    New test firmware 1.19+4 and DuetWiFiServer 1.19+1
    Firmware installation
    8
    36
    3.9k
    • lolorcundefined
      lolorc
      @Jarery:
      Im now wishing i purchased the ethernet versions. Or is there a way I can use the web browser interface with a serial port connection from a laptop and I'll forget the wifi part?
      I'm also having a hard time with my duet wifi at the moment.
      I'm writting a small python caching proxy to replace the wifi/webserver stack from the duet while still using the web ui
      At the moment I'm able to correctly proxy everything to the duet through wifi, I'm able to connect, upload and print through it.
      I also have a thread polling the duet with M408 every seconds through usb/serial to provide rr_status data instead of getting them through wifi.
      I'll probably try to proxy every http rr_* commands as usb/serial gcodes (not sure about the upload/download yet)
        Please can both of you connect via both USB and WiFi, and when the WiFi connection is lost, see what reconnection messages are written to USB and post them here? This is assuming that you are both running firmware 1.19.2.
        Some users have found that the WiFi connection is more stable if they set the access point to a fixed channel (usually 6) instead of leaving it on auto select.
        If the disconnections occur only during printing or other movements, and you have high microstepping selected, try putting the microstepping back to x16 with interpolation.
        A few users have converted a Duet WiFi to a Duet Ethernet. Hot air rework equipment is needed to remove the WiFi module, but after that it's straightforward to install the Ethernet module in its place.
        • Jareryundefined
          Jarery
          Thanks for the reply
          Both the suggestions I have been using since the beginning of my issues:
          • I've set my modem to a fixed channel from earlier suggestions
          • i've always been using 16x with interpolation (0.9 steppers)
          I've had macpronterface hooked up while i print and its disconnected. Running M122 on it after i lose web browser connection, the output ri posted above.
          Perhaps I don't understand your instructions of " see what reconnection messages are written to USB" as i see no messages mirrored to the usb when it disconnects and as mentioned the M122 output is as i posted above where it states reconnections 0. Is there a different command you want me to run via usb after it disconnects?
          My Settings:General are as per default, ajax retries 5 (I've boosted to 10 with no effect),
            Are you definitely running version 1.19.2 of DuetWiFiServer as well as version 1.19.2 of DuetWiFiFirmware? Look in the Settings General tab to check.
            • Jareryundefined
              Jarery
              Firmware Name: RepRapFirmware for Duet WiFi
              Firmware Electronics: Duet WiFi 1.0
              Firmware Version: 1.19.2 (2017-09-01)
              WiFi Server Version: 1.19.2
              Web Interface Version: 1.19
                If the WiFi module has disconnected from your router then it should write a message to USB saying so and giving progress information about the reconnection attempt. This was new in 1.19.2.
                • DocTruckerundefined
                  DocTrucker
                  Is the "File Information" section of the web page getting information from the firmware or purely on the web server side of things? How is it identifying layers if on the firmware? Mine is currently reporting 0.35mm layer thickness, which is only the first layer. I have however stripped a lot of code out of the gcode file to stop it using heat, and might have accidentally stripped what it is using to identify layers!
                  Edit: Nuts. Just seen the rc5 release… Will upgrade after testing the time estimation.
                    DocTrucker
                    Late report on the build time estimation! This is a test build with no heat. Works fine for me.
                    Actual build time: 2hr20m36s
                    Time to run the simulation: 0hr5m30s
                    Predicted build time: 2hr21
                    25.6 times quicker than build time on a Duet 0.6. I'll run a similar test on the DuetWifi at home soon. Guess I could just run the simulation and use this machine's config file temporarily.
                    Edit: Running the above again in 1.19+5 (2017-08-30) Will report on that thread.
                      Please use the 1.19.2 release from https://github.com/dc42/RepRapFirmware/releases, not the older +5 release.
                      The file information is provided by the firmware.
                      The Duet WiFi has a faster processor than the 0.6 so it should run the simulation faster.
                        DocTrucker
                        Thanks. Will do - after the current test has completed. Didn't spot the 19.2 release.
                        • Jareryundefined
                          Jarery
                          @dc42:
                          Doing a mesh bed calibration it disconnects mid way through. No output or messages on MacPronterface which was connected via serial at the time. I get no messages via serial at all unless I type a command to get a response.
                          On the MacPronterface if I do a M122 I get the following Wifi section:
                          Network state is running
                          WiFi firmware version 1.19.2
                          WiFi MAC address 5c:cf:7f:a4:a1:64
                          WiFi Vcc 3.13, reset reason Turned on by main processor
                          WiFi flash size 4194304, free heap 39840
                          WiFi IP address 192.168.2.54
                          WiFi signal strength -38dBm
                          Reconnections 0
                          HTTP sessions: 1 of 8
                          Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                          Trying to reconnect via browser that was open previously is " Error, Could not establish a connection to the Duet firmware! Please check your settings and try again" repeatedly, unable to reconnect.
                          Opening a new browser, to check Router (Asus AC3100) I see its connected and assigned an IP. Clicking on IP within router browser its unable to open a new window, it just times out.
                            That sounds like a different failure mode (connection stable but messages not getting through). Try enabling Webserver and Network debugging using M111, then see whether the failed attempts to open a session in a browser give rise to any debug messages in Pronterface.
                            • Jareryundefined
                              Jarery
                              heres whats the serial connection reports after after a disconnect :
                              HTTP connection accepted
                              Found responder
                              Received 394 bytes
                              Sending reply, file = no
                              HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=3 }
                              New conn on socket 0 for local port 80
                              Found responder
                              Received 394 bytes
                              Found responder
                              Received 394 bytes
                              Class Network spinning.
                                According to that, the Duet appears to be behaving correctly. Can you get a Wireshark trace of the network traffic?
                                • Jareryundefined
                                  Jarery
                                  That is beyond my current level of network troubleshooting ability…
                                  Once it disconnects, My web browser just repeatedly states it cannot connect, and the serial output is :
                                  File DuetWifi_Wiring_Box.gcode print time was 5h 8m
                                    Sounds like the WiFi module has stopped responding. Sending M552 S-1 to reset it followed by M552 S1 to reconnect may get it working again, but that doesn't solve the problem.
                                    • Adamfilipundefined
                                      Adamfilip
                                      Noticed that my PanelDue 7 flashes now every second or so. didnt do this before.. not sure whats causing it.
                                        If you mean the backlight flashes on and off, or isn't a steady brightness, that's common if you try to power a 7" PanelDue from USB power only. A standard 500mA USB port can't provide enough current for the 7" display.
                                        • Jareryundefined
                                          Jarery
                                          @dc42:
                                          This helps occasionally.
                                          After initial power on, once connected it seems to remain connected until I print. I have yet to have a print go beyond 15-20 min and stay connected since the update from 1.18
                                          I have a macro that disconnects wifi and reactivates so after it loses connection I can attempt to reacquire. I have maybe 50-50 success rate. Many times, doing this still I am unable to require web browser. The only sure fire way is to power completely off, unplug serial if connected, and power back up. Even if i do reacquire connection mid print using this method (macro not reboot) it disconnects again after a period of time.
                                          My router shows ip assigned the entire time.
                                          Safari, chrome, etc, browser has no change.
                                            If you run M122 after a print, what MaxReps value does it give?
