    3.4RC1 1XD board BUG?
    Beta Firmware
    • Marcossfundefined
      Marcossf
      I think we found a bug in latest RC1.
      With version 3.4beta7 when making a Z home whose axis is controlled by a 1XD plate, after triggering the probe, the axis retracts and rises at the speed set in the homeall.g, after setting Datum Z=0 and everything works correctly.
      On the other hand, with version 3.4 RC1, after triggering the Z probe, it tries to up to the set position after this operation, at an very very very exaggerated speed (it tried do an instant movement). It's so much speed that the external driver (closed loop absolute encoder) to which the Z axis is connected, goes into alarm and stops/block for safety.
      If revert to 3.4beta7, it backs to normal sucessful homeall behaviour and all it works as expected.
      @dc42 Any hint? Related with the canbus delay correction, maybe?
      None on the external driver config was changed or duet config files.
      Homeall.g:
      ; homeall.g
      ; called to home all axes
      M564 S0 ; disable axis limits
      G29 S2
      ;G29 S1 P"heightmap.csv" ; load heightmap
      G4 S1 ; wait until loading the heightmap
      T-1 ; unselect tool
      M584 P5 ; 5 axis visibles
      M584 Z43.0 U44.0 V45.0
      M574 Z2 S1 P"!43.io0.in"
      M574 U2 S1 P"!44.io0.in"
      M574 V2 S1 P"!45.io0.in"
      M208 Z100 U100 V100 S0 ; change max limits
      G91 ; relative positioning
      M208 S0 Z100 U100 V100
      G1 H1 Z100 U100 V100 F2000 ; lift ZUV relative to current position
      M400
      G92 Z100 U100 V100
      G1 H1 X-405 Y-255 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
      M584 P3 ; 3 axis visibles
      G90 ; absolute positioning
      G1 X51 Y0 F3000 ; move to physical X51, Y0 (logical X0,Y0)
      M400 ; wait for moves to finish
      G92 X0 Y0 ; establish current position as X0,Y0
      G30 K0; z probbing
      M114
      M208 Z0 S1 ; Z axis min limit = 0
      G1 H3 Z100 F2000 ; lift Z relative to max position and update M208 Z max limit
      G1 Z-5 F2000 ; move down 5mm for allow compensation
      set global.noToolMax = {move.axes[2].machinePosition}
      M208 Z{move.axes[2].machinePosition} S0
      M564 S1 ; enable axis limits
      M114 ; report positions
      Config.g related:
      ;################################# Z PROBE 0 CONFIG
      M950 S0 C"out4"                      	    ; create servo pin 0 for solenoid on Out4
      M558 P8 C"!io3.in" A1 H12 R0.5 F800 T4000      ; set Z probe type and the dive height + speeds
      G31 X0 Y0 Z0                 	    	    ; set Z probe trigger value, offset and trigger height
      ; ############################## DRIVER PARAMETERS SETTINGS
      M584 X40.0 Y41.0:42.0 Z43.0 U44.0 V45.0 ; axis drive mapping
      M350 X1 Y1 V1 Z1 U1 V1 I1 ; configure axis microstepping with interpolation
      M92 X150.53 Y150.53 Z100.12 U100.12 V100.12 ; axis steps per mm
      M566 X900.00 Y900.00 Z500.00 U500.0 V500.0 ; set maximum instantaneous speed changes (mm/min)
      M203 X18000.00 Y18000.00 Z12000.00 U12000.00 V12000.00 ; set maximum speeds (mm/min)
      M201 X300.00 Y300.00 Z500.00 U500.00 V500.00 ; set accelerations (mm/s^2)
        dc42 administrators @Marcossf
        @marcossf thanks for your example. This sounds to me the same fault as https://forum.duet3d.com/topic/27248/3-4-rc1-1xd-probe-problem-after-update but your example may be easier for me to replicate.
        Marcossfundefined 1 Reply Last reply Reply Quote 1
        • Phaedruxundefined Phaedrux moved this topic from Firmware installation
        • Marcossfundefined
          Marcossf @dc42
          @dc42 Hi David
          We've tested the 3.4RC+2 files from your Dropbox link in our printer and it worked. This problem is solved.
          Currently we have main 6HC with 3.4RC1 fw, DWC 3.4RC1, all boards 1XD and LC1 with 3.4RC1+2. Tested standalone, not in SBC due to global RPI shortage.
          For the moment we have not found any other problems with this version.
