    3.4rc1 Mini 5+ bltouch not retracting
    Beta Firmware
    467
      For good measure can you share your config.g, and the results of M122?
      • Serbitarundefined
        Serbitar
        I downgraded to 3.4b6 to get a print done but here is config.g
        G90                                                ; send absolute coordinates...
        M83                                                ; ...but relative extruder moves
        M550 P"Ender 3"                                    ; set printer name
        M918 P1 E4 F2000000                                ; configure direct-connect display
        M929 P"log.txt" S1                                 ; Enable logging
        ;M552 S1                                            ; Enable network
        M569 P0.0 S1 D3 V0 F4                              ; physical drive 0.0 goes backwards, stealthchop enabled
        M569 P0.1 S0 D3 V0 F4                              ; physical drive 0.1 goes backwards, stealthchop enabled
        M569 P0.2 S1 D3 V0 F4                              ; physical drive 0.2 goes backwards, stealthchop enabled
        M569 P0.3 S0 D3 V0 F4                              ; physical drive 0.3 goes forwards,  stealthchop enabled
        M569 P0.4 S0 D3 V0 F4                              ; physical drive 0.4 goes forwards,  stealthchop enabled
        M569 P0.5 S1 D3 V0 F4                              ; physical drive 0.5 goes backwards, stealthchop enabled
        M569 P0.6 S1 D3 V0 F4                              ; physical drive 0.6 goes backwards, stealthchop enabled
        M584 U0.0 X0.3 Y0.4 Z0.5:0.6 E0.1:0.2              ; set drive mapping
        M350 U16 X16 Y16 Z16 E16:16 I1                        ; configure microstepping with interpolation
        M92 U80.00 X80.00 Y80.00 Z400.00 E413.4:413.4      ; set steps per mm
        M566 U450 X450 Y450 Z60.00 E120.00                 ; set maximum instantaneous speed changes (mm/min)
        M203 U9000.00 X9000.00 Y9000.00 Z480.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
        M201 U2500.00 X2500.00 Y2500.00 Z20.00 E500.00:500.00  ; set accelerations (mm/s^2)
        M906 U1000 X1000 Y1000 Z1000 E1200:1200 I50          ; set motor currents (mA) and motor idle factor in per cent
        M84 S30                                            ; Set idle timeout
        M915 X Y S5 F1 R0 H150                             ; Stall detection XY log on stall
        M915 Z   S3 F1 R2 H200                             ; Stall detection Z pause on stall
        M915 P0.1:0.2 S5 F1 R0                             ; Stall detection E0,E1 do nothing
        M208 U-80.8 X-212 Y-150.6 Z0 S1                     ; set axis minima
        M208 U213.8 X95 Y100 Z230 S0                        ; set axis maxima
        M574 U2 S1 P"io0.in"                               ; configure active-high endstop for high end on Y via pin io0.in
        M574 X1 S1 P"io5.in"                               ; configure active-high endstop for low end on X via pin io6.in
        M574 Y1 S1 P"io6.in"                               ; configure active-high endstop for low end on Y via pin io5.in
        M574 Z1 S2                                         ; configure Z-probe endstop for low end on Z
        ; Filament runout sensors
        M591 D0 P1 C"^io3.in" S0                           ; Left extruder runout
        ;M591 D1 P1 C"^io2.in" S0                           ; Right extruder runout
        M950 S0 C"io1.out"                                 ; create servo pin 0 for BLTouch
        M558 P9 C"^io1.in" B1 H5 F480 T6000                ; set Z probe type to bltouch and the dive height + speeds disable heaters when probing
        G31 P500 X66 Y12 Z1.8
        M557 X-110:110 Y-110:110 S20                       ; define mesh grid
        M308 S0 P"temp0" Y"thermistor" T100000 B3950       ; configure sensor 0 as thermistor on pin temp0
        M950 H0 C"out0" T0                                 ; create bed heater output on out0 and map it to sensor 0
        M140 H0                                            ; map heated bed to heater 0
        M143 H0 S120                                       ; set temperature limit for heater 0 to 120C
        M308 S1 P"temp1" Y"pt1000"                         ; configure sensor 1 as thermistor on pin temp1
        M950 H1 C"out1" T1                                 ; create nozzle heater output on out1 and map it to sensor 1
