3.3b1CAN timeout resets itself?
Beta Firmware
955
    TypQxQ @T3P3Tony
    @T3P3Tony I’m not sure. I didn’t have the extra XY motors on the 3HC back then. My logs show 2 timeouts at an instance on 3.2.2 but not more than that.
    I left the printer on overnight just idling and that generated no timeouts which makes me wonder if it has something to do with amount of messages/s.
    After idling for about 7h:
    6HC:
    Messages queued 212635, send timeouts 0, received 283521, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 514, free buffers 49 (min 49)
    3HC:
    CAN messages queued 436976, send timeouts 0, received 689661, lost 0, free buffers 36, min 36, error reg 0
    While printing, before canceling and letting the printer idle:
    6HC:
    Messages queued 454219, send timeouts 6845, received 128018, lost 0, longest wait 1ms for reply type 6013, peak Tx sync delay 514, free buffers 49 (min 33)
    3HC:
    dup 0, oos 16, bm 8, wbm 9772795
      @TypQxQ, please confirm that the config.g file that you posted on 28 Feb is the one you used during that print, and provide the GCode file you were printing during that test this morning. Then I will run it on my bench setup. The last part of the 3HC diagnostics "oos 16, bm 8, wbm 9772795" are a particular concern.
      undefined 1 Reply Last reply 2 Mar 2021, 09:02 Reply Quote 0
        TypQxQ @dc42
        @dc42 Should be that config but I attach it here again.
        Also my eventlog and the gcode file.
        https://we.tl/t-LXCxEDaMXP
        I want to test without any motors connected when I get home later today. Plan to disconnect them and put them at 100mA not to get disconnection errors.
        undefined 1 Reply Last reply 2 Mar 2021, 09:05 Reply Quote 0
          dc42 administrators @TypQxQ
          @TypQxQ said in 3.3b1CAN timeout resets itself?:
          Thanks, that's a good plan. I'll probably run it the same way.
            @TypQxQ, please provide your sys/custom/tool_0.g and sys/custom/conf_Endstops.g files.
            undefined 1 Reply Last reply 2 Mar 2021, 11:59 Reply Quote 0
              TypQxQ @dc42
              @dc42 said in 3.3b1CAN timeout resets itself?:
              Here is everything in my config and customconfig folder.
              https://we.tl/t-xwMjBHKrGd
              Thank you!
                Thanks, I am running that job now. How long did you leave it running last time, before you ran M122 B1 and got this message?
                  Progress update. Running your job and your configuration, I am seeing a lot of send timeouts (in the M122 report) on the MB6HC. The number of out-of-sequence messages received on the EXP3HC ('oos' in the M122 B1 report) is much lower, suggesting that most of the send timeouts are spurious; but the fact that they occur at all indicates a problem. I will keep you informed.
                    It appears that with a code change I have resolved the send timeouts and associated 'oos' reports. Your print has been running for 76 minutes now with no error reports.
                    I still haven't seen any of the 'bm' reports on my system. They are likely to have a different cause.
                    I forgot to ask one thing. As I understand it, your system has just a MB6HC and one EXP3HC connected via CAN, and no other CAN-connected boards. Have you fitted the CAN termination jumpers to the EXP3HC board?
                    PS - if you want to try the 6HC and 3HC firmware binaries that I am running, you can find them here https://www.dropbox.com/sh/q5uqqkjbmhgvlhq/AACYqG0ynLME9ogoLd1zLB2Xa?dl=0.
                    undefined 1 Reply Last reply 2 Mar 2021, 18:44 Reply Quote 0
                      TypQxQ @dc42
                      This is great news!
                      I can confirm my CAN termination jumpers are closed on 3HC.
                      I plan is to buy another 3HC if I get multiple motors on XY to work 😄
                      Not sure what if you mean time since reboot or since stopped printing.
                      According to the eventlog above, "Last reset 10:14:33 ago" and was idle for almost 8h.
                      When it was printing and had an uptime of 00:07:53 it read:
                      CAN messages queued 3305, send timeouts 222, received 2369, lost 0, free buffers 36, min 36, error reg 100000
                      dup 0, oos 0, bm 4, wbm 5559827
                        What I meant was, how long did you have to print for to get a nonzero 'bm' value when you ran M122 B1? Because I haven't seen any yet. Looks like 7 minutes may have been enough for you.
                        undefined 1 Reply Last reply 2 Mar 2021, 19:37 Reply Quote 0
                          TypQxQ @dc42
                          Trying the new firmware right now.
