Duet 2 Wifi Firmware Ender5 Plus
M115
FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.3 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2021-06-15 21:45:03Hm!
Has problems
Has an Ender 5 Plus with Micro Swiss Direct + Bl touch
Has made everything work except Homing and leveling
Please someone who can help me
my config file ..
Configuration file for Duet WiFi (firmware version 3)
; generated by RepRapFirmware Configuration Tool v3.2.2 on Wed Feb 03 2021 12:12:49 GMT-0500 (Eastern Standard Time); General preferences
M550 P"Ender 5 Plus" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P2 S0 ; physical drive 2 goes backwards
M92 X600.00 Y600.00 Z800.00 E156.47 ; set steps per mm
M566 X1000.00 Y1000.00 Z80.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X8000.00 Y8000.00 Z600.00 E1200.00 ; set maximum speeds (mm/min)
M201 X900.00 Y900.00 Z30.00 E250.00 ; set accelerations (mm/s^2)
M208 X350 Y350 Z400 S0 ; set axis maxima; Endstops
M574 X1 S1 P"xstop" ; X min active high endstop switch
M574 Y1 S1 P"ystop" ; Y min active high endstop switchZ-Probe
M558 P9 C"^zprobe.in" H5 F100 T2000
M950 S0 C"exp.heater3"
G31 X-50 Y-11.02 Z-2,800 P25
M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0M140 H0 ; map heated bed to heater 0
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power lossHome all Fil
; homeall.g
; called to home all axes
; generated by RepRapFirmware Configuration Tool v3.2.2 on Sat Jan 30 2021 10:03:31 GMT-0500 (Eastern Standard Time)
G91 ; relative positioning
G1 H1 X-350 Y-350 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H2 X5 Y5 F6000 ; go back a few mm
G1 H1 X 150 Y 150 F500 ; move slowly to X and Y axis endstops once more (second pass)
G90 ; absolute positioning
G1 X150 Y150 F6000 ; go to first bed probe point and home Z
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G90 ; absolute positioning -
@btj Post your homeall.g and homez.g. Following on from your other thread, and because you added a BLTouch after you created the configuration, I expect your homing files still expect a Z endstop. Your homing files should use G30 for Z, not a Z move. So your homez.g probably looks something like this:
; homez.g ; called to home the Z axis ; ; generated by RepRapFirmware Configuration Tool v3.3.0 on Wed Aug 04 2021 11:16:52 GMT+0100 (British Summer Time) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 Z-205 F1800 ; move Z down until the endstop is triggered G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
When it should looks like this:
; homez.g ; called to home the Z axis ; ; generated by RepRapFirmware Configuration Tool v3.3.0 on Wed Aug 04 2021 11:19:43 GMT+0100 (British Summer Time) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G90 ; absolute positioning G1 X15 Y15 F6000 ; go to first probe point G30 ; home Z by probing the bed
Please only create a single thread for your issue. Spamming multiple threads won't get you help any faster and in fact will only slow things down. Also please describe what you're actually trying to do and what isn't working. This thread is now locked.