        M307 H1 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
        M143 H1 S300                                       ; set temperature limit for heater 1 to 280C
        M308 S2 P"temp2" Y"pt1000"                         ; configure sensor 2 as thermistor on pin temp2
        M950 H2 C"out2" T2                                 ; create nozzle heater output on out2 and map it to sensor 2
        M307 H2 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
        M143 H2 S300                                       ; set temperature limit for heater 2 to 280C
        M950 F0 C"out5" Q1000                              ; create fan 0 on pin out5 and set its frequency
        M106 P0 C"Part Coling T0" S0 H-1                   ; set fan 0 name and value. Thermostatic control is turned on
        M950 F1 C"!out3+out3.tach" Q1000
        M106 P1 C"Hotend Fan T0" S64 X64 H1 T45
        M950 F2 C"out6" Q1000                              ; create fan 2 on pin out6 and set its frequency
        M106 P2 C"Part Cooling T1" S0 H-1                  ; set fan 2 name and value. Thermostatic control is turned off
        M950 F3 C"!out4+out4.tach" Q1000
        M106 P3 C"Hotend Fan T1" S64 X64 H2 T45
        M563 P0 S"Left Tool" D0 H1 F0                      ; define tool 0
        G10 P0 X0 Y0 Z0                                    ; set tool 0 axis offsets
        G10 P0 R0 S0                                       ; set initial tool 0 active and standby temperatures to 0C
        M563 P1 S"Right Tool" D1 H2 F2 X3                  ; define tool 1 using U axes for X
        G10 P1 X0 Y2 Z0                                    ; set tool 1 axis offsets
        G10 P1 R0 S0                                       ; set initial tool 1 active and standby temperatures to 0C
        M307 H0 R0.281 C428.8 D4.28 S1.00 V23.9
        ;M911 S21 R23 P"M913 X0 Y0 G10 P0 R0 S0 G91 M83 G1 Z3 E-5 F10000" ; set voltage thresholds and actions to run on power loss
        M572 D0 S0.05                                    ; Guestimate pressure advance setting
        M207 S0.5   F2400                                  ; Retraction 0.5mm @40mm/s
        M671 X-145:145 Y0:0 S3 F1                          ; leadscrew co-ordinates
        M81 C"ps_on"                                       ; Turn off power supply (makes power switch show in webui)
        ; Load from config-override.g
        M501
        deployprobe.g:
        M280 P0 S10 ; deploy BLTouch
        • Serbitarundefined
          Serbitar
          In 3.4rc1 the probe now deploys but doesn't retract after probing.
          Machine was completely powered off after the update.
          M122
          RepRapFirmware for Duet 3 Mini 5+ version 3.4.0rc1 (2022-02-09 10:27:22) running on Duet 3 Mini5plus WiFi (SBC mode)
          Board ID: W4ZW4-V296U-D65J0-40KM0-LR03Z-H6928
          Used output buffers: 1 of 40 (14 max)
          Static ram: 103652
          Dynamic ram: 102128 of which 0 recycled
          Never used RAM 35788, free system stack 134 words
          Tasks: SBC(ready,3.9%,504) HEAT(notifyWait,0.0%,356) Move(notifyWait,0.0%,292) CanReceiv(notifyWait,0.0%,942) CanSender(notifyWait,0.0%,356) CanClock(delaying,0.0%,339) TMC(notifyWait,1.1%,114) MAIN(running,93.8%,558) IDLE(ready,0.4%,29) AIN(delaying,0.8%,264), total 100.0%
          Owned mutexes: HTTP(MAIN)
          Last reset 00:08:35 ago, cause: software
          Last software reset at 2022-02-09 18:36, reason: User, GCodes spinning, available RAM 36076, slot 0
          Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task SBC Freestk 0 n/a
          Error status: 0x00
          MCU revision 3, ADC conversions started 515901, completed 515899, timed out 0, errs 0
          Step timer max interval 1489
          MCU temperature: min 27.5, current 37.5, max 37.8
          Supply voltage: min 0.5, current 24.3, max 24.3, under voltage events: 1, over voltage events: 0, power good: yes
          Events: 0 queued, 0 completed
          Driver 0: pos 3760, standstill, SG min 0, read errors 0, write errors 2, ifcnt 13, reads 44146, writes 25, timeouts 0, DMA errors 0, CC errors 0
          Driver 1: pos -1280, standstill, SG min 0, read errors 0, write errors 2, ifcnt 10, reads 44148, writes 23, timeouts 0, DMA errors 0, CC errors 0
          Driver 2: pos 3560, standstill, SG min 0, read errors 0, write errors 2, ifcnt 10, reads 44147, writes 23, timeouts 0, DMA errors 0, CC errors 0
