    Time and filamen used write on SD
    Duet Web Control wishlist
    • TYPPA Albert Einsteinundefined
      Hi David
      It would be possible to save the data / statistics of the end of the Gode just finished in the SD before it goes off, not being on the computer. Also only the time / filament used. So you know the time / material used the next day when I get back to work 😉
      I have no special talent. I am only passionately curious.
      -Albert Einstein
        UP this ! Thanks
        -Albert Einstein
          This will be part of Logging, which is at or near the top of the firmware wishlist now. You can already see the filament required (according to the slicer) in the GCode Files list.
            @dc42:
            Thanks David
            -Albert Einstein