                          I don't know what BM and WBM stands for but I got them again after 00:13:24 :
                          CAN messages queued 6740, send timeouts 0, received 6156, lost 0, free buffers 36, min 36, error reg 0
                          dup 0, oos 0, bm 12, wbm 15972458
                          Also before printing I had some error reg. at uptime of 00:03:24:
                          CAN messages queued 2083, send timeouts 0, received 1735, lost 0, free buffers 36, min 36, error reg 110000
                          dup 0, oos 0, bm 0, wbm 0
                          Now printing without any timeouts so far but only 20min inside print.
                            'bm' is the bad move command count, which I put in temporarily to debug a previous issue. That's the count of move commands that were scheduled to start before the previous move had ended. 'wbm' is a record of the worst bad instance; the figure is how many 750kHz clock ticks the new move was supposed to start before the previous move had finished. So your 'wbm' figure of 5559827 indicates that a move was scheduled to start 7.4 seconds before the previous move ended.
                            I don't see a nonzero bad move command count on my machine. However, it's occurred to me that you might legitimately have this situation after homing. I don't do homing of my simulation of your machine, I just use G92 to set all the axis positions. But if you are homing an axis connected to the EXP3HC, then that homing move might be scheduled to take e.g. 10 seconds but stop after 3 seconds when it triggers the homing switch. Then the next move will start before the homing move was originally scheduled to end, triggering the bad move command logging.
                            I will fix the bad move command counter to take account of moves that complete before they were originally scheduled to complete.
                            PS:
                            1. I've just replaced the EXP3HC binary at https://www.dropbox.com/sh/q5uqqkjbmhgvlhq/AACYqG0ynLME9ogoLd1zLB2Xa?dl=0 to include that change to the bad move count logging.
                            2. My print has been going for almost 5 hours now. During that time it has recorded just one send timeout on the main board while sending a movement message. I think it must be spurious, because there wasn't a corresponding 'oos' (out of sequence) error on the EXP3HC, which I would expect if the 3HC hadn't received the move.
                            undefined 1 Reply Last reply 3 Mar 2021, 06:27 Reply Quote 2
                              TypQxQ @dc42
                              @dc42 I have finished printing and after 9h16m the print looks good and I also only received one timeout:
                              Messages queued 1750358, send timeouts 1, received 362388, lost 0, longest wait 24ms for reply type 6024, peak Tx sync delay 578, free buffers 49 (min 47)
                              CAN messages queued 361984, send timeouts 0, received 1747438, lost 0, free buffers 36, min 36, error reg 0
                              I loaded the new 3HC firmware with time 22:51 on Dropbox and will run it again. But the time compile time in M122 hasn't changed after updating this morning: "Duet EXP3HC firmware version 3.3beta1+1 (2021-03-02 15:56:53)"
                              Thank You!!! It this looks sooo good!
                              2021-03-03 05:32:39 Finished printing file 0:/gcodes/RearLeft v6.2.gcode, print time was 9h 16m
                              2021-03-03 06:30:00 === Diagnostics ===
                              RepRapFirmware for Duet 3 MB6HC version 3.3beta1+1 running on Duet 3 MB6HC v0.6 or 1.0 (SBC mode)
                              Board ID: 08DJM-956L2-G43S4-6JKDD-3SJ6L-TB62G
                              Used output buffers: 1 of 40 (17 max)
                              Static ram: 148212
                              Dynamic ram: 62952 of which 0 recycled
                              Never used RAM 143028, free system stack 98 words
                              Tasks: Linux(ready,63) HEAT(delaying,284) CanReceiv(notifyWait,774) CanSender(notifyWait,359) CanClock(delaying,342) TMC(notifyWait,18) MAIN(running,649) IDLE(ready,20)
                              Owned mutexes: HTTP(MAIN)
                              Last reset 10:23:58 ago, cause: power up
                              Last software reset at 2021-03-02 19:50, reason: User, none spinning, available RAM 139760, slot 2
                              Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task Linu Freestk 0 n/a
                              Error status: 0x00
                              Aux0 errors 0,0,0
                              Aux1 errors 0,0,0
                              MCU temperature: min 43.3, current 43.5, max 44.8
                              Supply voltage: min 31.8, current 31.9, max 32.0, under voltage events: 0, over voltage events: 0, power good: yes
                              12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0
                              Driver 0: position 160000, standstill, reads 5226, writes 2 timeouts 0, SG min/max 0/1023
                              Driver 1: position 0, standstill, reads 5227, writes 2 timeouts 0, SG min/max 0/1023
                              Driver 2: position 311549, standstill, reads 5227, writes 2 timeouts 0, SG min/max 0/158
                              Driver 3: position 0, standstill, reads 5227, writes 2 timeouts 0, SG min/max 0/1023
                              Driver 4: position 0, standstill, reads 5227, writes 2 timeouts 0, SG min/max 0/1023
                              Driver 5: position 0, standstill, reads 5226, writes 2 timeouts 0, SG min/max 0/1023
                              Date/time: 2021-03-03 06:29:58
                              Slowest loop: 90.33ms; fastest: 0.05ms
                              === Storage ===
                              Free file entries: 10
                              DMs created 125, maxWait 286ms, bed compensation in use: mesh, comp offset 0.000
                              === MainDDARing ===
                              Scheduled moves 1889328, completed moves 1889328, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                              === AuxDDARing ===
                              Heater 0 is on, I-accum = 0.1
                              Segments left: 0
                              Movement lock held by null
                              HTTP* is doing "M122 B0" in state(s) 0
                              Telnet is idle in state(s) 0
                              File* is idle in state(s) 0
                              USB is idle in state(s) 0
                              Aux is idle in state(s) 0
                              Queue* is idle in state(s) 0
                              LCD is idle in state(s) 0
                              SBC is idle in state(s) 0
                              Daemon is idle in state(s) 0
                              Aux2 is idle in state(s) 0
                              Code queue is empty.