          Driver 3: pos 17104, standstill, SG min 0, read errors 0, write errors 2, ifcnt 15, reads 44140, writes 29, timeouts 0, DMA errors 0, CC errors 0
          Driver 4: pos 0, standstill, SG min 0, read errors 0, write errors 2, ifcnt 15, reads 44142, writes 29, timeouts 0, DMA errors 0, CC errors 0
          Driver 5: pos 0, standstill, SG min 0, read errors 0, write errors 2, ifcnt 15, reads 44142, writes 29, timeouts 0, DMA errors 0, CC errors 0
          Driver 6: pos 0, standstill, SG min 0, read errors 0, write errors 2, ifcnt 15, reads 44140, writes 29, timeouts 0, DMA errors 0, CC errors 0
          Date/time: 2022-02-09 18:46:07
          Cache data hit count 1160425780
          Slowest loop: 60.47ms; fastest: 0.08ms
          === Storage ===
          Free file entries: 10
          SD card 0 not detected, interface speed: 0.0MBytes/sec
          DMs created 83, segments created 6, maxWait 48307ms, bed compensation in use: none, comp offset 0.000
          === MainDDARing ===
          Scheduled moves 39, completed 39, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state -1
          === AuxDDARing ===
          Segments left: 0
          Movement lock held by null
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          SBC is idle in state(s) 0
          Daemon is idle in state(s) 0
          Aux2 is idle in state(s) 0
          Code queue is empty
          === Filament sensors ===
          Extruder 0 sensor: ok
          === CAN ===
          Messages queued 4633, received 0, lost 0, boc 0
          Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 18 (min 18), ts 2578/0/0
          Tx timeouts 0,0,2577,0,0,2054 last cancelled message type 4514 dest 127
          === SBC interface ===
          Transfer state: 4, failed transfers: 0, checksum errors: 0
          RX/TX seq numbers: 20857/20857
          SPI underruns 0, overruns 0
          State: 5, disconnects: 0, timeouts: 0, IAP RAM available 0x0f624
          Buffer RX/TX: 0/0-0, open files: 0
          === Duet Control Server ===
          Duet Control Server v3.4-rc1
          Code buffer space: 4096
          Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0
          Full transfers per second: 40.50, max time between full transfers: 47.1ms, max pin wait times: 46.5ms/6.9ms
          Codes per second: 0.45
          Maximum length of RX/TX data transfers: 3592/1136
          • Serbitarundefined
            Serbitar
            Further debug...
            I replaced my bltouch with a multimeter set to measure frequency and duty cycle.
            Reset the board by pressing the reset button
            Measured 0% duty
            Sent M280 P0 S90
            Measured 7.35% duty at 50Hz
            Send M280 P0 S180
            no change in measurement
            sent m280 P0 s270
            no change in measurement.
            reset board.
            sent m280 p0 s270
            measured 12% duty at 50Hz
            sent m280 p0 s90
            Thus i think my issue is the same as this thread:
            https://forum.duet3d.com/topic/27139/rrf-3-4-0beta7-5-sbc-servo-only-responding-once-after-reset
            • Serbitarundefined
              Serbitar
              With 3.4b6
              Measured 0% duty
              Sent M280 P0 S90
              Sent M280 P0 S180
              Send M280 P0 S270
              Sent M280 P0 S90
              So updating servo positions multiple times in 3.4b6 works
                dc42 administrators @Serbitar
                @serbitar I can confirm that this is a bug in 3.4.0rc1. It affects the use of port IO1 on the Duet 3 Mini to connect a servo or BLTouch, but not IO2 or IO3. Are you able to use either of those ports for now? Note that IO3 is shared with the 12864 backlight control.
                • Serbitarundefined
                  Serbitar
                  Ah! I will sacrifice one of the runout sensors to put it on io3 and give it a go, thanks.
                  • Serbitarundefined
                    Serbitar
                    Works great on io3 thanks again.
                      @serbitar I've put corrected firmware for the Mini5+ at https://www.dropbox.com/sh/hx23neagiljflv2/AADxC8_URWgoU_NYcYP8b7XCa?dl=0.
                      • Serbitarundefined
                        Serbitar
                        bltouch back on io1 with your updated build works. fantastic! thanks!
                        • Phaedruxundefined Phaedrux has marked this topic as solved
