Y axis motor not responsive
Hi, hoping someone can help a fresh white belt in CNC.
I have a Workbee z+1 with duet3d wifi using DWC. At first one of the Y axis motors was jerking and lagging behind the other, now it is not responding at all.
I've fiddled with the coupler etc and tested the mechanics, tested both the motor and the cable and they all seem fine. Wiring to board is also correct so I've kind of run out of ideas. Is there anything I should be looking for in sys/config or elsewhere that might be instructing that stepper motor specifically?
Any help much is much appreciated.
Can you post your config.g and the results of M122?
What commands is it running when you are having issues?
