    beep when filament run out sensor triggers
    Using Duet Controllers
    620
    • davidewenundefined
      davidewen
      I would like to have a repeating beep when the filament run out sensor triggers.
      Has anyone done this?
      Thanks,
      David
      cosmowaveundefined 1 Reply Last reply Reply Quote 1
      • cosmowaveundefined
        cosmowave @davidewen
        @davidewen You have to write a macro with M300 and G4...
        Mankati FSXT+, DeltaTowerV2, E3D MS/TC
        davidewenundefined 1 Reply Last reply Reply Quote 1
          davidewen @cosmowave
          @cosmowave
          I've never written a macro.
          Can you direct me to some instructions or a YouTube video?
          Or would you have some examples that I could learn from?
          Thanks,
          David
          fcwiltundefined cosmowaveundefined 2 Replies Last reply Reply Quote 0
          • fcwiltundefined
            fcwilt @davidewen
            @davidewen said in beep when filament run out sensor triggers:
            @cosmowave
            Thanks,
            David
            Do you want the beeping to continue until you turn it off in some manner?
            davidewenundefined 1 Reply Last reply Reply Quote 0
              One important thing: which firmware are you using?
              In the dozuki you can find some instructions.
              Or here in the forum in the "conditional code" category you will also find different examples of other users...
                davidewen @fcwilt
                @fcwilt
                Yes, I would like the beeping to continue until I acknowledge it.
                FW:
                RepRapFirmware for Duet 3 Mini 5+ version 3.3 (2021-06-15 21:46:11) running on Duet 3 Mini5plus WiFi (standalone mode)
                David
                • fcwiltundefined
                  fcwilt @davidewen
                  @fcwilt
                  FW:
                  David
                  Perhaps you could use daemon.g (a special file that runs periodically if it exists) to generate the beeping (using conditional code).
                  The filament sensor could enable the code. A macro could disable the code.
                    @davidewen
                    First you should define a "filament-error#.g" macro, which is called at filament runout (# is the number of your extruder).
                    In this "filament error macro" you can create and set a global variable.
                    After setting the variable, add a blocking message (M291...)
                    You have to reset the variable after confirming the filament change.
                    Create a "daemon.g" file in the sys folder. Here you can check the variable and make your beeps.
                    eventually something like this...
                    while global.beep = true
                    	M300 S500 P1000		; beep with 500Hz for 1sec
                    	G4 P1000		; delay of 1sec
