    Firmware 1.19
    Firmware installation
    1.7k
    • Duet_Noobundefined
      Duet_Noob
      Hello ,
      must unfortunately use a translator, excuse me for it already in advance!
      I am really super satisfied with the Duet, currently build in the company a 3d printer which also the Duet gets with expansion card.
      On my private Duet Wifi would like to install the current firmware 1.19, unfortunately I'm not there any further, hope here can someone help me!
      I started with firmware 1.17 and then unfortunately installed immediately 1.19.
      That was wrong.
      Think must now write everything from the PC to the card.
      1. Have DuetWebControl-1.19 on the SD card in the folder www. pushed.
      2. DuetWiFiFirmware-1.19.bin, copied into / sys and renamed in exactly
          DuetWiFiFirmware.bin
      3. DuetWiFiServer-1.19.bin, copied into / sys and renamed to exactly
          DuetWiFiServer.bin
      4 A macro file in / macros to set up access to your WiFi network. I call this file SetNetwork, but you can choose any name. This should contain the following commands …..
      How do I create a macro now? With Repetier - Host or Ponterface? Can not connect between Repetier Host and Duet with USB …
      Now have a mix of version 1.17 and 1.19 maybe
      Best I delete everything and write the working data on it?
      Many thanks in advance
      Sorry for the stupid questions 🙂
      Andy
        First get the main firmware working via USB:
        • Use a text editor (e.g. Notepad++) to edit the config.g file on the SD card, putting a semicolon at the start of the M552 line. This stops it trying to enable the WiFi module, removing any startup issues you might encounter due to mismatched firmware versions.
        • Connect via USB, then open Windows Device Manager and expand Ports. If you see a Duet port then you will be able to connect using Pronterface etc. BUT as you were using 1.17 before, you will need to update the device driver to the latest version. The later device driver works with older firmware versions too.
        • You should then be able to connect via Pronterface or YAT.
        • Send M115 to see what firmware version you are running. If it's earlier than 1.19, use fallback procedure #1 at https://duet3d.com/wiki/Updating_main_firmware to update to 1.19.2.
        • Send M552 S0 to turn the WiFi module on but not try to connect. If you get an error message, then you need to update the wifi module firmware, by sending M997 S1 (you have already copied DuetWiFiServer.bin to your SD card).
        • When you have that working, use YAT to enter your WiFi SSID and password. See https://duet3d.com/wiki/Getting_connected_to_the_Duet_WiFi.
        HTH David
          Duet_Noob
          Thanks David for your quick competent help!
          The semicolon I inserted before M552.
          Where can I find the current device driver?
          Is that right? : https://github.com/dc42/RepRapFirmware/tree/dev/Driver
          In the device manager, I now have a question mark. Can this be installed via the automatic search for new driver? Or where can I find the right driver?
          Have the driver get installed!
          Connecting…
          Printer is now online.
          M115
          SENDING:M115
          FIRMWARE_NAME: RepRapFirmware for Duet WiFi FIRMWARE_VERSION: 1.19 ELECTRONICS: Duet WiFi 1.0 FIRMWARE_DATE: 2017-08-14
          M552 S0
          SENDING:M552 S0
          WiFi module started
          Error: Failed to initialise WiFi module, code -10
          [ERROR] Error: Failed to initialise WiFi module, code -10
          M997 S1
          SENDING:M997 S1
          Trying to connect at 460800 baud:
          failed
          Trying to connect at 230400 baud:
          success
          Erasing 244400 bytes…
          Uploading file...
          5% complete
          10% complete
          15% complete
          20% complete
          25% complete
          30% complete
          35% complete
          40% complete
          45% complete
          50% complete
          55% complete
          60% complete
          65% complete
          70% complete
          75% complete
          80% complete
          85% complete
          90% complete
          95% complete
          Upload successful
          Regards Andy
          P.S: Can upload pictures via external providers only here ?
          what is : The firmware update helper file (iap4e.bin for Generation 2 Duets, and iap.bin for Generation 1 Duets) ???
            Duet_Noob
            now in the YAT:
            M552 S0
            ok<lf>WiFi module started <lf>M587 S "Fritz!Box 7560 LH" P "10101010101010101"
            Bad parameter in M587 command<lf>ok <lf>M587 S "Fritz!Box7560LH" P "01010101010101001"
            No remembered networks<lf>ok <lf>M552
            WiFi module is idle<lf>ok <lf>M552
            WiFi module is idle<lf>ok <lf>M587 S "Funkkiste" P "010101010101"
            Bad parameter in M587 command<lf>ok <lf>M587 S"Funkkiste"P"010101010101001"
            ok</lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf>
              Don't put a space between S and the following " character, or between P and the following " character.
              The firmware update helper is the program that is loaded and run to update the main firmware using M997.
                Duet_Noob
                Now everything seems to have worked out.
                The semicolon I have now removed before 552 by editor.
                But I do not see the Deut-Wifi in the network.
                  Duet_Noob
                  In the network I do not see the duet, but now have access to the router or directly over the IP to the board!
                  Thanks again and it can be unfortunately, that I have to ask more still more …;)
                  Andy
                    Duet_Noob
                    Ah, i forget the Makro file thats the Duet Wifi automatical starts….
                    How was the command for that?
                      Duet_Noob
                      hmm, what is that? Everything a little shifted.
                      M550 PTronx X1 ; Set machine name
                      Here was space M552 S1 ; Enable network
                      ; Access point is configured manually via M587 by the user
                      M586 P0 S1 ; Enable HTTP
                      M586 P1 S0 ; Disable FTP
                      M586 P2 S0 ; Disable Telnet
                      Change to :
                      maybe that helps…
                      No Duet Wifi in Network, only over IP.
                        Check that the Duet is connected to the router by running M552 with no parameters.
                        If you have not already done so, you need to create a new /www folder on the SD card (delete the old one if it is present) and unzip DuetWebControl.zip into it.
