    SBC upgrade to 3.4 did not go smooth
    Firmware installation
    • Nxt-1undefined
      Nxt-1
      Yesterday I took the time to upgrade my Duet 3 MB machine from 3.3 to 3.4. Since I am running it in SBC mode (with a Jetson Nano), I upgraded using apt. However, due to the order in which the different packages get installed and configured, a dependency arises. At least in my case it did.
      Here's the therminal output I got:
      Setting up duetcontrolserver (3.4.0) ...
      Configuration file '/opt/dsf/conf/config.json'
       ==> Modified (by you or by a script) since installation.
       ==> Package distributor has shipped an updated version.
         What would you like to do about it ?  Your options are:
          Y or I  : install the package maintainer's version
          N or O  : keep your currently-installed version
            D     : show the differences between the versions
            Z     : start a shell to examine the situation
       The default action is to keep your current version.
      *** config.json (Y/I/N/O/D/Z) [default=N] ? Y
      Installing new version of config file /opt/dsf/conf/config.json ...
      Setting up duetwebserver (3.4.0) ...
      Configuration file '/opt/dsf/conf/http.json'
      *** http.json (Y/I/N/O/D/Z) [default=N] ? Y
      Installing new version of config file /opt/dsf/conf/http.json ...
      dpkg: error processing package duetwebserver (--configure):
       installed duetwebserver package post-installation script subprocess returned error exit status 1
      dpkg: dependency problems prevent configuration of duetsoftwareframework:
       duetsoftwareframework depends on duetwebserver (= 3.4.0); however:
        Package duetwebserver is not configured yet.
      dpkg: error processing package duetsoftwareframework (--configure):
       dependency problems - leaving unconfigured
      dpkg: dependency problems prevent configuration of duetwebcontrol:
       duetwebcontrol depends on duetsoftwareframework (>= 3.2.0); however:
        Package duetsoftwareframework is not configured yet.
      dpkg: error processing package duetwebcontrol (--configure):
      Setting up duettools (3.4.0) ...
      dpkg: dependency problems prevent configuration of duetpluginservice:
       duetpluginservice depends on duetsoftwareframework (>= 3.3); however:
      dpkg: error processing package duetpluginservice (--configure):
      No apport report written because the error message indicates its a followup error from a previous failure.
        No apport report written because MaxReports is reached already
            dpkg: dependency problems prevent configuration of reprapfirmware:
       reprapfirmware depends on duetsoftwareframework (>= 3.2.0); however:
      dpkg: error processing package reprapfirmware (--configure):
        Processing triggers for libc-bin (2.27-3ubuntu1.5) ...
      Processing triggers for systemd (237-3ubuntu10.53) ...
      Processing triggers for man-db (2.8.3-2ubuntu0.1) ...
      Processing triggers for ufw (0.36-0ubuntu0.18.04.2) ...
      Rules updated for profile 'Nginx HTTP'
      Rules updated for profile 'Nginx HTTPS'
      Firewall reloaded
      Errors were encountered while processing:
       duetwebserver
       duetwebcontrol
       duetpluginservice
       reprapfirmware
      E: Sub-process /usr/bin/dpkg returned an error code (1)
      Duet3D and delta printer enthousiast. Buildlog
      Looking for Duet3D configuration support, check out Nxt-3D
      • chrishammundefined
        chrishamm administrators @Nxt-1
        @nxt-1 It looks like the DuetWebServer package failed to execute the postinst script. Can you confirm using journalctl that DWS could be started when the installation occurred? If not, try to disable the service for now and resume the upgrade:
        sudo systemctl disable duetwebserver
        sudo apt upgrade duetwebserver duetsoftwareframework duetwebcontrol duetpluginservice reprapfirmware
        Perhaps there is something up with your http.json that worked with 3.3 (Kestrel + .NET 5) but not with 3.4 (Kestrel + .NET 6).
        Duet software engineer
        Nxt-1undefined 1 Reply Last reply Reply Quote 0
        • Nxt-1undefined
          Nxt-1 @chrishamm
          @chrishamm I can't really provide any more info I am afaid. Even before I posted the original thread, I already fixed the issue with a mixture of --reconfigures and reinstalls. I mainly posted to raise awareness in case more people encountered the issue.
