without the compensation is working really well.
Probing a single point changes / effects the the machine coordinate sytem. After a G30 when i whant to move lets say only in Y-Direction, the move is in Y and Z direction like in that last video.
Looking forward to solve this Problem together. Thanks alot for looking into it.
@Egris said in rotary delta + mesh compensation | Strange Z-Lift:
Are you saying that when the machine has been calibrated manually so that good prints are possible, the Z-lift moves during mesh bed probing are not vertical?
What happens if you home the printer, command the nozzle to e.g. 5mm above the centre of the bed, and do G30 S-1 ? Does the Z lift move afterwards go straight up? If so, is it any different if you run G30 S-1 when the nozzle is away from the centre?
i looked into the Statemachine for bed-probing in Gcodes 4 but couldn find any hint.
before the Z-Lift there is called the Function SetMoveBufferDefaults(). Could there be somthing reset? -
PS - one more test:
- Move the nozzle to a point off-centre e.g. X0 Y50 Z10. Then command the nozzle up (e.g. to Z50) and check that the movement is vertical. Next, command the nozzle to X0 Y50 Z10 again, but after that send G91 Y50 Z10 (i.e. tell the machine where it is at, giving it the same coordinates that it thinks it is at). Then command the nozzle up to Z50 again and see if the movement is still vertical.
@dc42 1. Are you saying that when the machine has been calibrated manually so that good prints are possible, the Z-lift moves during mesh bed probing are not vertical?
Yes thats true. In the Center of the Bed the Z-Lifts are "more" vertical than they are getting to the edges of the bed.
If i set my grid-probing to X-145:145 Y-145:145 the first Probe is at X-145 Y-145. Everything works fine until the Z-Lift. When Z is lifted the head moves to abaout X-145 Y145 in a not coordinated move. When it arrives there the head will move to the next grid point at X-125Y-145. On that 2 moves it crashed the nozzle into the bed
@dc42 said in rotary delta + mesh compensation | Strange Z-Lift:
tested it and it works like it should. Z-Movment is vertical
Thanks; and what about the G30 S-1 tests?
i can do that test probably tomorrow. I think i damaged my Z_Probe_In Pin by the 5V Signal of the BLtouch. My Duet2 probably was older than the revision that can handle 5V on that Pin.
. Is there a possibly to use another analog pin for my Z-Probe? I orderd a spare one
Are you sure the pin isn't working? The Z probe input pin is fairy tough even on older Duets.
You can connect the BLTouch to a spare endstop input.
I have reproduced this issue by configuring my linear delta as if it is a rotary delta. The forward transform for rotary delta kinematics was inverting the Cartesian Y coordinate. What surprises me is that this has ever worked, because that code has not changed.
I have put a new firmware build for Duet WiFi at https://www.dropbox.com/sh/q5uqqkjbmhgvlhq/AACYqG0ynLME9ogoLd1zLB2Xa?dl=0. If you are not already running release 3.3beta1, please read the 3.3beta1 release notes before installing this.
I've made an attempt at implementing auto calibration for rotary delta machines. The firmware for Duet 2 is at https://www.dropbox.com/sh/q5uqqkjbmhgvlhq/AACYqG0ynLME9ogoLd1zLB2Xa?dl=0.
Calibration factors implemented are:
3 = homing switch position corrections
4 = as 3 + bearing heights (all 3 heights adjusted by the same amount)
5 = as 4 + delta radius
7 = as 5 + tower position correctionsI have no machine to test this one, so it is highly likely that it won't work. It's also possible that it will work but only if you home again immediately after running auto calibration.
Please test it very carefully. Use M669 and M666 without parameters after running auto calibration to see what parameters changed.
