Multi extruder & filament sensor
Config Tool
    JaapVis
    I modified a Stacker 4 extruder printer with an Duet 3 board, running Firmware 3.2, it works real great but there is one issue and maybe there is some one solved this.
    This machine is running at the same time with 4 extruders with the following commands in the config:
    M563 P0:1:2:3 D0:1:2:3 H1:2:3:4 F11:12:13:14
    M567 P0:1 E1:1:1:1
    There is one tool T0 defined and all the extruders are running, so far no problem.
    In the meantime I added laser filament sensor and these work with the latest firmware oke.
    So I define these sensor with the command:
    M591 D0 P5 C"io2.in" R10:120 E3.0 S1
    M591 D1 P5 C"io7.in" R10:120 E3.0 S1 ; etc.
    now the trick how can I trigger the other three sensors because T0 only see sensor D0 and not D1 etc. and soon I activate D1 sensor the machine pause immediately caused by sensor D1.
    What is a work around to have all sensors working with T0?
    Best regards, Jaap Vis
    undefined 1 Reply Last reply 27 Apr 2021, 14:03 Reply Quote 0
      dc42 administrators @JaapVis
      @jaapvis, it should work already, as long as the mix includes D1. Have you tested it? If you have and it doesn't work in firmware 3.2, try firmware 3.3beta3.
        JaapVis
        @jaapvis said in Multi extruder & filament sensor:
        @dc42, what do you mean by "as long as the mix includes D1" ?
        What I do is follow:
        M563 P0:1:2:3 D0:1:2:3 H1:2:3:4 F11:12:13:14 to set 4 extruders to tool D0.
        And the mix ratio
        M567 P0:1:2:3 E1:1:1:1
        Finally the sensor:
        M591 D1 P5 C"io7.in" R10:120 E3.0 S1 (sensor on second tool)
        Above doesn't work...
        Jaap
        undefined 1 Reply Last reply 28 Apr 2021, 07:15 Reply Quote 0
          @jaapvis have you run M591 D1 without parameters, to check that communication with the sensor is working?
          undefined 1 Reply Last reply 28 Apr 2021, 09:58 Reply Quote 0
            JaapVis @dc42
            @dc42 Yes communication is working, see pictur.
            undefined 1 Reply Last reply 2 May 2021, 18:00 Reply Quote 0
              JaapVis @JaapVis
              @All
              Is there someone with a solution for this issue?
              5 out of 6
