    How to run a gcode loop X times
    Gcode meta commands
    • code7undefined
      code7
      Can someone give me a suggestion on a code statement that I can use to run a gcode loop X number of times?
      Delta Printer Using a Duet 2 Wifi v1.04c, FW3.4.0beta2, Duet WiFi sever 1.26, Duet Web Control 3.3.0
      cosmowaveundefined 1 Reply Last reply Reply Quote 0
      • cosmowaveundefined
        cosmowave @code7
        @code7 where would you like to do the loop?
        in a print file or in a macro?
        EDIT:
        If it is in a macro then something like this:
        while iterations < X
            your gcode
        Mankati FSXT+, DeltaTowerV2, E3D MS/TC
        code7undefined 1 Reply Last reply Reply Quote 0
        • code7undefined
          code7 @cosmowave
          @cosmowave Thanks. Much simpler than I expected. This works in the print file.
