    Website DWC does not work
    Duet Web Control
    • Pietundefined
      Piet
      Hi all,
      I'm running in SBC mode.
      Yesterday i accidentally deleted a directory from my SD card which made it so the UI wouldn't show on the rpi screen. I opted to go for a new install so I flashed a new image of duetpi and updated RRF to 3.4RC2.
      Now it does not show the web interface in the browser (I am using the right IP). I can connect to it using SSH and it does show the interface on the rpi screen just not in the browser. Strange thing is normally when i scan for IPs using advanced IP scanner I can see a dropdown arrow which shows the webpage however now that's not the case.
      I've uploaded the new 3.3 DWC files to the /www folder but it's still not working.
      Does anyone have any idea?
      Thanks in advance, Piet.
        It sounds like your browser might have needed a hard refresh? Or clear the cache.
        If you're using the SBC and still have access to SSH I suggest you use these steps to roll back to the stable branch, which should get you the newly released 3.4 final firmware.
        https://github.com/Duet3D/DuetSoftwareFramework/wiki/SBC-Setup-Guide#downgrading-to-stable-packages
        When using the SBC you should only use the apt get commands to move between versions. Uploading firmware and DWC files directly is not likely to give good results.
