    Configuration problems
    Firmware installation
    2.0k
    • Dave Parryundefined
      Dave Parry
      Just need to sort fan control not showing and M106 not doing anything either. Think it's because they havent been properly configured.
      • fcwiltundefined
        fcwilt @Dave Parry
        @dave-parry said in Configuration problems:
        Need to see you most recent fan code. It may be still back at v2 syntax.
          Dave Parry
          Think your right
          M106 P0 S0 I0 F500 H-1 C"Part Clg" ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
          M106 P1 S0 I0 F500 H-1 C"Bed Clg" ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
          • fcwiltundefined
            fcwilt @Dave Parry
            Think your right
            Yes - that's v2 syntax.
            Here is my code for two fans:
            ; cooling fans
            ; -- P# is fan, S# is speed (0 to 255 or 0.0 to 1.0) H# means turn on fan when heater H# temp hits T#
            ; -- H-1 means no thermostatic control
            M950 F0 C"fan0" Q500        ; create fan (F), pin name (C), frequency (Q)
            M106 P0 C"Part" S0 H-1      ; set fan (P), name (C), speed (S), thermostatic control off (H)
            M950 F1 C"fan1" Q500        ; create fan (F), pin name (C), frequency (Q)
            M106 P1 C"Hotend" S1 H1 T45 ; set fan (P), name (C), speed (S), thermostatic control on (H & T)
              Dave Parry
              @fcwilt said in Configuration problems:
              Have got them working with this
              M950 F0 C"fan0"
              M950 F1 C"fan1"
              But have tool fan on there as well which also starts part fan
                Dave Parry
                Tried rem ing out fan0 but then tool fan controls do nothing
                  Dave Parry
                  Just noticed that the tool fan shows when the hot end is active and when hot end is off or standby is hidden.
                  I either need to hide it completely or get rid of the part fan control but have the tool fan control that fan
                  • fcwiltundefined
                    fcwilt @Dave Parry
                    That tool fan display is controlled by the DWC.
                    It's just a way of having a single consistently named control in those cases where you might have multiple tools each with their own fan.
                    You can control the visibility of the actual part fan from the DWC.
                      Dave Parry
                      Frederick,
                      Can you tell me where the conrol for fan visibilty is, because I cant see it.
                      also Thanks for your great patience and help.
                        Dave Parry
                        Found it. I was looking on the dashboard and its on the status.
                        • fcwiltundefined
                          fcwilt @Dave Parry
                          Frederick,
                          This is visible when you have selected the Job/Status display in the DWC.
                          See the item "Change Visibility"?
                            Dave Parry
                            Yours looks different to mine. I dont have no fans option, just lists all the fans with a tick box for each. Also jobs and status are seperate tags.
                            • fcwiltundefined
                              fcwilt @Dave Parry
                              Like this?
                              Status is under the Job category - that what I meant by Job/Status
                                Dave Parry
                                I understand, and if I turn all the fans off in the tick box I get no fans message, Think I'm getting tired, Will carry on with calibration tomorrow. Thank you for your help. would'nt have got there without it.
