    Endswitches behavior
    RepRapFirmware on other controllers
    • danisizundefined
      danisiz
      I have configured the endswitch using switch type ones and they seem to work fine.
      They respond properly to M119 and work correctly if I run homex for example.
      However if during machine operation for example I move the x-axis in down direction and manually press the low end endstop the machine does not stop.
      Shouldn't the axis stop for safety at that very moment?
      Stephen6309undefined fcwiltundefined 2 Replies Last reply Reply Quote 0
      • Stephen6309undefined
        Stephen6309 @danisiz
        @danisiz No, they are ignored, unless homing. AFAIK, all 3d printer firmwares do this. The firmware will use the M208 setting to keep track.
        • fcwiltundefined
          fcwilt @danisiz
          @danisiz said in Endswitches behavior:
          The endstop sensors only halt movement when doing a G0/G1 move with a H1/H3/H4 parameter.
          danisizundefined 1 Reply Last reply Reply Quote 0
          • danisizundefined
            danisiz @fcwilt
            @fcwilt Thank you. Now I see that the behavior I described is the one that corresponds to the H4 parameter and I assumed that for security it was the default behavior.
              If you want to use your endstop as a emergency stop you can re-purpose them at the end of the homing file to act as an estop. Just be sure to set them as endstops again at the start of homing.
              https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m581-configure-external-trigger
