    Configuration problems
    Firmware installation
    2.2k
    • fcwiltundefined
      fcwilt @Dave Parry
      @dave-parry said in Configuration problems:
      I checked the sensors by removing M308 and M960 lines and put back M305 lines. and the sensor readings were back and correct.
      What firmware version are you running?
      • Dave Parryundefined
        Dave Parry
        WiFi/Ethernet 2.05.1 (2020-02-09b1)
        (Thought I had upgraded to Release 3.4.0 beta 3
        but it seems that for some reason it hasn't worked.)
        Duet Web Control 3.3.0
        Will try again
          Dave Parry
          Just tried again and the machine specific tab still says 2.05
          • fcwiltundefined
            fcwilt @Dave Parry
            Will try again
            Remember that you have to first go from 2.05.1 to 3.0.0
              Dave Parry
              Tried 3.1 combined.bin Cant seem to upload it.
              • fcwiltundefined
                fcwilt @Dave Parry
                3.1?
                So you got it up to 3.0 already?
                  Dave Parry
                  No I hadnt but have now. When I looked down the list 3.1 was above 2.05 and 3.0 was below and I didnt see it.
                  • fcwiltundefined
                    fcwilt @Dave Parry
                    You now should be able to go to 3.3.0 or (if you ok with betas) to 3.4.x.
                      Dave Parry
                      Thanks Frederick.
                      Cant get 3.4 to install. Get Error: In-application programming binary "Duet2CombinedIAP.bin" not found
                      Temps are working now but still have problem that cant set heaters to active
                      Have tried all the way back to 3.2. Same error message
                        Dave Parry
                        Got it done now at WiFi/Ethernet 3.4.0beta3 (2021-08-24)
                        • fcwiltundefined
                          fcwilt @Dave Parry
                          This post is deleted!
                          • fcwiltundefined
                            fcwilt @Dave Parry
                            Glad to hear it.
                              Dave Parry
                              OK so Hot end now goes Off Active and standby, but Bed not showing up and these error messages
                              G28
                              Warning: Obsolete use of S parameter on G1 command. Use H parameter instead.
                              Error: Failed to enable endstops
                                Dave Parry
                                Oh and no fan controls showing up
                                • fcwiltundefined
                                  fcwilt @Dave Parry
                                  Do you have this command after the M950 for the bed heater?
                                  M140 P0 H0 ; map heated bed to heater 0
                                  G28
                                  Correct.
                                  What used to be G1 S1 is now G1 H1.
                                  Just edit your homing files.
                                    Dave Parry
                                    Have bed temps working now, many thanks.
                                    Homing not working because of end stops Not enabled.
                                    Is that similar to temp sensors?
                                      Dave Parry
                                      I just checked and I have
                                      M574 X2 Y2 Z2 S1 ; set active high endstops
                                      Wiki says they have to be seperate lines
                                        Dave Parry
                                        OK so now I get it to home and move down 5mm and home again, but it then should move down and centre. but it stays with end stops activated and I get message Error: G0/G1: target position not reachable from current position
                                        File is
                                        ; homedelta.g
                                        ; called to home all towers on a delta printer
                                        ; generated by RepRapFirmware Configuration Tool v3.3.2 on Thu Sep 02 2021 19:22:19 GMT+0100 (British Summer Time)
                                        G91 ; relative positioning
                                        ;*** Slow homing has been configured. Change F180 to F1800 below when your configuration is working
                                        G1 H1 X265 Y265 Z265 F2500 ; move all towers to the high end stopping at the endstops (first pass)
                                        G1 H2 X-5 Y-5 Z-5 F1800 ; go down a few mm
                                        ;*** Slow homing has been configured. Change F180 to F360 below when your configuration is working
                                        G1 H1 X10 Y10 Z10 F180 ; move all towers up once more (second pass)
                                        G1 Z-5 F2400 ; move down a few mm so that the nozzle can be centred
                                        G90 ; absolute positioning
                                        G1 X0 Y0 F2400 ; move X+Y to the centre
                                        • fcwiltundefined
                                          fcwilt @Dave Parry
                                          Correct.
                                            Dave Parry
                                            Seem to think that error message is related to homed height, but just tried adding 5mm to homed height no different and then tried subtracting 5mm same.
