    CRC Error Duet3
    Firmware developers
    • Matiasundefined
      Matias
      Hi!
      Hope you can help me. I am compiling the RepRapFirmware for the Duet 3 6HC. The debugging is working but when I build the release version, the status LED indicates an CRC error (which is just checked in RELEASE version). I tried with the 3.2.2 release code (without any modification) and I am getting the same error.
      I am building on Windows with the crc32appender in the PATH that is being called without any problem.
      Let me know if there is something else I can provide!
      Is there something I am missing?
        I suggest you use HxD (a hex file viewer/editor) to check that the CRC has been correctly appended.
        • Matiasundefined
          Matias
          Thanks for answering so fast. Now it working, I just recompiled after cleaning the project and removed the old binary file.
          If someone has the same problem, to compare the binaries I used:
          • To edit (remove the last 4 bytes): https://hexed.it/
          • Calculate the CRC: https://simplycalc.com/crc32-file.php
