    Execonmcode + msmtp
    Plugins for DWC and DSF
    387
    • scumdeadundefined
      scumdead
      Good morning,
      I can’t get this command to work:
      echo "Subject: Scub\nImpression terminée" | msmtp scumdead@gmx.fr
      This works on the sbc, so msmtp is correctly installed.
      Thank you for your help.
      • chrishammundefined
        chrishamm administrators @scumdead
        @scumdead It looks like ExecOnMCode is missing the networkAccess permission, so msmtp cannot communicate with external services. @Falcounet you may want to add it to the next version (see also here for a list of other permissions).
        To work-around it, you could probably enable sudo support (see here) and run something like this instead:
        sudo bash -c 'echo "Subject: Scub\nImpression terminée" | msmtp scumdead@gmx.fr'
        Duet software engineer
        Falcounetundefined 1 Reply Last reply Reply Quote 1
        • Falcounetundefined
          Falcounet @chrishamm
          @scumdead @chrishamm I may release a version to fix that.
          I didn't wanted to add all the required permissions but it looks like I have to (except superUser) as that kind of plugin allow the user to do almost anything on the system.
          • scumdeadundefined
            scumdead
            @chrishamm said in Execonmcode + msmtp:
            Thank you for your answers, but it’s not working.
            Falcounetundefined 1 Reply Last reply Reply Quote 0
              Falcounet @scumdead
              @scumdead I've released v0.3 to fix the plugins permissions : https://github.com/LoicGRENON/DSF_ExecOnMcode_Plugin/releases/download/v0.3/ExecOnMcode-0.3.zip
              For the workaround to work, you first need to enable sudo support but that should not be needed with v0.3
              • scumdeadundefined
                scumdead
                Thanks for the new version.
                Msmtp does not seem to want to work, the msmtprc file cannot exist for the DSF user.
                  Falcounet @scumdead
                  @scumdead DSF user doesn't have HOME so yes you can't define a user configuration for it but you can still use the system configuration located at /etc/msmtprc
                  • scumdeadundefined
                    scumdead
                    It works after: chown dsf etc/msmtprc.
                    Do not use sudo, otherwise the body of the message does not appear.
                    Thanks, with your plugin, my printers will notify their status now.
