Axis quits in middle of print
I just did a conversion of an ender 5 plus to a mini 5+. My Y axis quits on most prints after about 2 hours and I get phase not detected errors on both phases. The first time I had the current set to 800. I bumped to 1200. Same. 950 same failure. (1200 made the motor pretty warm and I subsequently found a thread suggesting that Creality sets Y axis on that model to 900-950. ) As you might imagine it makes a mess. I've played around with cabling. Is there a log or other diagnostics that can help me get to the bottom of it? Thanks
@cryptosojourn said in Axis quits in middle of print:
Check the cables and crimps. The error message may be telling you correctly that the motor is losing connection.