                              === CAN ===
                              Last cancelled message type 51 dest 1
                              === SBC interface ===
                              State: 4, failed transfers: 0
                              Last transfer: 1ms ago
                              RX/TX seq numbers: 40775/40775
                              SPI underruns 0, overruns 0
                              Number of disconnects: 0, IAP RAM available 0x2d3ac
                              Buffer RX/TX: 0/0-0
                              2021-03-03 06:30:03 Diagnostics for board 1:
                              Bootloader ID: SAME5x bootloader version 2.2 (2021-01-16b1)
                              Never used RAM 154884, free system stack 0 words
                              Tasks: Move(notifyWait,80) HEAT(delaying,69) CanAsync(notifyWait,72) CanRecv(notifyWait,82) CanClock(notifyWait,74) TMC(notifyWait,30) MAIN(running,301) AIN(delaying,260)
                              Last reset 10:24:02 ago, cause: power up
                              Last software reset at 2020-11-10 18:16, reason: StackOverflow, available RAM 154112, slot 0
                              Software reset code 0x0100 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0000080e BFAR 0xe000ed38 SP 0x2002ffb4 Task � Freestk 4294967295 ok
                              Stack: 2000137c 200013b0 0002525d 00000000 0003e418 20001598 20003b28 00000000 00024885 200014b4 20003ab0 00000000 00f00000 e000ef34 c0000000 20003b30 000249c5 0002472c 61000000 ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff
                              Driver 0: position -1440, 160.0 steps/mm, standstill, reads 17400, writes 2 timeouts 0, SG min/max 0/1023, steps req 268204856 done 268206165
                              Driver 1: position -144480, 160.0 steps/mm, standstill, reads 17399, writes 2 timeouts 0, SG min/max 0/1023, steps req 271278668 done 271279392
                              Driver 2: position 48970973, 830.0 steps/mm, standstill, reads 17397, writes 2 timeouts 0, SG min/max 0/1023, steps req 47753506 done 47753659
                              Moves scheduled 1888753, completed 1888753, in progress 0, hiccups 0, step errors 0, maxPrep 191, maxOverdue 5, maxInc 1, mcErrs 0, gcmErrs 0
                              Peak sync jitter 11, peak Rx sync delay 198, resyncs 30, no step interrupt scheduled
                              VIN: 24.1V, V12: 12.1V
                              MCU temperature: min 39.8C, current 40.0C, max 40.2C
                              Ticks since heat task active 64, ADC conversions started 37442556, completed 37442554, timed out 0
                              Last sensors broadcast 0x00000002 found 1 68 ticks ago, loop time 0
                              2021-03-03 06:55:17 G10 P0 S220
                              Before and after the timeout fix:
                              And final again:
                              2021-03-03 18:14:05 m122 b0
                              Used output buffers: 1 of 40 (21 max)
                              Static ram: 148212
                              Dynamic ram: 62904 of which 0 recycled
                              Never used RAM 143076, free system stack 98 words
                              Tasks: Linux(ready,69) HEAT(delaying,284) CanReceiv(notifyWait,774) CanSender(notifyWait,359) CanClock(delaying,342) TMC(notifyWait,18) MAIN(running,649) IDLE(ready,20)
                              Last reset 10:54:16 ago, cause: software
                              Last software reset at 2021-03-03 07:19, reason: User, none spinning, available RAM 143444, slot 2
                              Error status: 0x00
                              Aux0 errors 0,0,0
                              Aux1 errors 0,0,0
                              MCU temperature: min 42.1, current 43.6, max 45.1
                              12V rail voltage: min 12.0, current 12.0, max 12.1, under voltage events: 0
                              Driver 0: position 160000, standstill, reads 42231, writes 2 timeouts 0, SG min/max 0/1023
                              Driver 1: position 0, standstill, reads 42231, writes 2 timeouts 0, SG min/max 0/1023
                              Driver 2: position 311549, standstill, reads 42227, writes 6 timeouts 0, SG min/max 0/156
                              Driver 3: position 0, standstill, reads 42231, writes 2 timeouts 0, SG min/max 0/1023
