    Disconnect wifi, failed to upload xx.gcode
    Duet Web Control
    • madin4undefined
      madin4
      I'm new here and the last days I wired my duet2 WiFi to my printer.
      And now ingot two problems.
      It moves, homes and heats that works quite well.
      But now I can't upload any file via WiFi it says
      Failed to upload xxxx.gcode
      I use prusa slicer 2.2
      Firmware is 3.3
      WiFi 1.23
      It is the same with or without the panel due.
      I formated thr sd card twice.
      And It worked yesterday before I updated from 2.1 to 3.3
      My second problem is.
      If I put the .gcode manually on the sd card it prints but super slow.
      Do you have any ideas to help me out?
      Greetings from the alps.
      Stephen6309undefined 1 Reply Last reply Reply Quote 0
      • Stephen6309undefined
        Stephen6309 @madin4
        @madin4 Printing slow: Make sure the slicer is set to RepRapFirmware. If using PrusaSlicer 2.4.1beta, also goto Printer Settings->Machine Limits->How to apply limits to Use for time estimate.
        Update your WiFi firmware, it's out of date. Goto https://github.com/Duet3D/RepRapFirmware/releases/tag/3.3 and download and install Duet2and3Firmware-3.3.zip
        To reflash: https://docs.duet3d.com/User_manual/Reference/Gcodes#m997-perform-in-application-firmware-update
        Also, see: https://docs.duet3d.com/en/User_manual/Troubleshooting/WiFi_troubleshooting
          Uploading this bin file to the system tab should prompt you to update the wifi server.
          https://github.com/Duet3D/RepRapFirmware/releases/download/3.3/DuetWiFiServer.bin
          What happens if you try to upload a gcode file through the Duet Web Control interface?
          • madin4undefined
            madin4
            So I tried everything.
            First of all I got the printer running and already calibrated a few things looks quite good so far
            The WiFi problem still exists. It works fine until I want to upload a .gcode file.
            There is no prblem uploading a .bin that works perfectly fine. And its not like that I have large .gcode calibration cube and such things I haven´t even printed a benchy jet.
            Those is the firmware thats fine right?
            I also tried with the latest 3.4 no change.
            Also in my Fr!tzbox i diled in Chanel 6 and set the printer on priorety.
            I realy don´t know what that could be.
            I hope you can help me.
            Cheers Martin
              Phaedrux Moderator @madin4
              @madin4 said in Disconnect wifi, failed to upload xx.gcode:
              Fr!tzbox
              It's funny you should mention fritzbox. There have been a few other users that have complained about issues with this router. Do you have a different router or access point you can test with?
