Multiple Z Probes Duet 3
I have upgraded my duet 2 to a duet 3 after one of trinamic drivers on the duet 2 died.
I have modified the Workbee z probe to use the new duet 3 IO names and that all works fine.
I want to add another Z probe to the machine in a fixed location to simply touch off new tools when changed instead of keep attaching/detaching the ooznest probe each time.
if i add M558 K1 P5 C"io6.in" H5 F500 T500 as a new line in config-probe.g then go into the machine specific tab it shows the 2 probes but both work off the 1st probe input or more specifically the probe input defined as "K0" if i swap them. Im at a bit of a loss and cant find anyone else having the same problemCheers
Rich -
@rich1351 there is a restriction that probe types 1, 2 and 5 can only be used for probe 0. So I suggest you use probe type 8 for your second probe instead of 5.
@dc42 Thanks, I knew there would be something I had missed, I read through the M558 page that many times it was starting to not make any sense
Ill get that sorted in the morning now, Thanks Again
Cheers
Rich