                              Driver 4: position 0, standstill, reads 42231, writes 2 timeouts 0, SG min/max 0/1023
                              Driver 5: position 0, standstill, reads 42231, writes 2 timeouts 0, SG min/max 0/1023
                              Date/time: 2021-03-03 18:14:02
                              Slowest loop: 1001.41ms; fastest: 0.05ms
                              === Storage ===
                              DMs created 125, maxWait 7881ms, bed compensation in use: mesh, comp offset 0.000
                              === MainDDARing ===
                              Scheduled moves 1889328, completed moves 1889328, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 1, 0], CDDA state -1
                              === AuxDDARing ===
                              Segments left: 0
                              === CAN ===
                              Messages queued 2236102, send timeouts 4, received 463095, lost 0, longest wait 20ms for reply type 6024, peak Tx sync delay 554, free buffers 49 (min 47)
                              RX/TX seq numbers: 39306/39306
                              Number of disconnects: 0, IAP RAM available 0x2d3dc
                              Buffer RX/TX: 0/0-0
                              === Duet Control Server ===
                              Duet Control Server v3.2.2
                              Code buffer space: 4096
                              Full transfers per second: 51.37
                              Maximum length of RX/TX data transfers: 5092/1688
                              2021-03-03 18:13:58 m122 b1
                              Tasks: Move(notifyWait,80) HEAT(delaying,69) CanAsync(notifyWait,72) CanRecv(notifyWait,82) CanClock(notifyWait,74) TMC(notifyWait,30) MAIN(running,331) AIN(delaying,260)
                              Last reset 10:54:27 ago, cause: software
                              Driver 0: position -480, 160.0 steps/mm, standstill, reads 62626, writes 2 timeouts 0, SG min/max 0/1023, steps req 333181004 done 333181004
                              Driver 1: position -48160, 160.0 steps/mm, standstill, reads 62625, writes 2 timeouts 0, SG min/max 0/1023, steps req 340878416 done 340878416
                              Driver 2: position 48970973, 830.0 steps/mm, standstill, reads 62625, writes 3 timeouts 0, SG min/max 0/1023, steps req 60334361 done 60334361
                              Moves scheduled 1888677, completed 1888677, in progress 0, hiccups 0, step errors 0, maxPrep 180, maxOverdue 4, maxInc 2, mcErrs 0, gcmErrs 0
                              Peak sync jitter 11, peak Rx sync delay 204, resyncs 36, no step interrupt scheduled
                              Ticks since heat task active 155, ADC conversions started 39267896, completed 39267896, timed out 0
                              Last sensors broadcast 0x00000002 found 1 160 ticks ago, loop time 0
                              CAN messages queued 462985, send timeouts 0, received 2236041, lost 0, free buffers 36, min 36, error reg 0
                              2021-03-03 16:46:53 Finished printing file 0:/gcodes/RearLeft v6.2.gcode, print time was 9h 18m
                              • ctilley79undefined
                                ctilley79 @dc42
                                The messages timed out and messages lost counters get cleared immediately after you run M122.
                                The only time I have seen a problem with the CAN communication was under the following conditions:
                                • The EXP3HC had separate power wires from the PSU
                                I may have screwed this up. So It's best to power the 3HC from the 6HC Mainboard instead of running a separate wire from the PSU? Why?
                                undefined 1 Reply Last reply 5 Mar 2021, 22:02 Reply Quote 0
                                  dc42 administrators @ctilley79
                                  @ctilley79 said in 3.3b1CAN timeout resets itself?:
                                  It only matters if you are powering a high-powered bed heater directly from the Duet and you have long wires between the Duet and the PSU. Under those conditions, the changes in ground voltage caused by the bed heater being switching on/off rapidly with PWM can affect the CAN communication.
                                  19 out of 25
