    Display 3HC mcu and drivers temp
    Using Duet Controllers
    • Pierigundefined
      Pierig
      I can display the Duet 3 6HC mcu and drivers temp with
      M308 S10 Y"mcu-temp" A"6HC MCU"
      M308 S11 Y"drivers" A"6HC Steppers"
      But How do get the same info from expansion boards?
      Cheers.
        dc42 administrators @Pierig
        @pierig for e.g. a board at CAN address 1 you can use:
        M308 S12 Y"mcu-temp" P"1.dummy" A"3HC MCU"
        M307 S13 Y"drivertemp" P"1.dummy" A"3HC Steppers"
        Note, in the next 3.4.0beta release, "drivertemp" will be changed to "drivers" to match the main board.
        Pierigundefined Mr Yodundefined 2 Replies Last reply Reply Quote 0
        • Pierigundefined
          Pierig @dc42
          @dc42 Thank you sir! works perfectly!
          • Mr Yodundefined
            Mr Yod @dc42
            @dc42 said in Display 3HC mcu and drivers temp:
            Thanks! 😮
            Just a minor correction: it should be M308 even for 3HC Steppers (I couldn't understand why it wouldn't show up, then I noticed that slight difference 😃 ).
            Besides: do I need to calibrate the 3HC processor's sensor too like I did for the 6HC or one calibration fits all?
