    Trouble assigning filament sensor after using pin for GPIO
    Filament Monitor
    • Pietundefined
      Piet
      Hi all,
      I have a question about assigning a filament sensor to an input after using it for a GPIO pin.
      I'm using a rotary magnetic encoder as filament sensor, this is placed inside my extruder and is declared as a pulse generating filament sensor.
      Now i'm trying to write a macro for loading the filament into the extruder and priming the nozzle. To do this i remove the filament sensor in the macro, read the output of the sensor (0 or 1), and keep extruding until that changes. After that i extrude an extra amount to prime the nozzle and remove the GPIO and try to redefine the filament sensor.
      However if i do this it throws this, Error: M591: Pin 20.io1.in is not free, even tho i
      removed it using: M950 J9 C"nil" and echo exists(sensors.gpIn[9]) returns false.
      Does anyone know of a way to fix this or should i abandon this macro?
      G91 															; relative posisitioning
      M591 D0 P0														; remove existing filament sensor
      M950 J9 C"20.io1.in"											; add GPIO at filament sensor pin
      var sensorInput = sensors.gpIn[9].value							; read current filamentsensor output
      M291 P"Load filament into the drive gears." S3
      while (sensors.gpIn[9].value == var.sensorInput)				; while filamentsensor value does not change keep extruding
      	G1 E1 F1800
      	if iterations > 50
      		M291 P"Loading filament has timed out" S2
      		M591 D0 P7 C"20.io1.in" L0.061 R80:120 E1 S1
      		G90
      		M99
      echo "Filament sensor has been triggered. Priming nozzle."
      M400
      G1 E110 F300													; prime nozzle
      M400
      G90
      M950 J9 C"nil"													; remove GPIO
      M591 D0 P7 C"20.io1.in" L0.061 R80:120 E1 S1					; add filament sensor again
      M291 P"Filament has been loaded." S2
      Thanks in advance,
      Piet.
        dc42 administrators @Piet
        @piet which firmware version are you using? A bug in this area was fixed in firmware 3.3.
        Pietundefined 1 Reply Last reply Reply Quote 0
        • Pietundefined
          Piet @dc42
          @dc42 Im using version 3.4.0beta3 in SBC mode
          dc42undefined 2 Replies Last reply Reply Quote 1
            @piet thanks, I'll test that.
              @piet I confirm there is a bug. M950 J# C"nil" does not release the port if it is on an expansion board. This will be fixed in the next beta release of the expansion board firmware.
              As a workaround, if you have a spare IOx.IN port on the same expansion board, then instead of deleting the GpIn port using C"nil" you could reassign it to that pin.
              Pietundefined 1 Reply Last reply Reply Quote 1
              • Pietundefined
                Piet @dc42
                @dc42 Alright, thanks for the help!
