    Problem compiling & linking
    Firmware developers
    • Zambiorixundefined
      Zambiorix
      Hi all
      I have followed all instructions on how to start with RepRapFirmware development environment on macos.
      https://github.com/Duet3D/RepRapFirmware/wiki/Building-RepRapFirmware
      The only difference, I didn't use homebrew, but installed gcc-arm-embedded from package (https://developer.arm.com/downloads/-/arm-gnu-toolchain-downloads) and eclipse from direct installer.
      All the other steps are the same.
      CoreN2G, FreeRTOS and RRFLibraries build just fine.
      RepRapFirmware (build configuration Duet3_MB6HC) however gives me errors.
      It seems that uint32_t is undefined, so I add:
      #include <stdint.h>
      in src/libc/nano-mallocr.c
      That gives me the following error:
      Now there are multiple definitions of _malloc_r
      Renaming src/libc/nano-mallocr.c to src/libc/nano-mallocr.c.ignore leaves me with:
      I have no idea where to look next.
      Also, I suppose it's not ok to remove src/libc/nano-mallocr.c , but then again, why did it say that uint32_t is undefined in the first place?
      Am I missing some setup?
      Thanks
      Cheers
      Gerd
        dc42 administrators @Zambiorix
        @Zambiorix we think the issue with multiple definitions of _malloc_r occurs when you use a later version of gcc than the one we currently use. We currently use ARM release 10 2021.10. We'll probably update to a later version before 3.5 final.
        Zambiorixundefined 1 Reply Last reply Reply Quote 1
          Zambiorix @dc42
          Thanks! That solved it, now the project build without errors.
          /bin/sh: crc32appender: command not found
          That is strange, I have added it to my PATH
          gerd@Gerds-MacBook-Pro ~ % whereis crc32appender
          crc32appender: /Users/gerd/Documents/Projects/Projects/Duet3D/RepRapFirmware/Tools/crc32appender/macos-x86_64/crc32appender
          What could be the issue?
            Zambiorix
            Ok, it all works
            I had to add the PATH in Eclipse.
            Project > Properties > C/C++ Build > Environment
            Not sure why I had to do that, since the application is accessible in a terminal window
